Question about LSI Logic CSB-6 Ultra ATA-100 IDE RAID Controller
CSB-6 Ultra ATA-100 IDE RAID Controller for Windows 2008 server
2 Suggested Answers
  • 747 Answers
SOURCE: I can install this device on windows server 2008
go to computer go system propertys go device manager you will adapter in this with yellow mark on it right click the trouble shoot it.
Posted on Feb 14, 2011
Maxtor ultra 133 raid drivers windows 7
Driver is for Vista but should hopefully for Windows 7. This is a legacy card no further driverswill be added past Vista.
http://firstweb.promise.com/upload/Support/Driver/Ultra133%20TX2%20windows%202.1.0.3%20logo%20driver.rar
Nov 16, 2011 | Maxtor Ultra ATA/133 PCI Adapter Card...
Need win 7 drivers for SD SIL680-Raid card
try the vista driver it should work ok
32 bit driver is here http://it.us.syba.com/bin/silicon_image/sil680/SD-ATA133I-VISTA-32bit.zip
64 bit driver is here http://it.us.syba.com/bin/silicon_image/sil680/SD-ATA133I-VISTA-64bit.zip
if you found this useful please vote for me
Apr 22, 2011 | SYBA SD-SIL680-RAID Ultra ATA 100/133 IDE...
Have an SYBA PCI IDE RAIDx2 and very urgent need the driver for Windos 7 Ultimate x64. The VIA site is out of service..!!
hi I found this link below for all syba driver updates and downloads, hope this helps.
http://it.us.syba.com/support_download/download/index.html
Feb 13, 2011 | SYBA SD-SIL680-RAID Ultra ATA 100/133 IDE...
Enable RAID system
use this guide, this is fo the embedded sata raid controller that comes standar with the ml150 g5.
Enabling SATA RAID functionality in the BIOS Setup Utility: 1.Boot the server, and then press F10 to enter the ROM-Based Setup Utility (RBSU).
2.Go to the advanced tab.
3.Enter the IDE configuration or hard disk configuration.
4.Change the ATA/IDE configuration to enhanced or SATA controller 2 enhanced (if not available then use enabled mode).
5.Configure SATA as RAID or configure controller 1 as RAID.
6.F10 to save and exit.
7.Reboot the server.
8.During post f8 will now show up for the embedded SATA set up.
•Creating the RAID volume.
1.Enter the embedded SATA setup by pressing f8 during post.
2.Enter the array configuration utility.
3.Enter create array.
4.Create the raid volume as desired.
5.Save and exit.
i hope it helps you!!!
Aug 11, 2010 | HP ProLiant ML150 G5 Server
NEED DRIVERS LOST DISK SD-SIL680-RAID
you can download from web site of board if you can use the public libray system jim
Mar 25, 2010 | SYBA SD-SIL680-RAID Ultra ATA 100/133 IDE...
Silicon Image Ultra-133 Medley ATA (Maxtor Ultra ATA/133 PCI Card
No I do not think there is unfortunaely. Contact Maxtor and ask if they are going to support it under Windows 7?
Jan 21, 2010 | Maxtor Ultra ATA/133 PCI Adapter Card...
I cannot find a driver anywhere for my belkin f5u098 ide raid controller.
The drivers for this ATA Controller Card are resident in Windows, just like the Motherboard's onboard ATA/IDE Controller. If they don't autodetect and load make sure you are running at least Service Pack 2 for Windows XP and SP4 for Win 2000. Vista and later will have resident drivers.
Sep 23, 2009 | Belkin Ultra ATA/133 PCI (f5u098) ATA...
Who is the mother board manufature for sy -p41 845pe? what type of cpu does sy -p41 845pe suport and speed range? the type of module, max support capacity and speed ranges? the type of chipsets? the type...
Processors
  • Supports all Socket 478 CPUs (400FSB & 533FSB)
Chipset
  • North bridge: Intel I845PE MCH
  • South bridge: Intel ICH4
System Memory
  • 3 x 184-pin DDR SDRAM
  • DDR200 / DDR266 / DDR333 support @ 2.5v
  • 3GB maximum system RAM
Slots
  • AGP slot, 4x AGP compliant (1.5v support only)
  • 6 x 32-bit PCI 33MHz slots
On-board peripherals - I/O
  • 1 floppy port supports 2 FDD
  • 3 Audio Jacks for the CMI9738 sound chipset
  • CMI9738 6-channel sound
  • Davicom 10/100 LAN (10/100 Mbit/s)
  • 2 USB2.0 ports and a further 4 available via headers
  • PS/2 ports
On-board IDE
  • An IDE controller on the ICH4 chipset provides IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA/100/66/ operation modes
  • Highpoint HPT371 RAID single-channel ATA133 RAID controller
  • Ultra DMA/ATA133, 100, 66, 33 operation modes
  • Supports up to 2 hard drives
  • Serial ATA support via the Marvell 88I8030 single-ATA bridge
  • Supports 1 S-ATA drive
BIOS & Voltages
  • FSB speeds of 100Mhz - 255Mhz (quad-pumped)
  • 1.1 - 1.85v Vcore adjustable in 0.025v increments
  • 2.5v - 2.8v Vmem adjustable in 0.1v increments
  • 1.5v - 1.8v VAGP adjustment
  • Fix AGP/PCI speeds and variable settings
Jan 22, 2009 | Soyo SY-P4I 845PE Motherboard
Hello, I have a PCI Ultra Ata/133 Dual IDE card. I have two Ide devices hooked to it. Everytime I hook it up in the system My regular Motherboard IDE says can't be read, reboot. I am trying to get not Raid...
Sounds like the system is trying to boot from the drives attached to the controller. Go into your setup and make sure the system is set to boot from the proper drive.
Jan 12, 2009 | Maxtor Ultra ATA/133 PCI Adapter Card...
Mortherboard
CPU:
Supports Intel Pentium 4 Socket 478 processors with 800/533/400 MHz FSB
Supports Intel Hyper-Threading Technology Chipset: Intel 865PE / ICH5-R
Supports Dual Channel DDR 400 Memory
Supports Advanced Configuration and Power Management Interface (ACPI) Memory: Six 184-pin DIMM sockets
Supports Single/Dual Channel DDR 400 memory (Max. 4GB). Audio: High quality 6-channel AC'97 audio with S/P-DIF function with JAck Sensing IDE/SCSI: Dual Ultra DMA 66/100 IDE controllers integrated in ICH5R- up to four Ultra ATA drives
Serial ATA/150 controller integrated in ICH5R- Up to 150MB/sec transfer speeds
2 channels Serial ATA 150MB/s data transfer rate via Silicon Image PCI controller
GigaRAID IDE RAID Controller I/O Connectors: PS/2 Keyboard and mouse, 1 x Parallel, 2 x Serial, 4+4 x USB2.0, 1 x RJ45, 1 x Audio Expansion Slots: 1 x AGP (3.0) , 5 x PCI (2.3), 1 x DPS Additional Features: GIGABYTE Patented Technology Dual Power System 2 (DPS 2)
GIGABYTE Xpress3 Series Software
from the above configuration for the board you can see that it supports up to 4GB ddr max
hope this helps pls appreciate by rating as fixyaa
Oct 05, 2008 | Intel Motherboard
Computers & Internet Logo
85 people viewed this question
Top LSI Logic Computers & Internet Experts
David Payne
David Payne
Are you a LSI Logic Computer and Internet Expert? Answer questions, earn points and help others
