Question about Vehicle Parts & Accessories
Left axel front
Doesnt seem to go in all the way making noise
    Problem Solver:
  • 5 Answers
What is the make and model please
Posted on Mar 13, 2014
Load poping noise coming from front axel on my side by side. Anyone know what this is?
I would check the hubs and make sure nothing is broken internally. Otherwise, you'll have to look at that front diff. If the oil leak is something new, you may have broken a ring or pinion gear in the differential. The pieces would be binding inside the housing, causing more damage. I would not drive it until it can be looked at, to limit any further damage.
Jan 12, 2016 | Cars & Trucks
I have a 2000 toyota celica gt with a manual trans. It's making a noise while your driving it. Someone told me the axel was bad so I replaced it. That wasn't the problem, but where the axel goes in the...
It could be a wheel bearing either the left or right side maybe both. When driving around corners note if the noise gets louder when turning either way, for example if the noise gets louder turning right then the left front wheel bearing is the problem, the same for turning left, the right front bearing would be the problem. If the noise stays the same and changing on acceleration or deceleration the problem may be more serious, possible a final drive issue like a bad pinion bearing ring and pinion gears.
Feb 13, 2018 | Toyota Celica Cars & Trucks
Knocking noise
Probably a bad "CV" joint on one of the front axels. The CVs go bad every now and then and are not too expensive to fix. Any auto shop can/will do the repair. You will need a new axel for left or right front.
May 14, 2014 | Honda Civic Cars & Trucks
1996 volvo 850 sw makes a clicking noise when turning left
sounds like the cv boot on the axle is shot...dont waste money on trying to replace the boot u can get a rebuilt axel for about the same price without the headache
Aug 22, 2012 | 1996 Volvo 850
Squeaking noise right front ?
not sure what type vehicle we're talking about here, although you can lube up the rack and pinion or grease up your upper, if so equipped, and lower ball joints.
Oct 06, 2017 | 2000 Jeep Grand Cherokee
2001 and 2002 jeep grand cherokee. while making hard left hand turn experience rumbling sound doesnt happen when driving straight or right turns. Cant decide if sound is from front or rear area
Try checking the bearing in the left wheel if the rumbling is on the left side. Sometimes bearings can be worn down and sometimes may even twist or bend.
Aug 21, 2009 | Jeep Grand Cherokee Cars & Trucks
Subaru cv axle noise?
Do you know if this car has ever been recked? if your going thru that many axels makes me think something is not running true, a wheel bearing would not make a cv joint in a axel go bad. Did you replace the axels? or did you have them done at a shop, and did you see the old axels after they were replaced. You got bigger problems than a wheel bearing. From what i can gather some thing is bent or your getting bunch of bad axels witch i dought.
Feb 05, 2009 | 1987 Subaru Gl 4WD
Problem with left front wheel
Check Speed Sensor at that wheel or if something is Rubbing against the Pickup unit on Outer axel
Feb 03, 2009 | 2002 Dodge Durango
Front end clicking noise on 96 subaru impreza
jack the wheel up and and sharp spin left and right should help you locate the problem. did you change both sets of the universal joints, if so did you really pack them well with the grease as sometimes if the grease is not well packed you can get a dry spot and this will heat up and become damaged.
Jul 03, 2017 | 2006 Subaru Outback
Vehicle Parts & Accessories Logo
19 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
