Question about Crafts & Hobbies
Not receiving orders
Dip and chip bowls and 2 other model cars
3 Suggested Answers
SOURCE: The head of the mixer seems to dip to deep into
Hi, Put your mixers head in upright position and adjust the screw between the head and the stand. This will rise the head (one rotation is about 1 mm) and the attachement will not scrape the bowl.
Posted on Aug 12, 2010
  • 44 Answers
SOURCE: Where can I get an elegant 2 piece chips and dip serving bowl?
this serving dish got some great reviews
http://www.crateandbarrel.com/2-piece-chip-and-dip/f15006
Posted on May 06, 2013
How much does a dip chip cost
Do you mean a Dual Inline chip? If so, the costs range from $0.01 to hundreds depending on the chip, most are cheap. DIP refers to the pin layout and nothing more, so knowing only this doesn't help much.
If you mean a specific DLP for your TV (I'm guessing since you posted this in the TV & Video section) then something around $50 is common. The exact chip required depends on your make & model of TV.
Nov 13, 2017 | Televison & Video
I put in an order at the end of last year, my order ID is 111-6534875-6018639.There was a delivery on about the 31St December 2014 my order was 1 book short and said the missing book would be delivered at...
You will have to contact the seller on this one. I have unfortunately seen this before and it is usually a scam. Most likely what you have received is stole property and all that you will receive.
Feb 20, 2015 | Sport & Outdoor - Others
I HAVE CRACKED THE BOWL BELONGING TO MY COOKWORKS FOOD MIXER. MODEL NUMBER: HY-1801. CAN I PURCHASE A NEW BOWL?
You can place an order with the concerned dealer close to you , order the bowl for the model you have as it can be ordered from the company .
Jun 14, 2011 | Microwave Ovens
I have purchased model #20050611. Can I smoke with wood chunks only and not use charcoal? Do I put the pre-soaked wood in the flame disk bowl or the water bowl? I am used to a double barrel wood smoker...
Wood only. No Charcoal. If you're using wood chips - soak them first. No sure wood chunks will work, as they will have a tendency to flare up & burn rather than smoke.
The presoaked wood chips go in the flame disc bowl, below the water bowl. The water bowl goes on the first shelf bracket from the bottom up.
I was going to send you a copy of your Owners Manual, but the Model Number you listed does not match up with any Masterbuilt Smokers?
Enjoy your smoker,
Apr 21, 2011 | Masterbuilt 20050106 Propane Smoker
Light comes on all by itself
You are probably picking up some kind of radio interference that is causing the receiver to think a remote has sent it a signal. A possible solution to this issue is to change the frequency that the remote uses to communicate to the receiver to turn the fan or light on.
I have had the same problem with the light coming on intermittently by itself. At first I also could not change the settings and have the remote work with the new settings. But I found out that when you change the dip switch of the receiver you must turn off the power using the wall switch or the circuit breaker and turn it back on before the receiver will use the new dip setting. I am still waiting to see if the light will come back on after changing the dip switches from 1-on, 2-on, 3-on, 4-off to 1-off, 2-on, 3-on, 4-on and the remote's jumpers from 1-jumpered, 2-jumpered, 3-jumpered, 4- no jumper to 1-no jumper, 2-jumpered, 3-jumpered, 4- jumpered.
These directions are for the Hunter 27157 model.
Aug 12, 2010 | Hunter 27185 Remote Control
The head of the mixer seems to dip to deep into the bowl. It is scraping the bottom and chipping the attachment.
Jun 30, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Cannot set remote code for fan/light(dip switch)
The remote dip switch setting must match the fan receiver dip switches. Set them both to 2 on
Jul 04, 2009 | Hampton Bay 52 In. White Redington...
Processor short-circuit.
I just crossed referenced that part, and the sofware couldn't find it. You need to find out what manucturer it is, then go to that web site and order it. How many pins does it have? Is it a sip, or a dip chip? sip stands up with pins at the bottom., dip lays flat with pins on both sides. You may have to order that from the product manufcturer.
Jul 01, 2009 | NAD T752 Receiver
I bought a hampton bay ceiling fan model uc7083t but i didn't
hi there i can help. There is a "dip switch" on nearly all fan remote units, much like a garage door opener has. To keep all the fans in your home from operating at one time, each fan needs a seperate "code". To use your other remote, you need to locate the receiver unit in the fan, usually in the "canopy". This is the bowl looking piece against the ceiling. then note the "code" which is the position of the switches. For instance, most have a block with 4 switches, and if the first is "on", and the remaining are "off", that is it's set code. This "code" can be changed to any combination of "on , off" that you like. BUT, you must also open the remote control and set it's switch to the exact same "Code", or order of "on off" as your Fan receiver. (Usually the control "Dip switch" is in the battery compartment.
Jun 19, 2009 | Hampton Bay 24002 Ceiling Fan
Crafts & Hobbies Logo
73 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
