Question about Denon DHT-1513BA Home Theater System
Subwoofer not working
The sub is connected but isn't doing anything. I've checked all connections and the power light on the back isn't coming on. The system came with a Boston Acoustics MCS 160 sub.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 17 Answers
There may be an internal fuse that's blown. I'd take it to a repair facility and have them check it. Could also have a bad connection inside. Good luck!
Posted on Oct 11, 2014
I have a 2005 Mitsubishi Eclipse with the Infinity high end stock radio installed, which has a 200 watt amp under the seats. The head unit does does not have direct speaker outputs. The head is connected...
I am going to refer you to the live help
at crutcfield.com audio
They can give you ideas on compatible equipment and designs that will achieve your desires without the OBVIOUS overlad/mismatch.
Your search for comparison returned these articles
Free factory (usa market) wiring diagrams
BBB Industries Premium Alternators Starters Power Steering Products
Mar 11, 2017 | Infinity BASSLINK Car Subwoofer
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Jun 13, 2011 | Pioneer VSX-81TXV Receiver
My jamo sub 200 & pioneer vsx517 receiver is not working properly
What do you mean that it sometimes doesn't work? It doesn't power on automatically?
Check settings of your receiver - if it has subwoofer output enables and if low frequencies from all channels are directed also to the SUB. By default only the LFE channel (.1) of 5.1 signal input is fed to the subwoofer. So Sub will work in this case only when you listen to 5.1 signal (DVD movie for example), but for radio or stereo music, only front speakers are used. By configuring this bass redirect, you can use subwoofer for all signal types.
Feb 08, 2010 | Jamo SUB 200 Subwoofer
I am trying to hook up a powered sub woofer to a yamaha rx-v461 and i dont know what cables go where on the back of the sub there are two speaker ports and there are two plug ins but each speaker port has...
Your subwoofer probably has both high-power inputs and "normal"low inputs. The first are for receivers, which don't have link-level output for sub, so they are able to take already amplified signal as input.
You need to use link-level input of your sub and connect it to subwoofer-output of your receiver. The output is marked as OUTPUT - Subwoofer and is black-color RCA plug (don't confuse with subwoofer INPUT under MULTI CH INPUT).
Receiver has only mono output for subwoofer. If your sub has stereo input (white/red RCA plugs), connect just the left channel to the receiver, it will still work.
Don't connect anything to the speaker output on the sub, you don't need that.
Sep 28, 2009 | Yamaha RX-V461 AV Receiver
Connection of a subwoofer to Yamaha ZX-V490
Get a powered sub-woofer that has speaker level inputs, then run your front speaker wires into the sub-woofers speaker level input and then run a set of speaker wires from the sub-woofers speaker wire output to your front speakers. This is a common way to use a sub-woofer with a receiver that doesn't have a sub-woofer output.
Most powered sub-woofers have these connections, just check it out first before you buy one. They look like speaker jacks on the back of the receiver.
Let me know if you have any other questions.
Jan 02, 2009 | Audio Players & Recorders
The lights are off
Do you have a 12 volt power running to the lighting plug? That enclosure requires a seperate 12 volt power line in order to make the lights come on.
Jul 16, 2008 | Dual XINBP-210 Car Subwoofer
Vibe cbr1 subwoofer
Might not be eathed properly. Check the earth on the battery as well. Theres more juice goin through there now so it might need a bigger earth or ground.
Jan 08, 2008 | Vibe CBR10 Car Subwoofer
No Power :( NEED HELP
Check the connection with the subs. See if all wires are connected or check for any break in the wire. Also make sure that the RCA's are connected to the subwoofer output at the back of your deck. Also check setting on your AMP.
Nov 30, 2007 | Nitro BMW-481 Car Audio Amplifier
Bose Acoustimass Subwoofer not working; front/center are working
Ok, have you tryed to unplug all of the wires from the sub, including the power wire from the wall. Install of the speaker wires to the sub, and plug back in the sub. Also what are the numbers on the speakers and the sub.
Jun 10, 2007 | Onkyo TX-SV525 Receiver
Denon DHT-1513BA Home Theater System Logo
151 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
