Question about Canon Photography
Film stuck in on right hand side - Canon Photography
    Master:
  • Canon Master
  • 442 Answers
First, be sure you've pushed the film release button (usually located on the bottom of older film cameras) and then try rewinding. If the film is stuck on the take-up reel of your camera your best bet is to manually unwind the film from the reel and see if it will work properly again. If not then it wasn't a film problem but a mechanical one on the reel.
Posted on Dec 16, 2014
The bottom roll of laminating film will not remove.
most likely, someone has unscrewed the thumbscrews in the right side "collar". Best thing you can do is loosen both thumbscrews on the both collars, push the film on the shaft as far left as you can. then tighten both screws back down as tight as you can by hand. then grab the film and push the entire assembly to the right as it's spring loaded to the right. once it clears the keyed shaft holder on the left, just lift up and out. the right side collar screw should never be loosed. it just causes problems. West Laminating Svcs. 405-324-6092
Sep 28, 2015 | Gbc HeatSeal Ultima 65 Laminating System
My advance lever is stuck o my Ricoh camera. I had a roll of film get stripped in it and took it out in the dark room and developed it but now even with no film in it the lever won't advance. I've looked...
Your camera is in cocked position with shutter fully cocked and that is why you cannot advance the film advance lever. Set the shutter to x position ( on your shutter speed dial on the right hand side and top of your camera ) . The shutter should release and then you should be able to advance the film advance lever.
Oct 18, 2013 | Ricoh KR-30SP 35mm SLR Camera
How do I unload or rewind the film
Not All camera do it the same way.
Some have an electric rewind - usually those that automatically advance the film after each picture. They will have a catch somewhere that lets you open the back - it's normally at the right hand side (as you look at the back) or.. Cameras that you advance the film with a lever under your right thumb usually have a rewind crank at the left hand end of the camera . Generally it is on the top folded into the round thing but sometimes it is on the bottom in a matching place. You unfold the crank so that you can wind the film back into its can. However, You must first operate a little button that will be located in a small recess on the base of the camera - this disengages the wind-on machanism inside the camera so that the film can go the other way. Normally you have to keep this pressed all the time you are winding.
When the film is all in the can you will feel the wind ease off and the noise will change . now you can open the camera. Again this is done in different ways on different cameras, but the commonest is to take the winding crank and pull it upwards as if you are trying to pull it out of the top of the camera. It will come so far than suddenly the back will release and open a short way.
Some cameras have a slider hidden at the right hand end on the side, that looks like a small silver bar that you pull down with your thumb-nail.
Jun 26, 2011 | Canon Photography
How to unload nikon fg 35 mm film
When the last exposure is made, the film advance lever will not move the film to allow another picture to be taken. Turn the camera upside-down; with the lens facing you. Locate a small button in a slight recess in the right-hand side of the bottom of the camera. Press the button in to release the sprocket drive mechanism from the film. Turn the camera right-side up again, and unfold or open the film crank knob from the top most part of left-hand side knob (the one with the ASA settings on it). Return or rewind the film back into the canister by gently turning the crank clockwise until you feel the resistance ease up completely. This indicates the film has been completely rewound and is now protected from light when the back of the camera is opened, next. To open the camera back, pull the crank knob gently up and away from the top of the camera. The back door will open and when the knob is fully extended, *** will be possible to remove the film canister from the camera body. You should do this in subdued light if possible - and return the film canister into the original protective container if available - otherwise, place in a light tight box, bag, etc.
I hope this helps - and good luck!
Nov 02, 2010 | Cameras
FILM ADVANCE/SHUTTER STUCK
Start simple and go from there.
I don't know if you have film in the camera so I'll read the following and choose what works for you.
I will assume the battery is working if applicable.
As stupid as this sounds press the shutter release button. If the shutter is cocked it will hold the advance. I've had people come in with this problem.
Not it?
If the film rewind has been pressed in it will disengage the film advance and stop the shutter mechanism as a result. Open the camera and close the back again resets the release.
If there is film in the camera remove it.
It there are important photos on the film and your rewind is not working use a coat to make a light proof black box. Just turn the sleeves inside out and put the camera in the coat. Wrap it so as it is closed to light. Open the camera remove the film and roll the film back in by hand.
OK so now we have a camera open with no film in it.
Open the back and look just below the shutter. On one side will be a very small "lever". This tells the camera that the film has been advanced and the shutter is cocked. Gently move the lever to the right. It should click. Now try pressing the shutter release.
Note that without film in the camera some cameras will not advance the shutter.
It should clear the problem.
If not something physical in jamming.
The film advance system could be jamming. On the side the film advance is on there will be a plastic "gear" inside the camera. Try moving by hand it should turn. You can reset the shutter this way.
Give this a try.
Hope this is helpful, if it gives you some direction please rate this answer.
Thanks
Mar 14, 2010 | Photography
Film wound on wrong side of camera
It sounds like you have a jam.  When you have finished taking shots and have used all the film, you must press the film-rewind button on the underside of the camera; this does not rewind the film, but allows you to commence the next step.  Once you have done this, flip up the rewind-crank on the top left hand side of the camera. It is situated on top of the film speed dial. turn this clockwise until all the film is back in its cartridge.  You should now be able to open the back of the camera.
I hope you have fun with your t50!
Dec 11, 2008 | Canon EOS-AE-1 35mm SLR Camera
SA-21will not pull film strip into chamber
Put the film in after it is powered up. The unit needs to run through a power-up and calibrate cycle first. Once powered up, the until will feed the film in once it reaches a certain point into the machine.
The unit is supposed to kick the film back out when you close down the scanning software. If your film ever gets stuck try this to get it out. DO NOT force the SA-21 out of the machine with film stuck in it.
Aug 13, 2008 | Nikon COOLSCAN IV ED LS40
Printer making funny noise and print is almost peeling off the page on the right side
Your problem is with the fixing film in the fuser assembly (HP Part #RM1-3044). The brown material you see is the plastic film ripping and peeling off of the hheating element.
Jan 23, 2007 | HP LaserJet 3050 All-In-One Printer
Mis-register
Hi There, 1. Make sure there is no dye film stuck to the print roller. This will cause card mis-registration (you will see feathered edges or a blurry effect. If there is dye film stuck to the print roller peel it off using adhesive tape or similar (the dye film will stick to the tape). You can move the print roller round with your finger quite easily. Then clean with a normal cleaning card. Afterwards check your print start and end position (you may be printing off the end of the card - also snaps the ribbon often!) 2. Make sure the other pinch rollers are really clean. 3. ** Check the warranty status first! *** Remove the right-hand side panel (2 screws on the side, 3 at the back). Check for free play on the card transport stepper motor pulley (there should be none!). Check the belt tension is not too loose (motor is adjustable - loosen 4 screws)). Hold the print roller with your left hand while trying to turn the large plastic pulley. You should feel no play. The grub screw on the pulley can sometimes come loose (1.5mm hex key required). Do NOT try to use a ball ended hex key. This only rounds off the grub screw socket. I hope the above helps! Regards, MC.
Oct 19, 2006 | Magicard Tango 2 Printer
Photography Logo
150 people viewed this question
Top Canon Photography Experts
old marine
old marine
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
