Question about Hasbro Playskool Step Start Walk N Ride
Looking for a replacement part
I'm looking for the red front door that covers the compartment on this toy. Do you know where I can find one?
Battery replacement J-10A
Good Morning Fhaas153
Looking at a J-10 picture on eBay
http://www.ebay.com/itm/VINTAGE-CASIO-J-10-ELECTRONIC-CALCULATOR-8-DIGIT-TESTED-/331587643662 , the picture of the rear says '1.5V battery x 2. Looking at this other shot
http://www.casio-calculator.com/Museum/Calculator/FGHIJ/J-10/Casio-J-10-back.jpg It looks like there is a fairly clear Slide-to-Open Battery door at the top of the rear panel. Given the battery rating at 1.5 Volts and the door size, I'd suspect it'll take either AA or AAA batteries. You should be able to slide the door and look, and most battery compartments will have an indication of the specific cell.
To be sure I'm covering both the what and the how, slide the door open. Remove old batteries if still there. Clean up contacts with a bit of fine steel wool if they are corroded or covered with old battery fuzz. Put new batteries in - negative end towards the coil springs generally. Replace sliding hatch.
Hoping this covers what you're looking for!
D
Dec 09, 2015 | Casio Office Equipment & Supplies
Looking for barbie dream house replacement parts.
barbie dream house replacement parts can be found on amazon, click here and take a look: Amazon com barbie dream house parts. I hope this was helpful. Cheers
Oct 13, 2012 | Toys
Sony kf-ws60s1 front red light flashes 6 times after lamp replacement. Need thermal fuse part number
hello!
your issue has nothing to do with "thermal switch". while you have replaced the lamp, you could lose a piece of plastic hardware, in front of the lamp housing. It pushes auxiliary interlock switch, right under the front of the lamp compartment. If you take lamp out, use flashlight and shine inside. There is a little switch at the bottom. Try to make the lamp housing push it, without breaking anything. you could get "generic" lamp with housing, which is not correct. Anyway, that's the deal. Also: don't forget to install lamp door and turn the handle clockwise! there is another switch. I've seen people who forget to put that door back! Really!
good luck,
Alex.
Mar 06, 2012 | Televison & Video
Where do I insert the batteries on the star wars millenium falcon toy?
Locate the turrent on the top center. Just behind it is the On/Off switch. Behind it are 6 black, round engine-looking pods. That is the top cover. There are two tabs right behind the On/Off switch you push back on to remove the cover. Grab your screwdriver and remove the battery door. Uses 3 "AA" batteries.
Feb 20, 2011 | Hasbro Star Wars E3 Otc Millennium Falcon
None of the controllers will work on my wii, we have changed the batteries but still nothing. We even bought a new controller. What would be wrong with it.
ok you will need to synchronization.Press the power button on the wii conosle to turn it on remove the battery cover on the backof the remote.Press and release the SYNC. button inside the cover.the player leds will blink.Open the fornt door on the wii console press and release the SYNC.button on the inside of the compartment. when the player LED blinking stop connection is complete the LED that is iluminated indicates the player number, THAT IS IT
Let me know if I help you out
Jan 02, 2011 | Nintendo Wii Console
Looking for water filter to be replaced. The red light is on and I can't find filter.
On a Whirlpool you can check the bottom front black vent piece, filter cover looks like a half-moon shaped cover. Its under the freezer side. There is a thumb-sized black push button next to it which will 'eject' the filter. Push on the black button and the filter pops out
Dec 31, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I'd like to disassemble my Fisher Price Laugh & Learn Jumperoo for storage. The ''toy bar'' (red bar in the outline of a barn) doesn't seem to come out. Is there a way to do this? Thanks!
I have the same problem. I did manage to release one side of the toy bar (left side when looking from front) by pressing very firmly on the red plastic tab that's visible underneath, using a metal tool. But on the other side of the bar, the holding tab is hidden by a white plastic cover, which itself is held by 4 white plastic tabs that I couldn't release.
Mar 16, 2010 | Fisher Price Toys
Lost battaries compartment cover
I lost my radio shack sangean 909 battery cover too! where do I get a replacement?
Jan 26, 2010 | Sangean ATS 909 AM/FM/SW Radio
I dont know were my starter is located in my 1994 acura vigor
it should be in the front of the engine hooked to the trany it could be on the back side of the engine it is round looking.
Jun 02, 2009 | 1994 Acura Vigor
Furnace filter on model gmt070-3a...
look in and around where the blower motor is located. there has to be a filter compartment there. probably near the bottom as it looks like an upflow heater. make sure the filter door is closed. it may have a door interlock switch that cuts the burner out if it is not fully closed.
Feb 01, 2008 | Goodman GMS90703BXA Heater
Hasbro Playskool Step Start Walk N Ride Logo
Top Hasbro Toys Experts
thegtw
William McDowell
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
