Question about Washburn D10sbc Acoustic Guitar
Acoustic guitar saddle for a yamaha fg 410 12a
I'm looking for a saddle for an acoustic 12 string yamaha fg 410 12a
4 Suggested Answers
SOURCE: Acoustic Guitar - Poor Sound Quality/Tone
might just be the pickups and their age. or a faulty cable
Posted on Apr 02, 2009
  • 10 Answers
SOURCE: Both the E and A strings
The neck may require adjustment, but would recommend taking it to a luthier or using a guide like raeguitars to talk you through it. Depending where it is on the fretboard that buzzes, the nut may require replacement/adjustment. I've had all these problems in the past and the above tutorial helped me fix all of them.
Posted on Nov 30, 2009
  • 5603 Answers
SOURCE: I need to replace a broken string on my Washburn
Try this site:
http://www.frets.com/fretspages/Musician/Guitar/Setup/SteelStrings/Stringing/ststringing1.html
Posted on Dec 28, 2009
Which are the best strings for Yamaha fg 300A guitar?
How do you play? Strummer, finger style or power chord.
Next question, how deep is your pocket?
I prefer Martin Acoustic 80/20 Bronze 12s but D'Addario EXPs are as good. If you are a light player try 11s and for a heavy player 13s.
Feb 25, 2017 | Yamaha Music
I have a Yamaha 12 string fg230 red label,575925 .what year was it made?
here is Yamaha 's Serial Number Wizard site. Yamaha Corporation of America
Also check out here..this is even better
Serial Number Chart For Acoustic and Classical Guitars
But in looking your number up I cant find a reasonable explanation. No letters...and there are 6 digit numerical numbers but they dont match yamaha's codes...I would call yamaha and talk to a tech at 1 (714) 522-9000 Good luck
Feb 26, 2015 | Yamaha Music
High action martin java mahogany 00x1
To lower the action on an acoustic guitar:
Usually just the saddle needs reducing.
1. Remove strings (or you may be able to just loosen them). Remove saddle, sand down the bottom a little at a time. Restring and check action.
The action can be set as low as poss without any fret buzzing or note choking on all strings and on all frets.
2. Repeat 1
If the action remains too high then there are other techniques.
Later ...
Jan 09, 2014 | Martin Guitars 00X1 Java Mahogany Guitar...
The D string on my new J-45 standard sounds unmusical , as if there are no rich overtones . I can tune the string with my electronic tuner but it never sounds musical. I think it has Gibson Premium...
Hi. Your guitar may not be intonated properly. You might want to try to level and balance the height and strings all throughout the neck. The level at the rear half (close to the soundhole) can be slightly higher than the front half (near the headstock). This can be done be adjusting the truss rod, nut and/or saddle.
Note: You may want to get a guitar luthier to do the trussrod, nut and saddle adjustments as these are very delicate procedures.
May 13, 2011 | Gibson Guitar Gibson SAG MB11 Masterbuilt...
I've got Takamine JJ 325 My problem is backround noise - What can i do ?
Acoustic guitars pickup noise almost like a microphone. You have to prevent the sound from reaching the guitar or get a solid body guitar.
Apr 11, 2011 | Takamine JJ325SRC-12 John Jorgenson...
My new Takemine cannot be tuned as the strings are laying flat on the 15th fret and just buzz out
Take it back to the shop where you bought it and ask them to set it up properly for you. It's an expensive guitar it should be supplied correctly set up.
Feb 22, 2011 | Takamine EG523SC12 Cutaway 12-String...
Apr 02, 2009 | Washburn Music
Strings are very far away from the last frets on the neck...
Sometimes the truss rod (nut you are referring to) will do the trick. The truss rod runs under the fingerboard and allows you to give the neck relief or tension. Some truss rods are dual action but I'm guessing yours is designed simply to give basic relief of the neck. I would make sure the truss rod is adjusted properly before sanding down the saddle. If you sight down the neck you should be able to see the relief in the neck - just use the string as your straight-edge. Most guitars need a slight amount of relief but higher-end guitars can be almost straight (better fretwork.) Once the neck has been adjusted correctly you can move forward with the setup.
Make sure the nut is also the proper height. If the nut is too low (1mm height between bottom of string and first fret) you should get it replaced by someone capable of doing such a thing. If the nut height is okay I would suggest moving forward cautiously by sanding the bottom of the saddle. Make sure this is done patiently and carefully as it can drastically change the sound and playability of the guitar. Hardly any material needs to be taken off to lower the action just a little. Error on the side of not-enough than too much. Make sure the bottom of the saddle remains flat! If the bottom isn't flat the guitar can sound horrible and if there is an undersaddle pickup it might not pick up evenly. The easiest way to do so is to tape some sandpaper rough side up on a flat surface (just don't pick something like mom's heirloom or something important in case it gets scratched.
If you'd like more detail check out http://www.fretnotguitarrepair.com/Repairs2.htm
Good Luck!
Nov 15, 2008 | Epiphone Aj-100 Acoustic Guitar
Washburn D10sbc Acoustic Guitar Logo
54 people viewed this question
Top Washburn Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Sock Puppet
Are you a Washburn Music Expert? Answer questions, earn points and help others
