Question about Measuring Tools & Sensors
Why is my water coming out of my Culligan Super S softener grey?
My Culligan Super S water conditioner is giving me light to dark grey water after a regeneration cycle. Will last for a while before next regeneration occurs and then it gets dark again. Almost like dyed water, not sediment (i.e., the water can sit in a glass indefinitely and not clear up). Have whole house filter from well, which feeds Medallist Gold Series softener, which feeds the Super S before distribution to the rest of the house. Any suggestions?
  • 384 Answers
SOURCE: I just cleaned out the salt chamber of my Culligan
Be careful this model of Culligan is actually a allen transport time machine. This is the reason it operates at night. If you where not sleeping you can hear the noise as an allen is transported to your pipes. For your safety keep all drains covered. Manually regeneration will regenerates all those little buggers. Please cover your head with tin foil to prevent the allens from reading your thoughts.The 50's warning Duck and Cover, in this case should be changed to Flush and Cover.
Posted on Sep 08, 2009
  • 175 Answers
SOURCE: No salt leaving Culligan softener during regen
It sounds like your salt in your salt compartment is stuck. Poor about a couple of gallons of hot water on top of your salt and see if that will break it up and fall down to the bottom of your salt container. Then regenerate your softener after about 3 hours have gone by. You should be back in business.
Posted on Nov 20, 2009
SOURCE: I have a culligan,gold series water softener.The
call your culligan service department. they will tell you what to look for.
Posted on Dec 22, 2009
SOURCE: The phone icon is on calligan water softener, how
I have the same problem. Did you ever figure it out?
Posted on May 26, 2010
  • 8 Answers
SOURCE: water softener is inoperative and is displaying E1
Usually, an E1 error code means the circuit board is bad. Try unplugging the unit for 5 minutes. Upon plugging it back in, if it does not reset itself, that means you need a new board. It is really easy to replace ( just a few wires) and will cost around $160.
Posted on Jul 21, 2010
How to. Bypass water conditioner of Culligan Estate 2
At the top of the conditioner, there is a tube running across the back of the head near the water line connections. the tube has push knobs on each end. With the blue knob pushed fully inward (knob up against the barrel of the valve / tube), water is routed through the water conditioner where it is softened. Water may be bypassed around the conditioner by pushing the red knob fully inward. Avoid "slapping" the valve when shifting from one position to another. see manual here: https://www.culliganmidmissouri.com/wp-content/uploads/2010/05/Estate2-Softener-Operating.pdf
Aug 22, 2017 | Culligan Measuring Tools & Sensors
Two years ago I changed the size of my Culligan holding tank under the sink to a bigger unit and at the same time put in a culligan water softener that also removes chlorine. I also changed the culligan...
hi.
im a plumber and i have seen it meny times befor. relax its calk thats in the water, its harmless and most gps wil tell u iets good for you lol
if it dos freak u out u may wane install a finer vilter sustem
Jul 07, 2010 | Culligan Sales #SY-750S Under Sink Water...
I'm looking for info on Culligan Super "S" water conditioner. Serial # V06244773 Part# 01014773 Can I get a manual? The water smells like rotten eggs. I need to know does it uptake bleach every 30 days or...
The Culligan Super S filtration system needs to have 1 gallon of 5% household bleach at least weekly. If your water is high in H2S it needs a gallon of bleach with every regeneration. Set the system to regenerate every day for 1 week and bleach at least 3x that week. Super S filters are recommended to be re-bedded every 750,000ppm. Regen cycle example: 2ppm iron, .5ppm H2S this system is set to regenerate every other and use 1 gallon of bleach per week. This system is now 13 years old and has exceeded the 750,000ppm suggested re-bed but is still performing with great water.
You also need to check the water heater to see if smell is coming from there. The anode rod in WH degrades and gives off a sulfur type smell. Here is a link for the Super S manual.
http://www.eculligan.com/support/supS-op-inst-manl-from1997.PDF
RJ
Jan 05, 2010 | Culligan Sediment Water Filter
I need a culligan n8 custom water conditioner manual
The Culligan N8 Custom and Estate 2 water softener systems are basically the same system. Here are a couple links for N8 manual to reset timer and Est 2 manual for other settings on systems that have "DIP" switches to set gallons settings.
http://www.culliganprowater.com/timer-reset.aspx
http://www.culliganwater.com/residential/resources/pdfs/reference/household_and_commercial_circuit_boards.pdf
RJ
Dec 27, 2009 | Culligan Sediment Water Filter
O-rings leak on a culligan mark 50 water conditioner
Neither a manual or parts are available for this this valve. It is obsolete.
RJ
Nov 22, 2009 | NRS Fleck 5600 - 64,000 Grain Timer Water...
I NEED A SERVICE MANUAL FOR MY CULLIGAN WATER SOFTENER. MODEL# 01014556 SERIAL# 2903H0010
Your best course of action is to contact Culligan here:
http://www.culligan-store.com/contact.asp
Nov 15, 2009 | Culligan Sediment Water Filter
To much salt in the water
The final rinse setting may have moved, which will coincide with the salt/brine draw rate...the Culligan units have a funny way of doing exactly that, which, by the way, can generate a lot of revenue for them, if your on a salt route for them to deliver it to you!....I would look up a qualified and TRUSTWORTHY!!! Culligan repair tech, or a service manual to reset this final rinse.
Mar 26, 2009 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Measuring Tools & Sensors Logo
59 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
