Question about Radio Shack TRC-447 CB Radio
The trc-226 has a spot to plug in a dc adapter in the house what is the part number
    Genius:
  • Radio Shack Master
  • 1,795 Answers
Are you talking about the adapter? Any 13.8 volt adapter that the allows the plug to fit properly should work . Just make sure it fits snug and make contact .
Posted on Mar 20, 2016
What kind of plug adapter does my recorder take?
you will need a 6v or six volt power adapter to use a house hold electrical outlet. You can use it in your vehicle if your adapter can convert 12 volt dc to 6volt dc
May 11, 2014 | General Electric 3-5027a Portable Cassette...
What is the part number for the dc adapter
Cant you just use a generic one off shelf? I saw one at the Dollar store, make sure it can handle the current you need.
Feb 15, 2014 | Radio Shack TRC-447 CB Radio
Power problems
Unplug the AC adapter (Charger) from power. Unplug the AC adapter from the laptop.
Remove the Battery.
Press the Power On button in, and hold it in for a count of 10 seconds.
(And I mean 10. Count, 1001,..1002,..1003,..etc)
Reinstall the Battery. Plug the AC adapter back in. Plug the AC adapter into power.
(ALWAYS plug the AC adapter into the laptop FIRST, then plug the AC adapter into power.
Why?
To avoid a voltage spike at the laptop)
WAIT 1 minute, turn the laptop on.
Still no?
Then the AC adapter needs to be checked, to see if it is putting out the correct voltage.
Don't know, Model Number wasn't stated.
AC adapter checks out, then it is on to the DC Power Jack.
The jack on the laptop (DC_IN) that the AC adapter plugs into.
What style?
Don't know the Model Number wasn't stated.
DC Power Jack checks out, then I suggest you have a problem with a Power MOSFET,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
(Model Number is on the Bottom of the laptop. Plus, this IS a Dell, right?)
Post back in a Comment.
Regards,
joecoolvette
Feb 19, 2013 | Dell Inspiron Computers & Internet
Plugged in and not charging
1) Use a multimeter, check the AC adapter (Charger) for power.
Make sure it is putting out the required voltage.
Have an assistant gently wiggle the cable FROM AC adapter TO laptop. See if there is an intermittent reading on the multimeter.
Have an assistant gently wiggle the power cord.
An intermittent reading on the multimeter indicates a broken wire.
Power cord is bad? Replace cord.
Cable from AC adapter to laptop is bad? Replace AC adapter.
If you have posted the laptop manufacturer NAME and MODEL NUMBER, I could have given you more than generic information.
Model Number is in the Bottom of the laptop. Post back in a Comment.
AC adapter works OK?
Check the DC Power Jack.
The DC Power Jack is the jack on the laptop, that the AC adapter plugs into.
DC Power Jack checks OK, this is your problem,
Regards,
joecoolvette
Jan 31, 2013 | Computers & Internet
I have a TRC-447. First problem was it wouldn't fit in my Ford Ranger.No room any where. So I hooked it up in the house with a multi-adapter. One day it quit working. I replaced a burned out fuse 2A.It...
That radio needs a MIN.4 A. Fuse. If the output has been torqued you will have to use a 5 A.fuse..However, the metalic smell tells me that you may have hooked the power leads backwards ?" ? They don't loke that one little bit ! ! Too bad....those were good radios axdn the President Grant is the same chassis< the latter has some minor diff's, but all parts are interchangable. Back to above...be sure the power is correct and do try new larger fuses. Good luck
Sep 05, 2010 | Radio Shack TRC-447 CB Radio
What size power adapter does it use?
You need a AC to DC power supply capable of supplying 120VAC in, 12VDC out @ 1 amp (1000 mA). The center of the plug must be + and the outside -. I believe Dell supports these speakers and may have the power supply available. Radio Shack might have a substitute PS as well, you just have to match the plug size. Be careful what you pay for it, a new pair of these speakers can be purchased for around $20.
Here is a 12v 1500mA adapter (the mA rating can be higher that what you need, but not lower) from Radio Shack http://www.radioshack.com/product/index.… but its more expensive that a new set of speakers.
Aug 06, 2010 | Harman Kardon HK206 Computer Speakers
Compatbility of product in Australia?
if you connect the boombox direct to the your mains of 240v, the appliances will blow up , to avoid that you need a step down transformer to connect the boombox before it goes into the mains source. you do not need any adapter, only if you want to use battery that is when you to swicth to 12v
May 25, 2010 | Lasonic TRC-931 Cassette Boombox
High Contrast in Printing Photographs from DC-12
sir
u do one thing press 0+ start & go to max setup
trc adjustment press start u can get a3 print
next trc toner concentration start
ofter u can get some defference
Dec 11, 2008 | Xerox DocuColor 12 Printer
Archos AV400 Power Adapter
wallwart is model # trc-05-1600 made by group west I have one, though I cant let it go... BUT may battery is dead and i have to unscrew? the back to replace it. Got any tips for me?
Sep 30, 2008 | Archos AV400 Digital Media Player
Looking for Power Adapter for Nakamichi CD player
A possible replacement is TRC Electronics Model #: PSA-18U-090 (you need to specify plug type/dimensions). You can also checkout Samsung AD1608 (though 8.4V).
Should you be challenge to build your own, here is a simple Do-it-Yourself (DIY).
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 04, 2008 | StarTech.com SV231USB and SV431USB AC...
Radio Shack TRC-447 CB Radio Logo
224 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
