SOURCE: Dell inspiron 1545 laptop and the same webcam problem.
open your my computer, click on "c" the system will tell you the information is hidden, click on the link and open up the operating system and look in the drivers or there in C and se if you can find you web cam driver, when you find it you might have to force the opening of the driver to install, and once you do that plug your web cam in and see if the system see's it and installs the drivers for the cam, if you installed the driver origanally witht he web cam installed you will have to remove the web cam and unistall the driver and re install it and then plug the web cam back in, and that should help correct the problem.
SOURCE: My dell inspiron 1545 shuts down by itself, dell
I have the exact same problem. However I don't think the problem is
the oper. system. The computer shuts down at random; many times it
won't even boot. I originally thought maybe their was a loose ram
stick, so i tried replacing it and had no luck. Then I tried removing
the hdd and tried to get into the BIOS, but it still sometimes would
shut off; meaning that the o/s can't be the problem.
It still works sometimes, but other times just shuts off or
won't make it past the initial boot screen. I'm thinking it has to be
a problem with something in the power supply. It's seems like the
power just completely cuts off, i've never seen anything like it.
SOURCE: Dell Inspiron 1545 power adapter not charging machine
Just call Dell, don't take it back to Best Buy or anything (that's where I got my Inspiron 1565). They will put you through a couple troubleshooting items and decide whether it's the AC adapter went bad or if they have to replace your motherboard. It's all free since they have a 1yr hardware warranty.
SOURCE: dell inspiron 1545 start up problem
try press F12 when you see the DELL Logo, if it still goes to BIOS you need to replace keyboard
SOURCE: dell inspiron 1545 power on administrator password pro
You can get a Password Reset disc download and burn to CD. Copy/paste the address below, into your address bar of your browser.
http://pogostick.net/~pnh/ntpasswd/cd080802.zip
Download this file and burn it to CD. Put into drive and turn on PC, and boot from the CD. Follow instructions, choose the correct USER. & BLANK the password. make sure you say OK to write the data, and reboot. The logon password will now be reset blank.
