Question about Logitech MX1000 Laser Cordless (097855023933) Mouse
Logitech mx1000 Not charging.
HI I recently bought a logitech mouse mx1000. When I put it to charge, the leds should start to imcremtingly go 1 green, then 2 green, and so on. But instead. After to sequences of green, it starts to blink red. Is there a way to reset or self test the mouse.
  • 5 more comments
  • Anonymous Dec 06, 2007
    I have an MX Laser (basically the same thing).
    Same problem. It worked for maybe six months.
    Now it's not charging anymore....
    The charger is plugged in but when I set the mouse on it to be recharged the green lights shut off and it just sits there. I can't tell if it is recharging or not.
  • pahe Dec 08, 2007
    Same have happaend to big time tried to find a solution at logitechs site but no luck there. Last logitech mouse for me...
  • RJ1956 Feb 15, 2008
    When I place the mouse on the charger, lower light will blink a couple times, then just go out. System Tray always indicates Battery Low for mouse. Have had it on the charger for two days now.
  • kuhnass7 Jun 30, 2008
    I called 6 months ago. They said they were sending a replacement, which I never received. When I charge my mouse a few green lights flash then it goes to red. I have tried every that was recommended. I have been putting up with charging twice a day.
  • Anonymous Aug 18, 2008
    This is a really good mouse. I have had it 3 years no problems until it stopped charging. I found the website that shows how to replace the batter -
    And I bought a battery on ebay and replaced it. It worked great and already had charge. Then I put it in the cradle to charge and it did not charge - no lights. It is the charger not the battery. And nothing I can find to do about that.
    Luckily my office has a similar (bluetooth version) mouse so I can charge it there. Just wish I had checked before replacing the battery.
  • Anonymous Sep 03, 2008
    Hi, My Logitech does the same, it worked well for a couple of months and recently started acting up. It goes on charge, but after a while the bottom LED start flashing red. I found that the unit can be charged if you leave it on the charger for short periods at a time.
I had the same problem with the mouse MX1000 not charging when it is on its charger.
Then, I realized that I forgot to plug the adapter for the charger - this charger is not taking its power from the USB port but from an external charger!
Once I plugged the charger, the mouse recharged without any problem.
I hope this helps.
This mouse is really great, once this question of recharge is solved.
Posted on Mar 24, 2008
I had a similar issue where the mouse would not charge unless it was oriented just right in the charger. I found that cleaning the contacts with fine grit sandpaper did the job.
Posted on Jul 01, 2009
I had the same problem. I solved the issue by cleaning the metal contacts. Try cleaning it with alcohol!
Posted on Jul 29, 2008
Mine was solved as simply as cleaning the mouse "feet" the little pads underneath the mouse. The slightest build up seemed to stop the contacts between the mouse and recharger from coming together and allowing the mouse to recharge. Two years old and still running strong.
Posted on Jul 27, 2008
Ok, Logitech maybe does not suck that much...
Two times have the mouse stopped the lights does not show either red or green. Both times this has happend after the mouse has discharged completly.
Solution the first time was to reset the mouse and control station, and then it continued to work.
Solution the second time was to replace the charger wich I found was broken after trying another charger.
Logitech replaced the charger on the warranty.
Thank you Logitech!
Posted on Dec 29, 2007
  • 166 Answers
My thoughts on the battery lights going red when it tries to charge is that the battery is somehow in wrong.. or grounding to itself.. or theres some internal circuitry problem. The only option with hope of fixing is if it's a battery issue... here was my solution to that
as for setting the mouse on the charger and the lights not being on.. the only time I have seen that occur is when the mouse's on/off switch is set to off...
unfortunately a lot of these things I don't know how to make up from down about them unless the object is in my hands
It has stopped working; I can see the cursor on the screen but there's no response. I have rebooted, but it has made no difference.
I have the same problem. It worked fine for over 7 years now. Yesterday I put it into the charging device after I switched off the Mouse. Started to charge. In the moring I took it off and slide the Off button to On. The battery indicator shows full. Windows 7 recognize it but no mouse movement. I tryied 2 different computers (both with XP) and the mouse is recognized but not working. I tryied to look into the laser lens but no red light there.... I also tryied to put it into charghing the Red Status Lid for 1 second and after it goes all green.
What to do???
Oct 25, 2010 | Logitech MX1000 Laser Cordless...
Recharger doesn't recharge
mcdevito75 here, The batteries in the mouse could be going bad, old.
Jun 29, 2010 | Logitech MX1000 Laser Cordless...
Docking station for MX1000 Laser mouse not working
That docking station has a lithium-ion battery in it that supposedly never needs replacing. I'm wondering if the battery did go out on it and needs to be replaced. If there is now way to get inside of the docking station then you will need to get another mouse, cause you can't just get the docking station.
May 27, 2010 | Logitech MX1000 Laser Cordless...
I cant open the mouse to get to the battery.
Please see the link it has a excellent guide
Please can i ask that you leave feedback and vote if this has been useful
Feb 10, 2010 | Logitech MX1000 Laser Cordless...
Strange, I just left logitech page for MX 1000 Laser Cordless Mouse. All they sell is the AC Adapter. Thought that was odd.
Their not selling replacement batterys, just the AC adapter.
Click this link:
If you scroll down to the bottom of the page & look to the right there is a toll free No# you can call.
Still find it strange that logitech sells the AC adapter & not the battery. Make you think your battery is good & the adapter is bad.
Good Luck & kind Regards.
& please vote.
Feb 24, 2008 | Logitech Cordless Mouse
Charger no longer charges
Clean the Contacts with an eraser, fine steel wool or light sand paper.
Feb 18, 2008 | Logitech MX1000 Laser Cordless...
No software disk.
Go to logitech website and download current drivers.
Nov 04, 2007 | Logitech MX1000 Laser Cordless...
Laser Mouse MX 1000 By logitech
Pretty much I cannibalized a pack of battery charging adapter plates, soldered the three wires to them, trimmed & bent them a little.. and then epoxied them down to the battery hold-down in their appropriate places. A little trimming was done on the plastic so the contacts could reach in far enough without obstruction.
After having the mouse sit around useless without a working battery in it.. for months, which definitely irritated me... I looked up 3.7V li-ion batteries and came across the "klic-5001 battery" (google it) and ordered two. The first one I destroyed trying to solder the wires directly to the battery contacts.. which just ruined all the internal li-ion battery components(i.e. DO NOT TRY DOING THAT)... the second battery, which I never tampered with whatsoever, is connected to the mouse via the contacts I described above. The klic-5001 batteries by the way do fit very well in the hold-down meant for the original battery.
End result: one, exceptionally well working MX1000 mouse which I can replace the rechargeable battery inside anytime it begins to get to aged and not working so well... ^_^ It charges as normal and the battery monitoring works like nothing ever changed.
Logitech MX1000 Laser Cordless (097855023933) Mouse Logo
4,562 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
