Question about Pride Jazzy 614 Hd JAZZY 614HD
Power button stuck
614 hd
Jazzy 614 HD. Motor runs but the wheel does not turn
hi T. Phelps, sounds like the coupler situated between the motor and gearbox is broken etc.
Regards
Rob
Jan 31, 2016 | Pride Jazzy 614 Hd JAZZY 614HD
Are the motors the same in the Jazzy 614 and the 614 HD model?
I believe the HD has a larger wattage motor, physically they may look alike but the HD will be stronger.
Sep 28, 2015 | Health & Beauty
Speed fluctuating on controller. goes from slow to fast without me touching controller on pride jazzy 614 hd battery powered chair
Your controller is dirty. Unfortunately, the unit is sealed and you therefore can do other than replace the unit. I suggest monster scooter parts at Jazzy 614 HD Parts The cost is high at $377.00. If you were really into fixing electronics it is possible to take the unit apart and clean the joystick, but that is a stop gap measure until you get your new joystick. Let me know if you need instructions on tearing the joystick apart and I will help if I can.
Jul 22, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
What does a jazzy 614 power chair 9 flashing wrenches need?
hi, that is the code for a brake fault , check the wiring to the brakes located on top of the motors...
Regards
Rob
www.gewizrepairs.co.uk
Jul 05, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
I have a Jazzy 614 HD scooter. The right tire seems to skip and not get traction
The newer Pride Jazzy and Quantum series are known for motor failure where the wires become broken inside the wire insulation at the wire entrance to the motor housing - so the break can not be seen. It starts as a shutter and is intermittent.
(The motor wire's gauge / strand count is too low for the repeated flexing when the motor articulates during acceleration and deceleration)
Eventually the break completely and you are stuck.
If the chair is less than 18 months old take it back to the dealer and demand a warranty replacement. If they don't fix it then contact your State Attorney General regarding elder and disabled abuse. Seriously!
Mar 16, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Increase the speed
1) Press the speed button (two lightning bolts) up to 5-lights.
2) Get larger tires.
3) Have a dealer reprogram the controller - requires PGDT PP1 or Quantum programmer which is a dealer only item.
Jan 21, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Need an owners manual for a jazzy 614 HD
You can download this manual by clicking on the following link:
http://manuals.monsterscooterparts.com/mobility/Jazzy/manual-jazzy-614.pdf
Hope this helps.
Jan 09, 2011 | Health & Beauty
I need directions to unlock the controller arm for my jazzy 614 HD.
kari with the jazzy try turning the power on and immediately push the horn button twice I think this will take it out of sleep or lock out mode. If that doesn't work turn the power on and immediately push the joystick forward until you hear a beep then immediately push it to the rear until you hear another beep then release it to the center. Good Luck Hope this helps
Oct 29, 2010 | Health & Beauty
Pride Jazzy 614 Hd JAZZY 614HD Logo
14 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
