Question about ASUS Computers & Internet
I have a new asus VS197D then when i turn on it said NO VGA DISPLAY
I just finish my new build then i try to connect to moniter then it said NO VGA Signal..
    Guru:
  • 377 Answers
If there is a graphics card in your pc than you should connect VGA cable to graphics card. may be you connected onboard graphics. just check hope that it will help you
Posted on Feb 16, 2014
5 Suggested Answers
BingoDabbers
  • 102 Answers
SOURCE: Moniter Vga cable
You need a vga to dvi cable, your local PC shop should be able to help.
Posted on Oct 06, 2007
  • 300 Answers
SOURCE: "No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Posted on Sep 14, 2008
bammbammfran
  • 159 Answers
SOURCE: I NEED HELP PLEASE!!!!!!! PROVIEW 19" MONITER.
Does the led on front of the monitor stay blue or does it become amber ?
If it becomes amber, then you are not getting a signal.
No harm in trying this : You can try to see if it is a contact problem.
With the monitor unplugged.
Use a small paper clip to run in and out of the blue vga plug holes a few times each to make sure they are not plugged or gummed up.
If that doesn't help and you know that your video cord is good, then I am afraid to say that more than likely there is a problem with yor video card.
If it stays blue then the signal is there but the screen isn't fully lighting up, leading to a failing power-inverter board or a bad bulb.
powerseller
bammbammfran
Posted on Oct 12, 2008
budmrtn
  • 11361 Answers
SOURCE: my Asus monitor wont display my desktop! :(
Since you have narrow down the problem to be the monitor, the next to do is to open it up. First place to look will be the capacitors in the power supply (common problem with ALL monitors). Please look here to get some ideas what to look for inside.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Post back so it may help other people also.
Posted on Apr 09, 2010
Testimonial: "thx mate found out there was nothing wrong with moniter found out my nice new graphics crad was nice new and busted taking it back today today thanks!"
There is no 1366x768 resolution item in setup menu for my monitor using.
Hi , your computer may only be configured for a generic display monitor which may not support your desired resolution . If so install the latest display's inf ( driver ) file and then after restarting access the display resolution applet and configure as per the recommended setting
I think here might have useful software
http://www.asus.com/Commercial-Monitors/VS197D/HelpDesk_Download/
Aug 06, 2015 | ASUS Computers & Internet
Toshiba Satellite Ultrabook U945-ST4N02 Windows 8,
Check with the moniter by connecting the VGA Cable. is there any display on moniter if yes then laptop;s screen faulty otherwise motherboard issue.
Oct 11, 2013 | Computers & Internet
Want boot up. Whern you push the power on button, one light on the CPU comes on and all fans come on. There is one beep when you push the button. The CD drive has power. The moniter does not come up. I...
it means machine working fine but display problem check it your RAM check with a soft cloth may monitor is also avilable or check behind the VGA cable proper connect it or not
Sep 23, 2011 | ASUS P4P800-VM Motherboard
My Asus monitor wont display my desktop! :(
your on the right track with the video card could need reseated, make sure is set to default in bios, when you get into windows with it pluged in to the onboard vga can u look in device manager to see if its showing up in there and isnt malfunctioning, then again it could just be bad electronics go out all the time
Apr 09, 2010 | ASUS VK222H Monitor
When i turn on my system unit, my monitor also doest turn on
please change your data VGA cable and then oper your moniter.
Jul 31, 2009 | ASUS P5S800-VM Motherboard
My moniter wont display anything
Your moniter resolution is greater than its compitable resolution.You have to start it on its safe mode.First unplug your coputer cable then restart it then you have to select Start with Safe Mode.If it doesn't work you have to format your PC.
May 17, 2009 | Computers & Internet
My ASUS P5SD2-VM Is Having A No Display Problem
If you are using the motherboards built in VGA graphic display, check your bios settings. Open your manual to page 2-22. Read the page.
Make sure you have the bios set to, Primary Graphics Adapter [PCI-E] set to, [IntVGA].
Set the internal VGA to, [Enable]. You will also need to set an amount of your system memory for the VGA to use. It is recommended if you are using Windows Vista that you increase your 1GB of system memory to, 2GB. Or instead you can buy a decent PCI-E video card that will use its own memory instead of your system memory. If you do this you'll need to change the bios settings to, Primary Graphics Adapter [PCI-E].
Also change, Share Memory Size to [Disabled].
If you need the manual for the Asus P5SD2-VM. Click on the link below;
http://support.asus.com/download/download.aspx?modelname=P5SD2-VM&SLanguage=en-us
Click the dropdown menu & click on your operating system. Than click Search. Asus list all drivers, manuals, FAQ's ect.
To view the manual you'll need Adobe Reader. You can download Adobe for free at this link;
http://www.adobe.com/products/reader/
Again, if you do not have any display & your using the built in VGA graphics card try resetting the bios. Doing this will reset the bios back to normal default settings. The bios will auto use the built in VGA. To clear the bios see page 1-22.
Mike
Apr 26, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
My Moniter Is Blank
First make sure that you have the P4 connector (the square one at the top of the board connected to your P4 power from the power supply.
From here I would disconnect the data cables from the hdd, optical drives, and remove all video/peripheral cards. You should have only the RAM, CPU, and power connected, then try to boot again.
If this works, then add 1 device at a time until it fails to start. This will isolate the component that is giving you problems.
With a single stick of RAM, try to get the computer to POST. (if possible, test the ram in another machine first to ensure that RAM is good)
Jan 01, 2009 | ASUS EN8400GS SILENT/HTP/256M PCI-E TV-OUT...
This is a new install, no vga out
You Can Try By Cleaning Out The Memories And Checking The Processor Is Placed Right In The Socket
Dec 25, 2008 | ASUS P5P800-MX Motherboard
What dvi cable do i need?
Any bog standard dvi cable should work. As should a dvi to vga converter. Dvi is by far the better interface, and I would highly recommend using it, without any converters. I don't believe you can up convert vga to dvi, but you can certainly downgrade a dvi signal to vga, but i can't see why you would want to...
Oct 17, 2008 | Computers & Internet
Computers & Internet Logo
79 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
