Question about Pool & Spa
Wire hayward pool pump
Red wire to ?
  • 323 Answers
SOURCE: Wiring Hayward pool pump
John what you have is a 240 volt motor on that pump. It will not connect to a 120 volt cord. You'll have to get a different pump.
Sirwriter
Posted on May 15, 2009
  • 156 Answers
SOURCE: The pump only hums when plugged in. Any suggestions?
It sounds like the impellor is locked. Take this part off and then see if the pump is turning but before you do, some of them have a big screw driver slot in the shaft. If it does, turn it to see if you can free the impellor. I have done this many times and they will continue to work for years after. They just get stuck from rust, etc. and also being frozen a little. Hope this helps.
Posted on Jul 06, 2009
SOURCE: pool pump is very loud
A loud pump is typically the bearings. You can get a bearing wheel for under $15 at your pool supply store. You should change the seals while you're at it- about $12. It's tricky to remove the impeller. Check Youtube for a nice "howto". You may also want to get a gear removal tool to remove the bearing wheel. Any auto parts store will carry it. To get to the bearing wheel you will need to remove the very long about 10 inch screws (4) from the rear housing. I used a 1 inch pipe to tap the bearing wheel. back on the shaft. Works great now.
Posted on Aug 21, 2009
  • 8404 Answers
SOURCE: looking for a diagram on a hayward pool pump
What specifically are you looking for (beside the fact you asked for a diagram)?
It should be setup for 220 Volts ... the only thing inside is a start cap.
Can you tell me more? I maintain 5 2 and 1 1.5 hp such pumps.
Posted on Oct 14, 2009
jharwell668
  • 640 Answers
SOURCE: Navigator Pool Cleaner: My Hayward pool cleaner just goes in small circles...
Check all of the following. Ones of these issues is probably causing your pool cleaner to go in circles. Let me know if these soultions don't work and I will be glad to offer more solutions, but I a think one of these might solve your problem:
1. You might not have proper water flow. Too much or too little pressure will cause this to happen. Check the pressure with your flow gauge and adjust if necessary.
2. Check for a partial blockage of the navigator throat. If you have a blockage, it could disrupt the movement of your cleaner. Clear blockage if necessary.
3. Check the shoes and wings. Damage or wear to them can disrupt your patterns of cleaning. If you notice that your shoes or wings are worn, replace them to correct the problem.
4. Check to make sure that your hose is not twisted. It should be clear of kinks, twists, and knots. Untangle if necessary. Laying the hose out in the sun will make it more pliable and easier to untangle if you need to do this.
5. Other things that could cause steering issues: check and clean the rear screen, check to see that the cone gear is is free and rotates smoothly, clean/replace/repair gear box, check pod connection, and check turbine and spindle assembly.
Hope this helps! Let me know if you need clarification or additional help!
Posted on May 20, 2010
How do I connect the red and black wires (power source) to the SP2610x15 pool pump?
Your line leads go on the L1 and L2 terminals in the rear of the motor. It will not matter which wire is on which terminal as long as you seperate them with only one wire on either terminal.
John
May 01, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
I have a Hayward 1 HP pool pump. I have to
hi ...the two yellow go on one side of the cap and the red /white go on the other.. like two on the negative side of a battery and one on the pos .. your pool pump repair guy longwood fl
Apr 01, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
I HAVE A PUMP MOTOR I WANT TO WIRE UP FOR A DIFFERENT USE I THINK IT IS TWO SPEED CAN YOU TELL ME WHAT WIRES ARE WHAT GREEN,RED BLACK AND WHITE
It should tell you on the label on the motor. White will be common and red either high or low. Black will be whatever red is not. green is ground.
Jun 08, 2009 | Hayward Power Flo Lx 1 Hp Pool Pump Sp1580
Sirwriter
May 15, 2009 | Hayward SUPERPUMP 2.0 HP, 115/230V
Pool & Spa Logo
20 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
