Question about Sony Xplod XM-1652Z Car Audio Amplifier
Want to know what the ohm is of a sony xplod amp 1000w 2/1 channel power amplifier xm-1652z
Just want to knw what the ohm is of one
    Problem Solver:
  • 15 Answers
All car amp outputs are 4ohm, regardless of the makes.
Posted on Feb 18, 2014
4 Suggested Answers
SOURCE: Sony Xplod XM-1652Z Car Audio Amplifier cuts out when turned up loud
The best thing to do is to get a amp that is more watts than your subs, not the other way around, speakers are known to handel a lil more power but amps cant produce more power than they are capable of... your ground wire should be thick also, say 6 to 8 mm or so, and its best to put in a cap and an equalizer.
Cheers
Posted on Dec 19, 2007
  • 11 Answers
SOURCE: will a sony xm-1652z 1000w amp run 2 dvc 4 ohm 800
IT WILL POWER THE SUBS WITH NO PROBLEM. I WILL NEED TO KNOW WHAT THAT MAX WATT THE SPEAKERS CAN HANDLE BEFORE GIVING PROPER ADVISE. RMS IS RECOMMENDED MINIMUM SETTINGS.
Posted on Feb 24, 2009
blueextc3221
  • 15935 Answers
SOURCE: How to install Sony Xplod XM-1652Z Car Audio Amplifier
First you will need to post the # of voicecoils each subwoofer has, and their resistance.
Next - you can purchase an amplifier installation kit just about anywhere that will supply you with everything needed to wire up 1 amplifier.
Power wire w/fuse
Ground Wire
Remote Wire
RCA cables
Speaker Wire.
CLICK HERE for your manual.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Posted on Jul 24, 2009
Can i bridge a Sony Xm-1652Z 2 Channel amp to 2 subs it gives me 2ohms
No - it is not 2 ohm mono stable
  • 1000W max power
  • 165W x 2, 20Hz - 20kHz, @ 0.04% THD + N, at 4 Ohms
  • 200W x 2, 20 - 20kHz, @ 0.15% THD + N, at 2 Ohms
  • 400W x 1, 20Hz - 20kHz, @ 0.1% THD + N, at 4 Ohms
  • OTL (Output Transformerless) circuit
  • Pulse power supply
  • Line & High Level Inputs
  • .3-6V Level Adjustment Control (RCA Pin Jacks) 1.2-12V (High Level Input)
  • 80 Hz, -18dB/octave Low Pass Filter Switch
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
What speaker componets do need to buy?
  • 1000W max power
And i would say that the best use of this amplifier would be for sub-woofers.
Feb 19, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
Getting my son a sony xplod xm-1652 2 channel what subs would sound good and the things says 1000x2 and 500x2 what is the truth
165 watts x 2 @ 4ohms and 200-230 watts@ 2 ohms or 400-460 watts bridged into a 4 ohm mono load is what the amp will actually do. A single 12 inch sub or a pair of 10 inch subs or 12s would be great
Nov 22, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
How do i bridge 3 subs to a 4 channel amp
My information shows the XM-1652Z as being a 2-channel amp. It will not be stable below 4-ohms in bridged mode. For best power, your subs will need to be 2-ohms with all 3 wired in series. This will present a 6-ohm load to the amp. After wiring the subs in series, connect the positive speaker wire to one channel (+) and the negative speaker wire to the other channel (-). For the 1652Z no other wiring is necessary. For subs you will also want to set the LPF (80Hz) switch to the "ON" position (to the right).
Keep in mind that the rated output is only 400 watts RMS at 4-ohms in bridged mode. That's kinda wimpy for 3 subs. You would probably obtain better results from two 2-ohm subs, each connected to a separate channel. That way each sub would be getting 200 watts RMS, still low but there's lots of good subs that will sound pretty loud with 150-200 watts
Mar 25, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod 1000W workign strangely
need a bigger gauge hot wire going to your amp ,maybe a battery cap. amp isnt getting enough power to perform so it cuting out.
Mar 01, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Will a sony xm-1652z 1000w amp run 2 dvc 4 ohm 800 watt rms subs?and whats yhe best wiring option if so?thx
Feb 21, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony amp model 1652z
1000W max power
<b>
</b>
Pulse power supply
Jan 15, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
How to measure watts
You need a Volt Meter and an Ohm Meter. P = VI & I = V/r, so Power = (Volt^2)/Ohms .
You can get the ohms by hooking them up to the subwoofer input wires, and you get the volts by hooking up to the amp output terminals/wires. Although, amps will put out different voltages for different frequences, this should give you ballpark estimates.
Nov 10, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp and sub connection
Too many problems, lol. One at a time. I lost you in your post, run by me again but one amp at a time.
Jan 08, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Sub power hadling capacity
Yes. If the rated power is 380W and the Max power is 1000W then it will handle it. Subs fry when clipping occurs. Clipping is when the amplifier is pushed past its capabilities and the output to the sub gets "dirty". The better quality the amp, the safer it will be on your speakers. It is also important to remember that the gain control on the amplifier is NOT a volume control to boot the sound, it is only to match the output from the headunit to the input handling of the amp. Cranking the gain up too much WILL CAUSE CLIPPING.
Jan 04, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier Logo
87 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
