GE washer model PTWN8050M0WW drive shaft
I need just the drive shaft it broke where do I call GE for parts, dealers only sell a whole kit which I don't need, just need driveshaft
5 Suggested Answers
  • 351 Answers
SOURCE: Can't locate stacking kit for HE2 Plus Washer and HE2 Dryer
more of the model number would help, but i can get them parts for you at www.whirlpoolpartssurplus.com feel free to give us a call
Posted on Jun 23, 2009
  • 53 Answers
SOURCE: my amana model ALW460DAW washing machine is
Amana are known for there triple lip seals to leak. Replace the whole kit and it will last a little longer.
Posted on Sep 25, 2009
Testimonial: "the suggestion was helpful, it will save me from doing the job twice."
  • 44 Answers
SOURCE: There is a part between the motor and the cage
This is a motor coupler. 5 dollars on ebay or 20.00 at an appliance parts store. Repair it yourself and save big.
Rich
Western Appliance Repair Meridian
Posted on Nov 19, 2010
  • 1010 Answers
SOURCE: Need to purchase this part ASAP tried Samsung try don't sell parts where can I get one
Did you tried the Samsung web - site? If not try the E-bay
Posted on Mar 23, 2013
The handle on my sp714 filter top will not turn freely? any idea what is causing this
Either the 'bearing' under the handle is broke (white PVC ring under the handle) and/or the stem seal is gummed up. Note the orientation of the handle to the diffuser once you remove the top of the valve and then drift out the pin holding all this together. Once apart drive out the stem and inspect all the pieces. You can buy a go-kit for the valve with has all the seals and the ring. If the spring or the stainless steel washers are broke those are available separtely. If the whole works is a mess you can also buy a replacement lid/handle/key assembly.
Your go kit is #10
We sell them for $23.49 + tax and UPS or mail if required. No tax outside of Michigan.
A whole new valve is #SP0714T, but only the top portion would be needed; part #SPX0714BA for $76.90 + tax and UPS or mail.
John
Jun 21, 2011 | Hayward SAND FILTER, PRO SERIES
The metal tub has come loose within the housing. It was making a terrible noise. I looked inside the door and the stainless steel drum is disengaged. The rubber gasket and all is fine. Model #...
Two possibilities, one that the drum broke off of the supporting shaft--very expensive part (but could possibly be welded) and a complete tear-down to fix. The second is that the main bearing just behind the drum is bad. You can replace the bearing--go to a bearing supply house with the old one--cost less than $20, plus full tear-down to remove and replace. We went the bearing route and years later is still working well. If you try to buy parts from GE, they want to sell you the whole outer drum assembly for many penny.
Sep 18, 2009 | Washing Machines
Worm pin on yard machine cultivator broke, don't need the whole drive shaft, where can I get just the pin?
Go to... http://www.buymtdonline.com/webapp/wcs/stores/servlet/FindingYourPart_10101_19502_-1 click on Option 1, choose your brand (Yard Machines), and enter your model # then search for your part. If it is available there, you can order it form any MTD dealer or order it online.
May 17, 2009 | Yard Machines Cultivator
Front right half shaft to short
Go kick who ever installed your lift for not doing it right. The front differential will have to be dropped the amount of the lift to make the axles work. You may have to install a slightly longer front drive shaft also.
Jan 06, 2009 | 2000 Chevrolet 3500
Steering
Hello;
You need to check all your mounting points in the steering. Also check your tie rod ends and the u-joints to the rack and pinion.
Dec 08, 2008 | 1994 Pontiac Grand Prix
Wheel in Hoover SpinSrub turbine broke
Sorry, you will not find that one part available for sale. You will need the assembly from the manufacturer, or may check online sales/auctions.
Nov 20, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
