Question about Refrigerators
Error codes on door display
LG - LFX31945ST/02 - Error codes appear on door control panel. Refrigerator button - 'Er' Freezer button - 'Fi'
  • 27 Answers
SOURCE: where is this fuse located on the LG refrigerator is displaying a ER DH code error
Hi. You have an Error Defrost Heater. Its taking too long for the heater sensor to open the circuit during defrost. You normally replace the heater, heater sensor and circuit board(motherboard) located on the back of the refrigerator in this situation. Check your mollex plugs and make sure they are connected tightly at the evaporator coil area. Sometimes they come loose. I reccommend replacing the heater and heater sensor located top right on the evaporator coil. This should take care of the problem. Need parts see me on ebay as user, themackshack. Good luck, Mack
Posted on Jan 06, 2008
  • 110 Answers
SOURCE: LG Refrigerator Defrost Error ER DH
it the def t-stat, def. thermistor, or def. fuse whatever lg decides to call it this week that is causing your issue
Posted on Jun 13, 2008
  • 1122 Answers
GO TO SEARS .COM ,CLICK ON PARTS,PUT YOUR MODEL NUMBER IN AND YOU WILL FIND WHERE THE PART IS,LET ME KNOW-MIKE
Posted on Jul 07, 2008
SOURCE: LG refrigerator error code
Had the same problem + a weird noise, which turned out to be ice build up on the blower fan. Unplugged overnight and then opened the lower back panel. There is a small fan that blows over some small coils at the bottom of the box. There is also a drip pan that should be "full" of water. I sponged out the drip pan, put the panel back on and then plugged back in. Works great.
Posted on Nov 04, 2008
stradeteox
  • 88 Answers
SOURCE: I have an LG LRSC26923TT
ER FF is a freezer fan error. Basically the mainboard is not receiving a feedback signal from the freezer fan motor within 65 seconds. When this happens the error code will come up and then none of the buttons will work.
You can clear out the error code by unplugging and plugging the machine back in. The error code will come back if the problem persists. Check around the freezer fan motor fan blades to see if ice buildup is interfering with the operation. Clearing out this ice may fix the issue.
If the problem comes back, then the fan motor may be getting ready to go out or the unit may not be defrosting properly.
Hope this helps, please rate my solution.
Posted on Jan 12, 2009
LG lfx31945 REFIGERATOR...FREEZER NOT COOLING. ER FF CODE
LG Help Library: Error Codes - Refrigerator ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library
  1. Cached
  2. Similar
Feb 26, 2018 - FF Error Code. A FF error code indicates that the unit has detected an issue with the freezer fan. This can sometimes be caused by frost buildup. ... If you notice frost buildup along the walls of the freezer compartment, the leveling and door alignment of the refrigerator will need to be checked.
SOLVED: Error Code ER FF - Fixya
www.fixya.com/support/t121701-error_code_er_ff
  1. Cached
  2. Similar
Oct 18, 2006 - Error Code ER FF Our refrigerator is 1 year & 1 week old. A few days ago it started making a noise that sounded - LG LRBC22544 Bottom Freezer question. SOLVED: Error codes Er rF 10 posts 14 Nov 2013 Lg lfx31925st 00 code er ff 10 posts 21 Sep 2013 SOLVED: How Do You Repair An lg lfx31925st error ... 11 posts 16 Nov 2012 SOLVED: LG refrigerator lrsc26944tt error code ER FF 11 posts 25 Jan 2009 More results from www.fixya.com
FIXED LG refrigerator error code Er FF - ApplianceBlog
https://www.applianceblog.com/mainforums/.../8302-LG-refrigerator-error-code-Er-F...
  1. Cached
  2. Similar
Mar 31, 2007 - Hey guys, This LG has me stuck. I have run the smart board entirely through the diagnostic mode and it says everything is OK - hours later a code comes up "Er FF" Model: LRSC26922TT Serial: 407KRPV00464 I have had no luck finding any useful info on the web.... nothing but horror stories about LG. FIXED LG Refrigerator LFXS32726 - Error Code E rF 3 Aug 2016 LG LFX31925 drain iced up (ER FF code) - How to remove freezer ... 24 May 2016 FIXED LG LFX31925ST Giving error code ER RF 3 Sep 2013 Kenmore elite refrigerator error code er FF 3 Mar 2013 More results from www.applianceblog.com
LG REFRIGERATOR REPAIR. HOW TO REPLACE FREEZER FAN. FF ...
9k=? 4:42 https://www.youtube.com/watch?v=Yiifd2sTrZI
  1. Similar
Jan 3, 2013 - Uploaded by SOCALAPPLIANCE LG Refrigerator repair. FF error code / ee ff . Bad freezer fan. Bad evaporator fan. How to repair an LG ...
Mar 22, 2018 | LG Refrigerators
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
What is wrong when I receive error code Er rF
Hello Anonymous!
Error code Er rF is an :Abnormality of BLDC FAN Motor for Freezer.
  • The freezer fan motor may be Defective.
  • Unplug the fridge for about 30 minutes and plug it back in, if the code appear again within 24 Hr , the Main Board might be defective too.
  • Check if the freezer fan is blowing normally, then the Main board has a problem.
  • If not, the Fan Motor is defective or both.
  • I would change the Fan first then the Main PCB
Good Luck,
JP
Jul 09, 2015 | LG Stainless Steel French Door...
LG Lfx31945ST . No ice and error ER 1F. About 6 weeks ago frost started to appear on the freezer drawer. Tried unplugging it for 4 hours and turning it back on but still getting error within a few...
probably heating element in freezer is broken.
Remove power and defrost. Remove wall panels in back of freezer to Check heater element behind panels With ohm meter should read 20 ohms or less. You could remove it and bring it to a local repair shop and have them test it and if required order you a new one. If this does not work it may be the control board
Oct 20, 2013 | LG LRBC22544 Bottom Freezer Refrigerator
Refrigerator displaying error "ER FF".
Error Code "Er FF" indicates a problem with the unit's freezer fan.
The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue.
This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service.
Hope this helps.
Jun 10, 2011 | LG LRFC25750 Refrigerator French Door
Help....kenmore trio refrigerator, error message "er co"
The Er Co error code signifies a communication error between the display control board on the freezer door and the main power board on the outer back panel of the refrigerator.
Check the wiring and connections between the low voltage interface and the main high voltage board.
If you are able to unplug the refrigerator and remove the cover over the control board on the back of the refrigerator,
you can check the wiring connection on the main control board.
If this wiring connection is okay, check the wire harness connection under the hinge cover on the top of the left hand refrigerator door.
If these connections are okay, then you will need access the wire harness connection in the dispenser.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 19, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Error Message: Er dH
The error codes are listed in the service manual (p. 32) at the address below:
LFX25960 Service Manual
"Er dH" seems to be a defroster issue.
Aug 14, 2008 | LG LFX25960 Bottom Freezer French Door...
Where is this fuse located on the LG refrigerator is displaying a ER DH code error
Jul 07, 2008 | LG LRFC25750 Refrigerator French Door
Error Code ER FF
FF is your freezer fan. You may need to defrost the unit.
Feb 28, 2017 | LG French Door Cabinet Depth Refrigerator...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
