How does one remove stuck screws if grabit tool does not work?
If grabit tool does not remove them, then how?
    Top Expert:
  • Computers & ... Master
  • 22,095 Answers
You could always drill them out using a drill that is a fraction smaller in diameter.
Posted on Feb 15, 2014
Broken antenna
The best way is to use an EZ-out drill bit or extractor tool like Pro Grabit. I have gotten a few out just using small pick tools and gradually turning it as long as it is not cross threaded.
Nov 13, 2013 | 2002 Toyota RAV4
Tip
Change lightbulb in Advantium SCB1001 KSS01
I was also told that I would have to pay a technician to come out to replace the interior light bulb in my Advantium speedcook microwave, but after reading the instructions from the tip below, I was able to take care of it myself.
I ordered the parts online and , after unplugging and removing the unit from the cabinetry, I was able to follow the instructions as suggested by UNCLEMOE.
The only difference was that there were many more screws holding the cover in place. I removed all of the screws around the top and sides at the front edge of the microwave as well as the screws along the bottom of the sides and around the top and sides of the back panel. There is one additional screw that must be removed before the cover can slide back. This screw is on the right side of the microwave in a silver dollar sized indentation.
Oh, don't forget not to touch the halogen light bulb with your bare hands to avoid shortening the life of the bulb.
http://www.fixya.com/support/r650818-change_bulb_ge_microwave_jes1289sk01
It's crazy that GE should expect customers to pay a technician $100 each year to replace a simple lightbulb, but thanks to FIXYA.com I was able to do it myself in about 40 minutes with a little help to lift the unit.
as a side note, one of the screws was in so tight that the screw was stripped in an attempt to remove it. A little thing called GRABIT and a power drill took care of that problem in no time. check it out at 4GRABIT.com
on Aug 27, 2008 | General Electric Advantium SCB1000M 975...
Line stuck in my ryobi RLT30CDNB
Try an easy out tool found at any hardware store. First use the appropriate size drill bit out the easy out kit and drill into the damaged part of the screw, then use the easy out tool in a drill in reverse slowlyuntil it grabs the screw and backs it out. You could get some PB blaster lubricant and spray the screws, Trust me yould never use WD-40 again. Hope this helps.
Nov 11, 2011 | Ryobi Garden
How to remove a sheared bolt from washing machine
There is a product called Grabit that should work. It comes in different sizes. You should be able to find it at a home improvement store or a hardware store.
Dec 28, 2010 | Garden
Tryin to take a starter off and can't get the top bolt off?
try some liquid wrench or pb blaster penetrating oil and let it soak. using a breaker/cheater bar. if the bolt head is rounded off, try using a damaged fastener removal tool such as grabits.
Jun 30, 2010 | 2001 Kia Sportage
Remove stuck brake drum
you have to get a brake adjusting tool and a screw driver....
put the brake tool in and locate the adjuster wheel, use a screwdriver to release the locking prawl, its tuff but doable.
If there are no access openings to the adjuster, either in the drum or backing plate, then you need to work it off with a few pry bars
Sep 15, 2009 | 2003 Toyota Corolla
My collet nut is stuck and I cannot remove it. Is there a trick to removing a stuck collet nut?
remove all the star head screws, unscrew the top plastic collet holding the plastic outer casing on. take a pair of vise grip locking pliers open the plastic casing just enough to expose the inner shaft inside the casing lock the vice grips onto the metal shaft between the bearing casing and the collet that is stuck enough to hold but not to dent it up. now that the vice grips are locked onto the main shaft get an adjustable wrench and size it to the collet screw size and turn it should come off rather easily or at least mine did just did it as i wrote this then screw the casing back together and happy dremeling hope this helps
Jun 27, 2009 | Dremel Variable - Speed Multipro Rotary...
I have a Maytag Model MGR5770ADW and it appears that the left side door hinge spring is broken. How do I remove the side panel to investigate? Thanks, Ken
no need to remove the side panel, the door itself lifts off the hinges, and it will be reall obvious, if its broke, theres no servicing it just replace, and its done from the fornt, 2 screws and the hinge falls into the unit ( can grabit from pulling out lower storage drawer. part number (74011141) , might as well replace he 2 hinges one broke whos to say the right one is gonna last much longer
Dec 07, 2008 | Maytag MER5755QAS CleanDesign Electric...
Collet base removal
Try using a tapered wood screw or sheet metal screw as an extractor. Choose one of a size that will let its tip go down into the broken collet and get a grip when you twist it. If that fails, you might use a screw extraction tool.
Oct 12, 2008 | Dremel Variable - Speed Multipro Rotary...
Replacement of burners charmglow 810-6320B
The only way I was able to get the screws out was to use a 5/16" cobalt drill bit to drill through the center of each screw. Then, and only then, was the GrabIT screw extraction tool able to grip and remove each screw. Of course, I had to break off what was left of the burned out burners first to get easy access to the screws. To replace the burners, remove 3 screws (in an L shaped pattern) from the left side of the burner control panel. I did NOT have to remove the utility shelf to get to these screws. The control panel can then be moved forward about an inch, thereby enabling the new burner tubes to fit into their gas spouts. TIPS: It was easier for me to attach the back of the new burners before trying to attach the fronts. I used new 6-32 machine screws to attach them. You'll need to look from the bottom of the burner control panel when attaching the front of the new burners -- to see better.
Jul 13, 2008 | Brinkmann Charmglow Stainless Steel LP...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
