Question about Kirby Vacuums
Propeller replacement need one
  • 357 Answers
Hoover self propell cable needs replacement
Hi there! We recommend taking the cleaner to a Hoover authorized service center to have the self propelled cable repaired or replaced. Follow the link to locate the nearest service center to you. Service Center Locator
Thanks!
Jun 24, 2014 | Hoover Vacuums
Unit does not self propel
You need to replace the belt that propels the vacuum. This is the belt you need:
Hoover 38528035 Belt
Feb 15, 2010 | Hoover U6616-900 WindTunnel Bagless...
Self propelled feature does not work. I replaced
There is a cable from the handle down to the transmission on this machine that breaks all the time or the cable is mounted to a plastic piece that is broken. That will need to be replaced.
Nov 28, 2009 | Hoover U6476-910 WindTunnel Upright Vacuum...
Self propulsion doesn't work on my upright. Vacuum works fine otherwise
You will need to look @ your owners manual to see where the self propell belt is located i am sure yours is broke and need to replace,- it will not be hard to replace-Lance
Oct 21, 2009 | Hoover Vacuums
No suction
Flip the machine upside down and remove the four screws from the baseplate. Replacement should be fairly self-explanatory from there. If it's a self-propel model, note that the v-belt in the front WILL look loose normally, so it does not usually require replacement.
If you have a self propelled model, the belt you need ends in 035, if it's non self propelled it ends in 033.
Contact me if you need more assistance in changing the belt.
-R
Sep 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Self propell doesn't work. Motor spins and belt burns, brushes do not turn. model Hoover self propelled u6425-900
may be a stripped sprocket/cog or snapped shaft. check and replace as needed.
Sep 03, 2008 | Hoover Vacuums
Install self propelled belt
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=647063
Generic problem for all Vacuums
Posted by wmtp on Jun 04, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Usually the self propelled vacuum have 2 belts and you should replace them both 2 the same time 1st the self propelled belt and then the brushroll belt. Normally you would hook the belt on the pulley side of the brushroll or self propelled unit and then stretch the belt onto the motor pulley side of the motor using a belt puller or a screwdriver with a bend on the end for pulling and or stretching either belt onto the motor pulley. If you have a problem please feel free to contact your local vacuum cleaner dealer.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 04, 2008 | Vacuums
Brush won't turn and self propel doesn't work
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40485&thid=619779
Brush won't turn and self propel doesn't work (by 2 users)
Posted by brucelk on May 24, 2008
I have replaced both the v-belt and the larger belt with Hoover brand belts and the brushes still don't turn properly and the self-propel function doesn't work. It seems that when I lower the handle all the way down toward the floor it works fine, but no one can vacuum this way. Is there an adjustment to belts to tighten them up? Otherwise I have to get it in to the only repair shop in town which is an hour's drive.X
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
1 Other User Has the Same Problem Comment by chartsell, posted on May 29, 2008 I have replaced both the belts as well. I have tightened the screws as someone else as suggested. The brush still will not turn unless you lower the handle almost to the ground. Hello,
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover U6437-900 / U6439-900 Windtunnel Vacuum. It is not so much the belts, the 2 belts are only part of the solution. The average belt change is every 4 to 6 months as a rule and to change them @ the same time. The Hoover Self-Propelled works on when the handle is lower to a comfortable position then the self-propelled drive may just need and adjustment. There is a self-propelled rod that controls the self-propelled feature and it either needs adjustment or replacement or the part that hold it may be broken but either one can be fixed. So feel free to contact your local vacuum cleaner dealer with questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
May 24, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover wind tunnel upright self propelled. U6473-900. Brush does not work. Heard it was a 'brush controller' problem and can be fixed. Please tell me how.
Most likely the flat belt has stretched enough so as to not turn the pulley that in turn turns the brush roll using a V belt. Also there is a small idler wheel, if hook up, then it won't engage the V belt.
May 20, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Replace the belt
Take off the bottom plate, put the new belt on the motor shaft first, then stretch it to go over the pulley, it is hard, but it will stretch to go over it.
Mar 27, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Vacuums Logo
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
