Question about Dishwashers
Remove filter diplomat adp 8640
Diplomat adp 8640 remove filter and clean
suben
  • 214 Answers
SOURCE: i need a detailed diagram
there's no diagram for that
Posted on Aug 28, 2008
  • 1462 Answers
SOURCE: diplomat adp 8520 dishwasher no hot water
two things to check
check continuity thru heater
remove outer door panel and check for faults in wiring loom
get back to me is these are both ok
Posted on Nov 14, 2008
SOURCE: diplomat dishwasher adp 8322
i had same problem and have found that under the lower basket the connecting bar to the spray arm had become detached this can be reattached by inserting the two nozzles back into position and pushing down youll see what i mean ! however i have found i now have to do this after every wash ,am currently onto diplomat to rectify this completely , hope this is any use.
Posted on Nov 28, 2008
SOURCE: diplomat adp 8242 beeps twice one flashing light
Turn off plack power button, turn back on, then press cycle selection button 4 times very quickly. flashing lights should change, shut machine and it should fire up and work...... it worked for me. May have to try it several times as getting the 4 button press timed right can be a bit tricky.
Posted on Jul 23, 2009
ginko
  • 19396 Answers
SOURCE: need an instrution manual for
Hi.
Here the manual:Diplomat ADP8352-UM
Posted on Aug 21, 2010
The door leaks on my Diplomat HJA 8640 DISHWASHER. I have changed the door seals with no luck
Malcolm,
Good for you replacing those seals. Not trivial, I suspect.
Does your DW have a positive latch closure or does it just close without a latch?
If the opening of your unit has become distorted due to gradual settling, even a new seal won't work properly. Look carefully and make sure the unit is "square" in the enclosure. If not, use the leg adjusters to correct the situation.
Also, when you replaced the seal, you no doubt cleaned the door thoroughly, since debris can accumulate (especially along the bottom of the door) and interfere with closure.
Use a flashlight for a thorough visual inspection!
Oct 24, 2016 | Dishwashers
Dishwasher not working but deeping twice
This is just a guess but it sounds like there is a flow meter on the drain hose somewhere that is bad.
Dec 10, 2013 | Dishwashers
Diplomat ADP 8352 starts ok but then, after the water pump kicks in it starts to make a laboured noise. I imagine its a motor starting to go but its giving out an awful smell. Any ideas which parts it...
The filter is probably blocked.
It is inside the base of the machine.
Take out the filter and clean it and also clean out the filter well as that can also hold quite a bit of debris.
Please dont forget to vote this answer was helpful.
Many thanks
Feb 22, 2011 | Dishwashers
Diplomat dishwasher bleeping showing FA
We have just experienced an FA audible error on our Diplomat ADP 8332 dishwasher...after pulling the dishwasher out and removing the low front panel we found the drip tray full of water. We tipped the dishwasher onto it's front and removed the drip tray and found a float pressure switch...it appears that once the drip tray is full the float switch activates and causes the FA fault (prevents the dishwasher from continuing) drain off your drip tray replace all covers and you should be good to go!!
Sep 16, 2009 | Dishwashers
Gas hob is permanently igniting
hi gud day,try to clean the area of knobs by using vacium,remove all the knobs firts then clean it,unplug the unit before u clean.
tnx gerbee
May 19, 2009 | De Dietrich DTG775X Gas Hob 22 in. Cooktop
Diplomat adp 8520 dishwasher no hot water
two things to check
Nov 14, 2008 | Dishwashers
Diplomat Dishwasher Model ADP 8132
Please can you give me the dimentions of this Dishwasher Diplomat Model ADP 8132, as I have got to get a replacement and have been told that the Hotpoint FDL570X is the replacement offered,Many Thanks,
Mar 28, 2008 | Dishwashers
Diplomat dishwasher adp 8322
Mar 09, 2008 | Dishwashers
Dishwashers Logo
22 people viewed this question
Top Dishwashers Experts
Owen Barnes
