Question about Proform 400 CT Treadmill - Treadmills
Motor burned out
During use tread speed slowed and then it put off a harsh burning motor smell. The electricl motor does still spin, but not consistently nor well. Can I just change out the electric motor?
maxtreadmill
  • 832 Answers
SOURCE: my tread mill looses speed during my workout. the
If you haven't adjusted the belt refer to your owners manual for the proper procedure if you still have the same results then it could be caused by a lack of lubrication under belt or a worn belt.
Posted on Apr 11, 2010
rockmeister
  • 2047 Answers
SOURCE: When starting, the motor starts sluggishly. It
Treadmills are usually made up of various components. The rolling surface (tread) is usually placed on a set of rollers when the unit starts due to the low friction between both the surface (tread) and the rollers the surface (tread) starts slowly while the rollers move regularly and the sensor is placed on the movement of the rollers.
What you need to do is get the unit serviced usually there is a way the tread it tightened to have better grip on the rollers. This method differs from one make to the other so get an expert who knows about proform rollers. Once the system is tightened the problem will be solved.
Hope this solution has been helpful?
Posted on Jan 05, 2011
SOURCE: I have a Proform 545s treadmill with incline and
i have a proform 545s as well and it would light up when pluged in but you could not use the speed settings at all. i figured out how to fix it just by tinkering around with it. i removed the back cover on the programer up top and exposed the circiut board. there is are 2 ribbon like sets of wires that come from the speed controler. the plug into the circuit board with a whit clip. pop loose the white clip on both of there and you will see a series of prongs that come in contact with the ribbon. using a small flat head screwdriver you must bend these prongs in slightly to close the gap between the two. it took me a couple tries to bend them enough to make contact again. i tried it and to my surprise it works great. the fan still is not working but i am trying to trouble shoot that now. hope this helps you....
Posted on Dec 15, 2011
ercupa190
  • 12223 Answers
SOURCE: my proform xp slows below the set speed, the motor wines and after forty minutes starts to smell
Dear Sir:
Please RUN THE software calibration for easy diagnose and troubleshooting, and adjust the speed sensor see the diagram attached.
And you will see the problem with the motor, possible lack of LUBE, and maintenance.Now you test the motor for lubrication and maintenance too.
Posted on Apr 21, 2012
ercupa190
  • 12223 Answers
SOURCE: I have a proform 580 trainer whose speed fluctuates. if it is set to 4 mph it will go down to 3.2 mph then back up to 4 mph and anywhere inbetween those speeds.
1) Tess by RUN the sofware calibration for easy diagnose, troubleshooting and fix it.
2) adjust the speed sensor, test for open or faulty, clean it and tight the plug very well. see the diagram attached.
3) Test the inclination motor for overheating Try to LUBE
4) Lube the deck belt according with the schedule maintenance.
God bless you
Posted on Dec 18, 2012
My washer was smoking during the spin cycle what could the problem be.
hi Bill.
The pump may be belt driven, motor driven or have its own electric motor. A burning smell coming from the washing machine during or after the spin cycle can indicate that the drain pump has become seized, preventing it from turning.
read up some more at this link.
https://www.partselect.com/Repair/Washer/Burning-Smell
Dec 12, 2017 | Washing Machines
Inconsistent Speeds and Motor Smell
A new treadmill is in order! It sounds like the motor is either old, or it has a factory default. Definitely do not use the treadmill if it produces burning smells this is in fact the wires in the motor heating up and melting this could cause a fire.
Jan 23, 2014 | Advanced Fitness Group AFG 1.0 AT Folding...
Weslo Cadence G-40 during operation there was a loud pop and an electrical smell, as if something blew or burned. Since that time I've been using it and notice a minor slowing and recovering of the belt...
You must test the motor, and tight the electrical connection very well. and see if there some burn wires, or connector.in any board of the elliptical. See my personal TIPS.
And test the electrical wall, and see if the voltage is o.k .
However keep you eyes open, for any inconveniences. Suspect of the motor winding.
God bless you
Sep 28, 2013 | Weslo Cadence G40 Treadmill
Slow motor on lawnmowermower and smells hot
you may find that you have a build up of old cuttings under the blade impeller if they build up in the drive gear under the impeller then the motor will run slow do not try to use the unit as you will run the risk of the motor burning out fallow the user guide on how to clean and strip your unit down and please unplug it from the mains hope thi helps
Oct 22, 2009 | Electric Garden
GE Wizard Top-Load Washer - Burning Smell
sounds like an over heated motor. motors tend to do that before finially hitting a brick wall. please e-mail me for any other assistance. good luck :)
Jul 07, 2009 | Washing Machines
Kenmore 70 series slow agitator
You have burned the clutch this must be replaced
Jun 09, 2009 | Kenmore 15864/15862 Top Load Washer
7.3 diesel turbor wont start
It needs to spin over at correct speed so if it is dragging causing slow turn over then yes it can cause
Oct 17, 2008 | 1996 Ford F350 Crew Cab
Whirlpool washer slow to spin
Yes I happens to work a lot with this type of machines. Normally when the spin is too slow the problem rises form a week voltage, motor winding too week for the velocity. I means that the winding in the motor might have gotten burn and weakened the winding to the point where when the motor ask for more voltage to spins the housing the winding heat up. That is why you smell as something burning. The system in this type of machines is not complex but tedious. If everything else work in the machine then it is the motor.
Nov 22, 2017 | Whirlpool Washing Machines
Washer smoke during spin cycle...
could be belts slipping or a bad motor going - what's it smell like - burning rubber or an electrical smell?
Aug 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
Proform 400 CT Treadmill - Treadmills Logo
52 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
