Question about Radio Shack TRC-447 CB Radio
What is the part number for the dc adapter - Radio Shack TRC-447 CB Radio
  • 1,162 Answers
Cant you just use a generic one off shelf? I saw one at the Dollar store, make sure it can handle the current you need.
Posted on Mar 26, 2014
I need a replacement power supply for Sportcraft Arcade Hoops. Existing AC Adapter is model MW35-0750350
The adapter model number doesn't matter.
You need the output volts, AC or DC and the current (mA) off the existing adapter. You also need to match the input voltage for where you live, either about ~115v or about ~230V.
The last thing you need to match is the proper connector for the game and if DC the proper polarity.
If it's DC the easiest way is to go to a local store and get a universal adapter that can set multiple voltages, has multiple connectors and can possibly set both polarities. Just get one rated at equivalent or slightly more current than the old one. If you have to purchase one with significantly more current, you may need to set the voltage a little lower.
Nov 02, 2016 | Computers & Internet
Need to know input, polarity and voltage to ensure I have the right adapter.
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Jun 24, 2013 - If the device has a DC input of +12V / 5.4A, get an adapter that has a DC output of +12V / 5.4A. If you have a universal adapter, make sure it has the proper current rating ... Ideally, you'll have the same voltage, current and polarity on your ......or hdmi on my laptop .can you say what's the reason for the same.
How to select an AC to DC power adapter - ApogeeKits
www.apogeekits.com/power_adapter_selection.htm
An explanation of regulated versus un-regulated AC to DC voltage power adapters. ...voltage output power adapters and how to use this information to select the right one... Some (more expensive) DC voltage output power adapters have voltage ... Care should be take to ensure that the maximum input voltage of the load ...
AC/DC Power adapter ' Laptop Parts 101
www.laptopparts101.com > Laptop parts
Dec 26, 2008 - It's very important to use the right adapter for your laptop. ... Polarityon the new adapter's plug must be the same as on the original ... AC/DC power adapter voltage and amperage ..... I have purchased an non-hp dc-dc convertor (150W), 12Vinput, 19V output. .... So the cable component has to be replace.
Determining Proper A/C Polarity - Galen Carol Audio
www.gcaudio.com > Resources > How-To's
Jan 10, 2016 | Computers & Internet
Power problems
Unplug the AC adapter (Charger) from power. Unplug the AC adapter from the laptop.
Remove the Battery.
Press the Power On button in, and hold it in for a count of 10 seconds.
(And I mean 10. Count, 1001,..1002,..1003,..etc)
Reinstall the Battery. Plug the AC adapter back in. Plug the AC adapter into power.
(ALWAYS plug the AC adapter into the laptop FIRST, then plug the AC adapter into power.
Why?
To avoid a voltage spike at the laptop)
WAIT 1 minute, turn the laptop on.
Still no?
Then the AC adapter needs to be checked, to see if it is putting out the correct voltage.
Don't know, Model Number wasn't stated.
AC adapter checks out, then it is on to the DC Power Jack.
The jack on the laptop (DC_IN) that the AC adapter plugs into.
What style?
Don't know the Model Number wasn't stated.
DC Power Jack checks out, then I suggest you have a problem with a Power MOSFET,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
(Model Number is on the Bottom of the laptop. Plus, this IS a Dell, right?)
Post back in a Comment.
Regards,
joecoolvette
Feb 19, 2013 | Dell Inspiron Computers & Internet
Plugged in and not charging
1) Use a multimeter, check the AC adapter (Charger) for power.
Make sure it is putting out the required voltage.
Have an assistant gently wiggle the cable FROM AC adapter TO laptop. See if there is an intermittent reading on the multimeter.
Have an assistant gently wiggle the power cord.
An intermittent reading on the multimeter indicates a broken wire.
Power cord is bad? Replace cord.
Cable from AC adapter to laptop is bad? Replace AC adapter.
If you have posted the laptop manufacturer NAME and MODEL NUMBER, I could have given you more than generic information.
Model Number is in the Bottom of the laptop. Post back in a Comment.
AC adapter works OK?
Check the DC Power Jack.
The DC Power Jack is the jack on the laptop, that the AC adapter plugs into.
DC Power Jack checks OK, this is your problem,
Regards,
joecoolvette
Jan 31, 2013 | Computers & Internet
I need a new ac/dc adaptor for my pdv 709 ac100-240v 50/60hz 0.5a output dc 9v 2a efficiency level 1v factory id a
If you have the original adapter simply purchase a generic adapter with the same connection type, amp/current and voltage. Otherwise it will show on the products sticker, normally with the model and serial number, what input the ac/dc adapter uses. Im assuming from the information given you need to purchase a 9 volt adapter with an amp or current rating of 500mA or 0.5 amps. I hope this helps. Good luck.
Dec 03, 2009 | Durabrand PDV-709
AC / DC power adapter for Packard Bell SLIMVIEW
Here is the replacement from an UK seller.
Part number is 6860870000 , put this number in google to get the part in your area.
Aug 27, 2009 | Computers & Internet
I have a Iomega 250GBExternal hard drive. The pins that connect to the hard drive via the adapter pack have broken. The serial number is 579233448 the model no is DA-30C03 and the p/N is 31426900. I wanted...
i have the same probleme . I have a Iomega 250GBExternal hard drive. The pins that connect to the hard drive via the adapter pack have broken. The serial number is 579233448 the model no is DA-30C03 and the p/N is 31426900. I wanted to know which is the correct product to buy please
Sep 08, 2008 | Iomega (33090) 250 GB Hard Drive
Charger
The light can come in a box with just the light alone (light with battery), single ac(light with ac cord and 1 charger), single dc(light with dc volt cigarette outlet and 1 charger), double (light, 1 ac, 1 dc cord, 2 chargers) pb charger...and so on. The sticker on the box that contains the UPC code should have the listed detail on what the box should contain. Still confused check out the website www.streamlight.com search the light you're looking for and check out the product part number list. Hope that helps ;)
Jul 21, 2008 | Stinger Streamlight 75000
Durabrand ac/dc adapter model TAD-10
you can buy an aftermarket brand that is the same as the Durbrand ac/cd adapter model Tad-10 here:
http://www.acdapter.com/DURABRAND_PVD_AC_ADAPTER.html
Jan 19, 2008 | Durabrand PDV-705 Portable DVD Player
Radio Shack TRC-447 CB Radio Logo
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
