Question about Proform XP Weight Loss 620 Treadmill
Treadmill is stuck at it's max incline position
erpaalai
  • 999 Answers
SOURCE: My Proform treadmill will not incline. It is stuck
Under the hood there should be a tech sheet with calibration instructions. I have not worked on these for several years or I would rattle off the procedure. If the sheet is still there make sure you put it back in the plastic sleeve for next time..... Eric
Posted on Jun 17, 2009
outfield502
  • 79 Answers
SOURCE: the proform 730 CS treadmill is stuck in the
The only way is loosening the screw or nut and making it back manually, but it is the right way to fix it, you should review the KEYPAD, specifically the down key. tries to do the following: turn it off and rub the area where the key now is turn it on again if it does not work with you to replace that part
Posted on Feb 06, 2010
maxtreadmill
  • 832 Answers
SOURCE: treadmill stuck on highest incline....and motor
If the incline is stuck, it could be a problem as simple as the gearbox on the motor being jammed. Unplug the treadmill remove the motor shroud then remove the incline motor from the treadmill, reconnect the wiring, plug in the treadmill and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
If the incline motor does not move, we need to figure out if the motor is getting voltage. Use a simple multi-meter and set it to AC volts. When you put it into calibration, it tries to calibrate the directions one at a time. Measure across the white and black wires first, then measure across the white and red wires second. If the motor is getting voltage you will read 120VAC (or thereabouts) one one of the measurements. If you have voltage but the motor won't move, you need to replace the motor. . If the incline motor does not move and you have done the voltage test and you do not have any voltage present, there is a problem in the electronics board that supplies the power, you need to replace the board.
Posted on May 17, 2010
  • 218 Answers
SOURCE: my proform 360p treadmill is stuck on full incline
try thisSometimes incline motors will get frozen in position and need broke free. Try this:
take the motor cover off and take the screw out of the bottom of the incline motor that is attached to the screw assembly. Once you remove the screw you should be able to break the incline motor free. run the incline up and down with the screw still off( laying the treadmill on its side may make this easier). Once it goes up and down (hold the screw so it goes in and out) reattach it then run the calibration described below. If it was just stuck it should work fine.
1. remove safety key
2. press and hold the speed+ and stop keys at the same time
3. Put the safety key in/on and release the keys
4. press stop once
5. hit the incline + arrow and let the incline go the whole way up and down
6. remove safety key and try
If these instructions do not work to fix the incline motor
check your main harness running down the right leg for breaks in the wires or a loose connection if nothings found you can switch the red and black wires on the incline motor terminal block and see if it goes down. If it does you know you are only getting voltage to one side of the motor. There is a schematic under the motor hood that tells you what the voltage should be when you press the up or down keys. Use a multi-meter to see if you are getting the correct voltage coming from the console to the motor control board and then from the board to the motor. If no voltage from console-replace console if you have voltage from console but not from board - replace board and finally if you have voltage from console and from board replace motor. You will need to test the voltage both when pressing the up key and the down key.
Posted on Aug 14, 2010
  • 34 Answers
SOURCE: my treadmill is stuck at the highest incline and
Although it is fairly rare the incline motor can jam up into the highest position and get stuck there. To fix this take off the plastic hood that covers the incline motor and depending on the motor you should be able to wind it with your hand out of the highest position. When it is out of the highest position run the calibration as described in the owner's manual and it should go all the way up and all the way down. If it is not this type of motor that can be wound by hand then the first and last thing to do is to try calibration of the incline as described in your manual. If this does not work then a new incline motor is needed.
Posted on Aug 18, 2010
I have a Horizon HTM 3000 treadmill which is stuck on max incline and require the incline calibration code.
hi, i also have problem with my horizon htm 3000, incline motor stuck.
did anyone know where to buy brand new incline motor?
and how much it will cost?
Nov 16, 2013 | Exercise & Fitness
Incline stuck treadmill
Run the software calibration for easy diagnostic and fix it. Lube the incline mechanism. Go to Hood cover motor and follow the steps or read your owner manual.
God bless you
Oct 15, 2013 | Icon Epic T60 Treadmill
My treadmill is stuck in incline
please RUN the software calibration for easy diagnose, troubleshooting, and fix it.
see the diagram attached, for troubleshooting too.see the b.diagram
Happy New Year.God bless you
Dec 31, 2012 | Treadmill Doctor Encore 1500 Treadmill...
Precor 927 stuck in incline position
How long have you let it run for after turning it back on ? Some treadmills have a re calibration test built in and will incline to the max and work its way down. During this time you should simply walk away and not touch anything as it trys to calibrate its self. If not i will need more information on it
Oct 10, 2012 | Precor 927 Treadmill
My treadmill is locked in the max incline position and controls won't respond
Run the software calibration for diagnose, troubleshooting, and fix it.
2) clean the gear and shaft from elevation motor.
3) adjust the POT for better improvement.
see the diagram
God bless you
Jul 27, 2012 | Exercise & Fitness
Proform xp650e, incline driving continuosly in max incline position with loud clunks/bumps
Your treadmill has what is called a "stair step" incline motor. It is common for them to go bad. You would need to remove the motor hood and activate the incline motor. Check to see if the noise is coming from the motor and if so I would suggest replacement.
Jul 28, 2010 | Proform Exercise & Fitness
Epic treadmill t60 is stuck in max incline how do
Usually when stuck at the max up position it indicates that you may need a new incline motor. It is not the sensor. I have been repairing treadmills for 15 years and incline sensors seldom if ever go bad. If can isolate the incline motor using a 110 volt power cord, this may un-jam the motor and get it back down to 0%.
I use www.treadmillpartszone.com for parts.
Jul 25, 2010 | Icon Epic T60 Treadmill
My treadmill is stuck in the max incline position
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
Jun 11, 2010 | Nordic Track Exercise & Fitness
Proform XP Weight Loss 620 Treadmill Logo
15 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
