Question about Insignia Remote Control NS-RC08A11 p/n:90.71V11.004
Remote lights up but does not turn tv on - Insignia Remote Control NS-RC08A11 p/n:90.71V11.004
Tv on standby wont turn on either by remote or buttons on tv
Its not the remote but the set itself, Have it looked at and get an estimate for repair
Dec 05, 2012 | LG MKJ32022813 Remote Control
Sharp remote quit working. Lights turn on, could it be the tv's problem? Ga724wjsa
Another way to verify if the remote is working is use your phone or camera to look at the IR eye of the remote while pressing a button you will be able to see a red light everytime you push the buttons to make sure the remote isnt just faulty. For any Sharp TV do it yourself TV repair call us in Centennial, Colorado.
Jun 02, 2012 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
CANT PROGAM UNIVERSAL REMOTE TO TV
From http://www.ehow.com/how_7158721_connect-remote-tv.html :
  • 1
  • Hold down the program button on the remote control for 3 seconds. This button mighty be displayed on the remote as "PRG." When you have done this, the LED light on the remote control will turn on. The light will remain on for the remainder of the programing process.
  • 2
    Press the "TV" button on the remote control to let the remote know it will be syncing with a TV. Universal remotes have multiple device buttons that let you connect other devices, such as the VCR and DVD player, to the remote. Having the TV properly programed under the "TV" button makes it much easier to switch back and forth from another device to the TV.
  • 3
  • Find the proper codes for the TV you are programing. You will find a link with a list of TV codes in the Resources section below. Input the 3-digit code into the remote and press "Enter." If the code took, the light will turn off and the TV will turn on after pressing the "Power" button. If the light remains on, stand closer to the TV and move any objects that are blocking the signal from the remote to the TV, then start the programing process from Step 1 and continue down the list of codes until it works
    Resources:
    TV Codes: Universal TV Remote Control Codes
    Hope This Helps!
    -Be Sure To Rate MacAppleZoo 100% Or Whatever You Think I Deserve!-
    Sep 12, 2011 | Televison & Video
    Looking for a sky remote control code for beko.
    Hello
    The three digit Sky remote code for Beco TV are:
    514 398 065
    Four digit code is:
    0125
    1* Turn your TV and SkyHD box on and press tv on your remote control.
    2* Hold down select and the red button together until the red light on your remote
    control blinks twice (this is after about two seconds).
    3* Press tv again.
    4* Key in your TV's brand code. The light on your remote control blinks twice.
    5* Press standby on your remote control.
    If your TV switches off, press select.
    The light on your remote control should blink twice.
    If your TV does not switch off, press tv, then press standby.
    Repeat the sequence of pressing tv then standby until the TV switches off,
    then press select.
    If the light blinks three times, your remote control has checked all the possible
    settings for the code you used. Check you have the right code and start again
    at step 1.
    *6 Turn your TV back on and press the tv guide button on your remote control.
    The TV Guide screen appears, meaning the remote control settings have
    been reset.
    Aug 12, 2011 | Televison & Video
    What is the code for LG 37LE4500 TO WORK WITH SKY REMOTE CONTROL
    I also have an LG TV. I used this 4 digit code: 0742.
    TO PROGRAM THE remote USING THE 4 DIGIT CODE:
    1. Turn your TV on.
    2. Press tv on your Sky remote control.
    3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
    4. Press tv on your Sky remote control again.
    5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
    6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
    Mar 12, 2011 | LG Televison & Video
    How do i program tv aND DIRECT TV BOX FROM SCRATCH?
    You need to turn on your television set.
  • On your DirecTV remote, press the "TV" button once.
  • Now, press and hold the "Setup" button until the "TV" light goes off.
  • Enter "991" on your remote control, using the numeric keypad. The "TV" light on the remote should blink twice.
  • Aim your remote at the television and slowly alternate between pressing "TV and "Power" on your remote, until the television set turns off. Once it turns off, press "Setup" on your remote control to lock in the code.
  • To search for codes for other devices and program them into your remote, repeat Steps 1 to 5, but use the appropriate key for your device instead of "TV."
  • Feb 04, 2011 | RCA RCR311B Remote Control
    Need help programming philips universal remote for a sanyo tv
    Here are the codes,0506,0311,0612,0002,0428,0802,0412,0619...Turn TV on. Aim the remote at the TV,Press and hold CODE SEARCH button until light turns red, press TV, the light will blink once and remain on,enter one of the four digit codes, the light will go off, if the light flashes instead of turning off, you will need to try another code until it does, press the POWER button, the TV should turn off..... hope this was helpful...
    Apr 18, 2010 | Philips Universal PH301S Remote Control
    I cannot find my instrution manual. Help!
    Here are the codes, 002,003,004,005,104,105,106,115,205,204,206,213,304,305,316,319,405,502,505,506,519,604,605,705,804,805,903,904,905,906...Turn TV on,aim the remote at the TV,press and hold the code search button until light turns red,press TV,the light will blink once and remain on,enter one of the three digit codes, the light will go off,if the light flashes instead of going off, you need to try another code until it does,aim the remote at TV and press POWER button, the TV should turn off....hope this was helpful...
    Apr 17, 2010 | Philips PM335 Remote Control
    Lost my manual of my Jumbo Universal Remote. I would like to know the 3-digit code to activate my JVC TV, Model I'Art Pro
    Here are the codes, 013,054,055,060,065,067,089. Turn the TV on, aim remote at TV, press and hold the CODE SEARCH button until the light turns red, Press TV button, the light will blink once and remain on, enter one of the three -digit codes, the light will go off, if the light flashes instead of going off, you will need to try another code until you find one that does, aim the remote at the TV, press POWER button, the TV should turn off.........hope this was helpful....
    Apr 17, 2010 | Televison & Video
    How do you tune Sky+ remote into Sony KDL46W5710 Television
    The Sky+ remote should automatically default to Sony TV's. Leave the batteries out for a few minutes and try again. The Code for Sony is 0000.
    Or try this :-
    With TV and sky box on.
    Press the 'TV' button on the remote.
    Hold down the 'select' and the 'red' button (of the four coloured buttons) together, until the red light on the remote blinks twice. (takes 2 seconds)
    Press the 'TV' button again.
    Now enter four zeros, the red light on the remote should blink twice.
    Press the 'standby' button (top right).
    If the TV turns off, then press 'select' and the light should blink twice again, job done.
    If the TV does not turn off then press 'TV' followed by 'standby' again.
    Alternate pressing 'TV' 'Standby' until the TV turns off.
    When it does, finish by pressing 'Select.
    Check the red light on the remote, if it blinks 3 times, then it has run out of options for 0000.
    Dec 19, 2009 | Televison & Video
    Insignia Remote Control NS-RC08A11 p/n:90.71V11.004 Logo
    21 people viewed this question
    Top Insignia Televison & Video Experts
    Jaime Hernandez
    Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
