Question about Toshiba TLP-ET1 Multimedia Projector
What lead to use?
What lead should i purchase with connect an HDMI connection currently the unit hasn't got an HDMI plug/adaptor. only computer pin, scart, 3 pin Video.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
To buy a HDMI-VGA adaptor (a adaptor adjust HDMI to VGA)
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Posted on Feb 22, 2014
How do I connect my galaxy s5 to my Samsung flat screen tv which has usb,hdmi, av cable etc. ?? I am trying to watch videos off my phone from my gallery
This is easy. All you need is a HDMI adaptor for the S5 .you will find it on Amazon .when you get it plug in the usb into your you then plug a HDMI lead into the HDMI socket then get the lead for charging your phone and plug that into the usb socket on the adaptor then you plug the adaptor to the mains. . Don't forget to connect the other end of the HDMI Lead to the TV. I have one for my Galaxy S3. They do work but you have to get the right one for the phone . I don't know if the one for the S3 will be ok but it mighy work
Mar 02, 2015 | Samsung Televison & Video
For my 50v500 tv built in 2004 is there an HDMI cable or adaptor to connect for signal?
If there is a socket at its back marked as HDMI, the set should have capability to receive HDMI signals, provided the HDMI firmware has been installed to it successfully. You can connect it with an HDMI cable, with any other external equipment having HDMI output, and select the TVs' input to HDMI.
Electro help
Jul 03, 2014 | Hitachi 50V500 50 in. HD-Ready LCD...
What lead should purchase
Feb 15, 2014 | Toshiba TLP-ET1 Multimedia Projector
How can I tell if a "LG ultra slim innovation" monitor is digital or analogue? Currently can't connect bc I need to purchase a splitter and adaptor for my digital PC
If it uses a VGA cable to connect to the PC, it's an analog. If it uses a DVI, it can be an analog or digital or both. If it uses an HDMI cable, it is digital (video and audio combined).
Feb 13, 2011 | LG Electronics 19 Ultra Slim LCD Monitor
I have a Casiotone MT70 made in 1984. How do I check the polarity as I need to get an AC Adaptor and don't want to damage the keyboard?
Here is how you might check the polarity of a 7.5 volt DC replacement adapter:
Put the 5 batteries into the unit and verify operation. NOW using a DC voltmeter measure the voltage from battery negative and meter negative connected and meter positive to the pin on the power jack. IF you see 7.5 volts positive, then the pin is the positive lead for the adapter.
If you see zero, then continue testing.
With the 5 batteries inserted, connect the positive meter lead to the positive of the stack of batteries. Now touch the negative meter lead to the pin.
If there is 7.5 volts there, then the pin is the negative lead for the adapter.
READ THESE INSTRUCTIONS CAREFULLY.
USUALLY the jack has a contact that disconnects the batteery when the plug with sleeve is inserted.. We are testing the jack without inserting a plug here so the plug should HAVE THE BATTERY VOLTAGE with correct polarity on the pin.
Oct 07, 2009 | Casio Music
Where do i plug the different leads in the back of my tv i havn,t got a yellow port for the yellow connecter
What sort of tv do you have, is it new? If its new it may well have an Hdmi connection which gives you the sweetest graphics....
If your tv is older you probs have a scart connection, the yellow lead carries the video signal, some tv's have three little socket that the red yellow and white leads plug into if you cant find anywhere to plug it in you will need one of these , a scart adaptor
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=120439215212&category=11319&refid=store
(thats just an example of what one looks like, you can buy them all over)
THe red white and yellow cables plug into the scart adaptor which usually plugs in the back of your tv, done
Jul 29, 2009 | Microsoft Xbox 360 Console
Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
Jan 13, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
I need to know the polarity of my Hp Pavilion F1703 monitor as I have just brought a new power adaptor and before I connect up to the mains it says make sure you insert the adaptor the correct way round...
If the monitor does not have a symbol (similar to the letter 'C' with a dot in the middle), the cheapest digital multimeter can be used on the 'diode' or 'continuity' setting to check the input.
If the meter reads between 600 and 900, you are measuring the forward voltage drop of a protective diode.  Any other reading will mean that the positive probe of the meter is on the positive part of the connector.     i.e. If you are placing the positive meter lead on the center pin and the negative on the shell and it reads 600-900, then the power supply needs to have the negative applied to the center pin and the positive on the shell. If the negative lead is held on the center pin and the positive on the shell and the reading is 600-900 then the center pin is the positive input and the shell the negative.
The readings shown above mean that you are measuring the forward voltage drop of a diode meant to protect the unit against improper polarization and it will probably either die or ruin the adaptor if misapplying the polarity.
You can buy such a meter at electronics or auto parts stores for under $20 US.
Jan 11, 2009 | HP Pavilion F1703 17" LCD Monitor
Toshiba TLP-ET1 Multimedia Projector Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
