Question about ASUS VS197D-P 18.5 inch Widescreen 5ms 50000000:1 LED LCD Monitor
NO VGA SIGNAL
I just finish my new pc build for the first time then i was excited to connect to my first new monitor ASUS VS197D then after i connect that i turn the monitor and my build pc then it said NO VGA Signal..
  • 4 Answers
SOURCE: NO SIGNAL PROBLEM
Please check whether the monitor is set to the correct settings. If you feel its incorrect, most LCD/TFT monitors come with an auto set up button which will restore the display to one that usually works. In case it still doesnt work, you might need to connect your pc to a different monitor and check the display settings. You could also try to download the drivers for this monitor and then re-connect the monitor and see if it works.
Posted on Jun 02, 2009
  • 732 Answers
SOURCE: i have an asus LCD monitor...with a docking
laura_vangun, Make sure that ALL the connection points are clean and dust free. also check to see if any gold contacts are bent or broken or have been pushed further into the plastic body of the connectors. (all the connector pins should be same height) If problem persists then try connecting ASUS to KNOWN GOOD desktop pc to see if it still won't display an image of the desktop. Also tell me AGE and or approximate total "on" hours of use this unit has on it. Is it still under warranty? What EXACTLY do you see or hear when you push the "ON/OFF" button to start(power-up) your ASUS unit? Do a comment to your original post and I will try to be of further assistance. 12fixlouie on fixya Bye for now.
Posted on Oct 27, 2009
holmes3804
  • 107 Answers
SOURCE: I just bought a refurbished asus bp003 c2q q8300
You might try going into the computer's BIOS / Setup and set the video settings there. I'm not familiar with Asus, but it should tell you upon boot-up which key to press to get into Setup. That's assuming this model can handle HDMI.
Posted on Feb 15, 2010
  • 5 Answers
SOURCE: asus monitor vw224u stopped working, found was
Try pressing the S/A button to change input sources.(the button on the far left on the front of the monitor) Chances are the cable got unplugged, then the monitor when into analog mode and its now stuck there, because many monitors default to analog.
Posted on Feb 28, 2011
SOURCE: why does my asus monitor always read "no signal".
nah that happens with me sometimes..
have you connect the cable properly?
if that still can't make it works, first turn on your PC and monitor..
then plug off the cable that power them, so that your computer and monitor will suddenly off..
plug it on again, then your monitor will work again..
that works on mine cause my CPU is too old and had a power problem..
Posted on May 07, 2011
I connected up vga and HDMI cables and power, etc to ASUS desktop. All inputs are without signal. If I set monitor for vga, it says no vga signal. Same if set for HDMI input: no HDMI signal.
I would check your source for why it is not sending signal rather than why the monitor is not receiving. Of course, that being said, is this a new monitor or an old one that could be shot?
Dec 26, 2015 | ASUS Computers & Internet
There is no 1366x768 resolution item in setup menu for my monitor using.
Hi , your computer may only be configured for a generic display monitor which may not support your desired resolution . If so install the latest display's inf ( driver ) file and then after restarting access the display resolution applet and configure as per the recommended setting
I think here might have useful software
http://www.asus.com/Commercial-Monitors/VS197D/HelpDesk_Download/
Aug 06, 2015 | ASUS Computers & Internet
I have a new asus VS197D then when i turn on it said NO VGA DISPLAY
if there is a graphics card in your pc than you should connect VGA cable to graphics card. may be you connected onboard graphics. just check hope that it will help you
Feb 15, 2014 | ASUS Computers & Internet
No monitor signal on my m2n-vm dvi after installing my new graphics card asus en210.The graphics card was tested on my other pc and works fine..any help?
First boot the computer without connecting Graphic Card, then go to BIOS and find for VGA option change the option to compatible mood, save the setting and come out of it. now off the computer re connect your graphic card and start the computer.
Aug 15, 2012 | ASUS M2N-VM DVI - Motherboard - micro ATX...
Asus led monitor model vh197 shows no signal on screen and no display ,screen became dark
Good Day Dasarathi!
Please check the VGA cable if its properly connected and make sure two screws are fixed to both end connecting the monitor and the video card.
No signal comes out when there is no signal from the video card to the monitor. That is why you need to check if the VGA cable is fix to both end.
If that did not fix it, you will need to open the casing of your computer. Disconnect the video card from the motherboard. Gently clean by wiping a clean clothe over the contact surface of the video card. Then, reseat the video card properly to the slot in the motherboard. Return the casing cover and connect the VGA cable again.
Just remember doing the above procedure is only when the computer is turn off.
Turn on your PC and see if that fix it.
You will need to replace the video card if by booting the PC you will hear a series of beep codes. If no beeps then you are lucky VGA cable is the faulty one.
Jun 09, 2011 | ASUS Computers & Internet
When i added a video card.. and restarted my pc. a blue screen appears... saying "overun"?? what is the problem??
well did you check weather the video card came with a VGA pin where you can connect the monitor signal cable if not , connect the monitor signal cable to the video card VGA out socket.
good luck
Jan 05, 2010 | ASUS P4S800-MX Motherboard
No signal to monitor
if u have a two VGA output in ur PC..try to use the build in VGA port...if doesn't appear... Try the one VGA port
Oct 18, 2009 | Computers & Internet
Want to use my tv as a monitor, how do I activate the vga output?
Hi adiazjr.On the Asus 1000he, in order to switch to an external monitor you need to press the function key (Fn) at the bottom left of the keyboard and the F8 key at the top. When you press both of these keys at the same time it will send the video signal to whatever external monitor or TV you have connected. Hope this helps!
Aug 28, 2009 | ASUS Eee PC 1000HE Netbook
Monitor Problem
Well assuming you used the same video cable when you tested the monitor on the Asus PC you?re left with: - Physical problem with the Asus video card. - Asus video card configuration problem. - BIOS configuration problem - Possibly a problem with the DVI/VGA adaptor depending on the answer below. A couple of questions about the Asus before we start: - I?m not sure I understand how the DVI/VGA converter figures into this. Is your cable coming off the monitor DVI thus you need it to plug into the Asus VGA connector? If yes who is the manufacturer of the device and what model do you have? - Has the Asus worked in the past with another monitor or is this new? - What is its history/configuration?
Mar 11, 2007 | ASUS T2-AH1 Barebone
ASUS VS197D-P 18.5 inch Widescreen 5ms 50000000:1 LED LCD Monitor Logo
20 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
