Question about Jandy Aqualink Rs4 One Touch Control System Control System
Water temp short
Is this a sensor and where do you find it to replace
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
Water temp sensor on system is connected to the pipe coming from the pump outlet goes to numbers 5 and 6 on long plug on Bezel board if temp sensor is bad on heater it goes into the header where plumbing connects to heater
Posted on Dec 01, 2014
2 Suggested Answers
UglyPoolGuy
  • 46 Answers
SOURCE: Aqualink reads " water temp short " . Is this a
This code menad that the water temperature sensor has gone bad. These will cost around $60-80 retail, unless you buy Jandy OEM, then you will be paying well over a $100.00. But you can also use a Jandy, Goldline, or Pentair sensor and it is a fairly simple repair.
Pentairs Part Number: Model # : 520272 Hayward Gold Line: Model # : GLX-PC-12-KIT Jandy: Model # : 5089
Posted on Dec 08, 2010
Will heater work with jandylink if water temp snsor short
need new temp sensor will not work without
Dec 15, 2014 | Pool & Spa
Tip
Ducati Fault Codes
Engine Fault Codes - Ducati 749/999
To see the fault codes, with the ignition off hold both dash buttons down and turn ignition on.
1.1 TPS Disconnected
1.2 TPS short circuit to earth
2.1 Pressure Sensor short circuit to power supply
2.2 Pressure Sensor shorted to earth
3.1 Water Temp Sensor shorted to power supply
3.2 Water Temp Sensor shorted to earth
4.1 Air Temp Sensor shorted to power supply
4.2 Air Temp Sensor Shorted to earth
5.1 Battery Hi
5.2 Battery Low
10.1 Hor. Coil shorted to power supply
10.2 Hor. Coil shorted to earth
11.1 Ver. Coil shorted to power supply
11.2 Ver. Coil shorted to earth
12.1 Inj1 shorted to power supply
12.2 Inj1 shorted to earth
13.1 Inj2 shorted to power supply
13.2 Inj2 shorted to earth
14.1 Inj3 shorted to power supply
14.2 Inj3 shorted to earth
15.1 Inj4 shorted to power supply
15.2 Inj4 shorted to earth
16.0 Pump Relay
17.1 LH Fan shorted to power supply
17.2 LH Fan shorted to earth
18.1 RH Fan shorted to power supply
18.2 RH Fan shorted to earth
19.1 Starter Solenoid shorted to power supply
19.2 Starter Solenoid shorted to earth
30.0 ROM/Eprom error
34.0 Signal Panel Sensor
36.0 Speed sensor
37.0 Immobiliser (transponder)
37.1 Immobiliser (antenna)
37.2 Immobiliser (instrument panel serial driver)
37.3 Immobiliser (serial cable disconnected)
37.4 Immobiliser (ccm serial drive)
37.5 Immobiliser (key not recognised)
37.6 Immobiliser (ccm program)
38.0 Can Line error
Source http://moto-files.weebly.com/ducati-fault-codes.html
on Dec 20, 2016 | Motorcycles
Tip
Whirlpool stove oven fault codes
F-1 SHorted key pad Recommend to replace control board/keypad<br /> <br /> F-2 Shorted oven oven temp. Recommended to replace oven temp sensor<br /> <br /> F-3 open temp sensor. Recommend replace oven temp sensor<br /> <br /> F-5 check door latch switch.recommend to replace door-latch switch
on Jan 02, 2011 | Kitchen Ranges
999 injection relay tick continuously when turn to on
found on the net
Listed below are the Ducati error codes for the 999/749 series which are very handy to know...
If your stead decides to create an error and then flashes her yellow warning strobe (the EOBD light) then follow these steps....
1) Turn the ignition to 'OFF' (Whilst stationary that is.... )
2) Depress and hold the left hand instrument panel button
3) Turn the ignition to 'ON' whilst still depressing the left hand button
4) You should then see the error codes displayed
5) Make a mental note of the codes and cross reference with the following list.........
ERROR CODES
1.1 = Throttle Position Sensor (TPS) Disconnected
1.2 = Throttle Position Sensor (TPS) short circuit to earth
2.1 = Pressure Sensor short circuit to power supply
2.2 = Pressure Sensor shorted to earth
3.1 = Water Temp Sensor shorted to power supply
3.2 = Water Temp Sensor shorted to earth
4.1 = Air Temp Sensor shorted to power supply
4.2 = Air Temp Sensor Shorted to earth
5.1 = Battery Hi
5.2 = Battery Lo
10.1 = Horizontal Coil shorted to power supply
10.2 = Horizontal Coil shorted to earth
11.1 = Vertical Coil shorted to power supply
11.2 = Vertical Coil shorted to earth
12.1 = Inj1 shorted to power supply
12.2 = Inj1 shorted to earth
13.1 = Inj2 shorted to power supply
13.2 = Inj2 shorted to earth
14.1 = Inj3 shorted to to power supply
14.2 = Inj3 shorted to earth
15.1 = Inj4 shorted to powersupply
15.2 = Inj4 shorted to earth
16.0 = Pump Relay
17.1 = L/H Fan shorted to power supply
17.2 = L/H Fan shorted to earth
18.1 = R/H Fan shorted to power supply
18.2 = R/H Fan shorted to earth
19.1 = Starter Solenoid shorted to power supply
19.2 = Starter Solenoid shorted to earth
30.0 = ROM/Eprom error
34.0 = Signal Panel Sensor
36.0 = Speed sensor
37.0 = Immobiliser (transponder)
37.1 = Immobiliser (antenna)
37.2 = Immobiliser (instrument panel serial driver)
37.3 = Immobiliser (serial cable disconnected)
37.4 = Immobiliser (ccm serial drive)
37.5 = Immobiliser (key not recognised)
37.6 = Can Line error
__________________
May 17, 2014 | 2003 Ducati 999
New heater was left dry for 4 weeks while spa pump was replaced. turned back on with error code Fault-shorted H20 Sensor. is it truly in need of replacement or can it be cleaned after sitting and rusting?
You can put an ohm meter on the two wires of the temp sensor and see how much resistance you get. I can't find the chart right now but you should read about 15,000 ohms at a water temp of 88 degrees. Resistance drops as temp rises. A "short" will give you the same result as just holding the two test leads together.
Having the heater idle for a few weeks should not have affected anything. The temp sensor isn't too hard to change yourself if needed.
Sep 15, 2013 | Jandy Lxi Heater Temperature Sensor...
Replaced water pump thermostat temp sensor but temp gauge read all the way up when car is first started 3100 engine in 1996 monte carlo
For the temp gauge to read at full heat when the engine is cold is an indication of a short in the wire to the sender unit or you have connected the wrong wire to the sensor/sender unit.
Aug 17, 2013 | Chevrolet 2500 Cars & Trucks
My temp gauge in my 2000 galant reads hot as soon as the car is cut on. The car itself is not running hot, what could the problem be?
Check that the wire to the temp sender unit is not shorting out before the sensor As water temp rise so the resistance in the sender unit decreases and the current increases so a short would indicate hot water. REmove the wire and see it any thing happens and if it stays cool then, Replace the sender unit
Mar 07, 2013 | Cars & Trucks
My 2001 Chevy S10 truck 2.2 L the engine is always cold. The temp. is just above 100 degrees and the check engine light is always on. I got the computer read and indicates a faulty thermostat. I replaced...
Are you sure the coolant isn't heating up? I had the same issue once and the problem was i hadn't opened the high point vent on the cooling system. there for no liquid was getting to the sensor ie. it wasn't reading the true temp of the coolant. If that's not it try pulling the sensor out get enough slack in the wiring so you can get the sensor into a small pan of water. put scalding hot/boiling water in the pan have someone watch the guage put the business end of the sensor into the water and see if your temp rises. If not you were ether given the wrong sensor or a defective one.
May 16, 2011 | 2003 Chevrolet S-10
Dec 07, 2010 | Jandy Aqualink Rs4 One Touch Control...
Temperature fluctuation
The water temp sensor is a switch that closes the circuit when the temp reaches a certain level and that switch sends power to the fans. Either your water temp sensor is faulty (always on) or the wiring from the sensor is shorted out.
The easiest fix would be to replace the temp sensor. They are cheap, and replacing it will likely fix the problem. Your local parts store can get you one and show you where it is located on your car.
If it doesn't fix your issue, at least you'll have eliminated that from the problem and can search for the short in the wiring.
If you know basic electrics a simple auto circuit tester (cheap at any auto parts store) or multimeter will help you trace the short. If you're competent with electronics, you can always wire the sensor to the fan independently of the car's wiring harness to workaround the short. Be sure though that you have a workshop manual with a wiring diagram and that you make the correct connections to the switch, fan and the car's 12V power.
I'll bet that replacing the sensor will take care of it though.
Hope this helps.
Dec 25, 2008 | 1993 Subaru Legacy
Jandy Aqualink Rs4 One Touch Control System Control System Logo
131 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
