Question about Watches
Battery replacement for dw-6100 g-shock watch
3 Suggested Answers
upajos
  • 24 Answers
SOURCE: battery replacement for a G-shock.
The reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, as well. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
Posted on Oct 29, 2008
  • 299 Answers
SOURCE: How do I get to the battery of a CASIO DW-1500
You have to remove the caseback but without the proper tools you'll risk damaging the watch. You also must replace the gasket or it will leak. Best bet is to take it to a watch shop or jewelry store where they can do it for you for about $8. Sears has a kiosk in their stores to do this too.
Posted on Apr 25, 2010
I changed the batt. in my casio g shock dw 5600e and the screen will not light up.
you had to reset it by shorting it, it is located inside your watch. or push all the buttons at the same time. i hope i had been helped you.
Jul 21, 2011 | Casio DW-5600E-1VCT Wrist Watch
My g-shock watch model# DW 5700 displays a rectangular nox in the upper right corner with the letters "REM" below it. I've installed a new battery and this is all I get. None of the function buttons...
Rem is the reminder function of the watch , you can turn it off and on by holding down the bottom right button usually on casio watches. You can also find the online manual here http://world.casio.com/wat/download/en/manual/
please rate solution
Oct 18, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
Spring poppedout on dw 6900 g shock. need a
This happened to mine, couldn't get a spring anywhere. But managed to fix it by using a staple which I cut to size, Works fine now.
Oct 23, 2009 | Casio G-Shock G7000D-8V Wrist Watch
I've changed my battery on my casio g-shock dw 003 but the illuminator no longer works! why?
Did the same with my DW-003 and thought I'd broken the Illuminator (and the alarm didn't work). Next battery change was via a shop and the illuminator worked again (as did the alarm). This was just a battery cahnge, rather than a repair job - One of those things, I guess
Sep 30, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Battery problems
If your watch is blacking out when the light is used, this is the first sign for battery replacement as light feature consumes more power than all watch mechanics together. Uderpowered battery can be the reason why the battery gauge do not show any bars.
My advice is to change battery first.
If the watch will have the same problem after battery replacement, then you will need watch repairers advise as it will be clear that the watch is having mechanical or electronic fault and in this case only watchmaker would be able to deal with it.
Don't forget to rate, please.
Jan 04, 2009 | Watches
I just replace the battey on a g shock dw 9050 and i cant set the time i shows the time but at the top it flashes TYO
Did you ground the battery? If not you need to open up the watch and find the ground and take a tweezer and touch the top of the battery and the ground.You should be able to move on from there, if not are your buttons making contact with the movement?
Jun 29, 2008 | Watches
Manual for casio G.shock DW-5900
How do I replace the battery on a casio wrist watch?
Apr 25, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
I had the battery in my Casio G Shock DW 6800 replaced. Since then none of the beeps or alarms have worked. Is there a reset button he didn't press?
There is a reset button inside your watch, but I don't think that is the problem. Most likely, there is a spring that makes contact to the watch and the back of your watch case, and it fell out by the person replacing your battery. I would definitely go back to the place where you had the battery installed, and have them take care of the problem buy ordering you a new spring or have them pay for you to send it to Casio.
Apr 24, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Battery replacement for a G-shock.
Mar 24, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Watches Logo
62 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
