Question about Radio Communications
I cannot connect my cellairis cadence headset to my computer
Vdo m5 bike computer has no speed reading . Cadence reading is fine. I replaced all new batteries. Just can't make it work, sometime display shows transport . Don't know what is that meaning ?
The computer goes into Transport Mode when it detects the bike is moving without the wheel moving (as on a car carrier) so that means the wheel sensor is not working. If you take a magnet and pass it right by the sensor several times and get no cadence count then the wire is broken or the cadence portion of the computer is non-functional. Unless it's the wire and you can fix it you need to buy a new computer.
Aug 18, 2017 | Cadence Cycling
Tip
Choosing Your Wireless Bike Computer
Wireless bike <b>computers</b> are pretty self-explanatory. They consist of a main unit and sensor, which shall inform through radio signals instead of traditional <b>cable transmitter</b>.<br /> <br /> <b>Wireless computers</b> are fairly easy to configure and install. Wireless computers eliminate the tedious task to wind the cable around the brake lines to make an extra length of wire. An experienced mechanic can probably<b> install a wireless computer</b> to less than 5 minutes. A novice user can probably still make the task less than 10 minutes. If your computer has cadence sensor, wireless sensors to get rid of problems with cable routing for long-stay chain without change and brake pipes.<br /> <br /> Some runners prefer to use <b>computers</b> in contexts out of circulation, since they are usually cheaper to replace in an accident. However, the absence of the child in the models reduces the possibility of connecting the sensor to the roots, rocks, brush, etc. .. Suspension forks and create additional obstacles. With the corded models, a pilot should be concerned with changing the length of the fork. wireless sensors allow the holder free travel without worrying about the tight rope or hook.<br /> <br /> When choosing a<b> wireless computer</b>, the set of cycling accessories, it is important to think about riding needs. There are several options with a range of features, technologies and prices to help cloud the decision-making. Riders must think things like screen size, buttons, advanced features such as cadence and heart rate. Big screens make viewing data easier, but the computer mainframe is generally much larger and makes the computer a bit more urgent. There are several options out there for <b>computers</b>. The best option is to visit some local shops and take really using computers.<br /> <br /> bicycle computers Vetta V100 Series provides an excellent opportunity for a cheap but feature-packed wireless bike computer. There are three models in the series, V100 WL2X - Standard V100HR WL2X - includes a heart rate monitor, and V100A WL2X - includes altimeter functions. All three computers include wireless speed and cadence sensor and has features such as high speed, cadence characteristics, formation lap and hours of service. V100 computers scored the best runners in several bars and left their mark in the Tour de France cycling by cycling team USPS.<br />
on Feb 03, 2011 | Computers & Internet
I have an older cat eye computer. Wires. The cadence function stopped working. All other functions are good. I installed a fresh battery, I adjusted the sensor location. Still does not count cadience
Aug 16, 2017 | Cat Eye Cycling
Can you use the Bluetooth headset with the Xbox 360
I use Bluetooth headsets with my Xbox360 but before u can do that u need to purchase the Bluetooth transmitter that plugs into ur unit.
Nov 27, 2014 | Video Game Consoles & Games
How do I wake the cycling computer from a sleep mode?
To wake your computer from its sleeping mode, press any button, spin the wheel and rotate the crank. Doing so will connect the speed and cadence sensors to the computer.
Jan 17, 2013 | Cycling
Sigma BC 1609 Cadence Bicycle Speedometer reads my movement much slower than I am actually going. E.g. moving about 15, reads as 5 mph.
I had the same problem. It is caused because the mount is facing the wrong direction and your computer is swapping speed and cadence. 5 mph would mean 63 RPM of the wheel which probably what your pedal is actually doing. The wheel is actually turning at about 3 times that rate so if you check your cadence it is probably maxing out at 180 even though that wouldn't be possible.
To fix this, just twist your mount 180 degrees on your handlebars or stem and try again. That way the computer is correctly lined up with the mount.
Mar 10, 2012 | Sigma Sport BC 1609 Cadence Wired Computer
I have a cateye strada cadence computer. The wheel sensor is working fine but the cadence sensor isnt detecting anything. The manual says that the magnet must be within 3mm of the sensor but, with the...
I have the same exact issue - all works but not the cadence sensor. I am going to try using some rubber shims or something...wish I had an old innertube to use.
Jan 26, 2010 | Cadence Cat Eye Strada Computer
Cadence does not register on edge 705
This is probably a pairing problem. Device and cadence should be paired. Pairing is often lost when changing battery.
Pairing the Edge 305 and sensors
Once you have installed the Garmin Edge 305 and the cadence sensor they need to be paired. As they communicate wirelessly with each other the Edge needs to connect to each sensor before it can receive input from it.
The initial pairing needs to be done away from other wireless systems this allows the Edge to pick up the sensors it is supposed to be monitoring. This is a little like black magic, but it seems to work quite easily.
The cadence sensor has a small press contact which puts the sensor into pairing mode. The HRM just seemed to connect by itself.
Subsequent pairing is much faster as the Edge 305 seems to remember which sensors it is paired with. If you have problems or need to change one of the sensors then you can use a setup feature to either turn the sensor off or to re-pair it.
Jul 14, 2009 | Garmin EDGE 705
Cannot get my new cadence(WIND)sensor to work. will aparently teach. Any ideas
No reactions to any buttons:
Reset the training computer by pressing all the buttons simultaneously for two seconds until the display fills with digits. Press any button and set the time and date in Basic Settings after the reset. All other settings are saved. Skip the rest of the settings by pressing and holding STOP.
Polar Cadence Sensor W.I.N.D.
To activate the cadence sensor in your training computer, select Settings > Features > Shoes/bikes > Bike
1/2/3 > On > Cadence > On.
Teach new sensor? is displayed.
• If your sensor is already taught, select No.
• To teach a new sensor, make sure that there are no other cadence sensors nearby (40 m/131 ft) and then select Yes.
After selecting Yes, Start test drive is displayed. Rotate the crank a few times to activate the sensor.
The flashing red light indicates that the sensor is activated. Completed is displayed after the
teaching has been finished. The training computer is now ready to receive cadence data.
To return to time mode, press and hold the STOP button.
Good Luck,
Techjoel
May 08, 2009 | Polar Cadence Sensor W.I.N.D
Radio Communications Logo
44 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
