Question about Freezers
Whirlpool ev171nyms04 It will not start power is on turned dial to max and nthing
    New Friend:
  • 41 Answers
Hi
Replace your thermostat. if it does not work you have a motor problem.
Posted on Feb 23, 2014
Electrolux freezer will not turn on automatically when termperature warms in compartment, controls don't appear to turn compressor on, any help would be appreciated?
Sounds like your thermostat is bad. You probably have to replace it and the sending unit also. Big job! Look for a manual at : http://www.servicemanuals.net
Apr 28, 2014 | Electrolux Freezers
The door on our older freezer was left open. 2days later I noticed it. The unit runs but comp hums but cooling coils are not getting cold them dial does not shut unit on and off. Without schematic I don't...
chance are that the frost has turned to ice if the unit started to defrost then got cold again.do a full defrost and then try starting from warm....
Sep 25, 2010 | Whirlpool Freezers
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Whirlpool ED25RFXRWFreezer/Fridge temps unstable...either too hot
check the defrost timer but the cold control could be bad
Mar 01, 2010 | Whirlpool Freezers
Freezer won't turn on at all
First , disconnect the power to the freezer . Remove the thermostat ( piece with the dial ) and put the 2 wires togather . Reconnect power and see if compressor will start . If so , then the thermostat is bad . You would have to order from a parts house .
Sep 05, 2009 | Freezers
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 | Freezers
I have a whirlpool freezer, the red light on the front is on and the food appears to be not fully frozen. I have turned the temp dial up a bit but the light stays on? I can't find the book that came with...
The light is there to indicate there is power. If it is running constantly and still not cooling properly there is a problem in the sealed system (or the door is not sealed completely, but there would be a lot of frost were this the case. Here is a link to where you can find the manual with a complete model number.
HDR-SR12E Eric
Jul 02, 2009 | Whirlpool 10 cu. ft. Chest Freezer...
Bought a chescold finch 3 way fridge but no instructions - help
The max/min gas flame is for adjustment of temperature when using the fridge on gas. The next one with 0 to 7 is possibly the electrical thermostat. I am not familiar with this exact model. One of the dials will be able to be pressed in. The idea is to press and hold this button in for about a count of five, then push the lighter strike. You will hear a click noise which is when a spark is delivered to the burner area. Some fridges have a small window or guage which shows if the flame has lit. You may have to look down the chimney. You keep holding the press button down after having depressed the lighter strike button for about five seconds. This allows gas to flow to the burner while the thermocouple heats up. Once the thermocouple (which is a small copper probe sticking almost into the flame) heats up, it will keep the gas valve open and if you then release the button, the flame will continue burning. The idea is that if the flame were to blow out, the thermocouple would cool and in turn act as a safety by shutting off the gas supply. Hope this is enough info.
Mar 05, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Kenmore chest freezer
check light inside .on? you got power. check compressor in back on? if no then you probably have a bad stat. open door and look inside for numbered dial. turn max hot to max cold back and forth. if compressor comes on you need a new stat probably. remember only a stat a compressor on these units. if its hot stat should send power to compressor. if power is arriving at compressor and not running then start relay and or start cap are probably bad. but if compressor is running and still no cool then your probably out of freon. unfortunitly these boxes are made with steel tubing in the cabinets. when you move them lots of times the tubing rusts and ruptures. then your all done. new freezer time. they are sealed to the point there are not even a place to apply gages to check charge. you can gently remove power and then stat and jump thermomstat to take it out of equation and if compressor runs you need a new stat. constant power comes in one side of the stat and when the sensing tube is heated it closes the points to the outlet side and puts power to the compressor. there may also be a ground wire usually green be sure to observe which two are power in and power out. usually side by side. good luck
Oct 25, 2008 | Freezers
Freezers Logo
62 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
