Question about Microwave Ovens
H6 error dawlance ac
Kep pad not working please resolve
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 78 Answers
Check all your connections in the wiring. also get a new touchpad and replace it.
Posted on Feb 18, 2014
My microwave touch pad does not work except the stop/reset button
You probably need to call the manufacturer. Sorry, no other ideas.
Feb 14, 2013 | Microwave Ovens
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    Only certain buttons of microwave oven touch pad work.
    Hi, welcome to Fixya!
    From your question, I suspect the fault is from the control board of the microwave. This is why some buttons on the the touch-pad are not working.
    Have the control board replaced and the buttons that refuse to work will start working again.
    I hope the above is clear. If not, please let me know.
    Regards.
    Nov 17, 2011 | Microwave Ovens
    Microwave won't work - put in food and press START and it beeps and says "PROBE" and nothing comes on. Tried all cancel buttons, even reset the fuse.
    Please check if the pads are working to indicate that the touch pad is outputing data to the processor. If there is no menu selection, clock settings then the pad could have worn off.
    Also check to disconnect the magnetron , the main capacitor and the connections to the main processor board.
    Apr 19, 2011 | Microwave Ovens
    Touchpad is not working
    Hello :
    If touch pad has gotten wet, then allow to dry for several days. Avoid spraying cleaning liquid near touch pad.
    Check for insect infestation. Insects (cockroaches most frequently) will appear under clear surface of touch pad or under readout window; they like the warmth of the circuit boards.
    Place window mesh over vent to keep insects out.
    good luck .
    please rate !
    Mar 29, 2010 | GE Microwave Ovens
    Lights under micro do not turn off all of the time but some of the time. Finger sensitive pad does not register 0, 7, 8.; most of the time.
    sounds like your touch pad is bad. if its under a year old. call for warranty service.if not you may need to order a touch pad. its not too hard to replace. remove power, take tho screws off the top of the micro holding the top vent cover on. remove the vent cover. above the touch pad is a screw, remove that screw and lift the Assembly up and it will tip out. be careful because you don't want to damage any wires. you can label and disconnect the wires to completely remove the Assembly.good luck!
    If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
    Jan 18, 2010 | Samsung Microwave Ovens
    I have a Magic Chef microwave model mco153sf. The
    HI. This is , indeed, an issue within the touch pad circuitry. it is damage, and will require replacement. I have located a replacement touch pad. Use the link below to access the touch pad. You can order the pad on-line, by clicking the link below.
    CLICK HERE
    Dec 23, 2009 | Magic Chef CMV1000B Microwave Oven
    Flashing dispaly of 4 eights, with no response from keypad
    First check all door switches are properly working. If they are ok , the defect may be in the key pad. You need to replace the key pad.
    May 26, 2009 | Sharp R-510HW Microwave Oven
    Button panel does not work or it starts making 'pick-pick' noise
    The touch pad seems faulty, there may be moisture behing the first touch pad film, suggest replacing touch pad as it cannot be fixed, Phil
    May 18, 2009 | Sanyo EM-S9515W Microwave Oven
    Microwave Ovens Logo
    107 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
