Question about Dell LATITUDE Computers & Internet
Turn on computer and it says no bootable devises resart
    Habit-Forming:
  • 152 Answers
Please check if any removable disk is inserted, if so remove and reboot ,else OS has been corrupted need to reinstall the OS.
Posted on Feb 17, 2014
How do i fix a encore 2 toshiba with a message that says no bootable device resart system how do i do that
You should check in your BIOS settings to make sure your internal hard drive is designated as your primary boot device. If it is and the system still does not boot up, you either have a bad hard drive or the ribbon cable has come loose. There is an outside possibility that your MBR (master boot record) has become corrupt and the drive would have to be reimaged.
Mar 04, 2015 | Toshiba Tablets & eReaders
So I lost my temper and slammed my Gateway
Check the hdd connector for damage.
Sep 26, 2014 | Computers & Internet
Bootable devise was not found new
Bootable device not found actually indicates the HDD (hard disk) is no longer recognised and either needs to be re-seated or replaced, if the bootable device error message comes up all the time the it will be a definite HDD replacement.
Oct 09, 2013 | Fujitsu LifeBook AH530 NoteBook
I just bought an little Hannspree SN10E288 with Linux. I can not install XP because all the partitions are unknown for Windows.What can I do for it.
Try the following, You need a bootable Windows CD/DVD for this
(1)Set your BIOS setting to boot from CD/DVD ROM first (before the Hard Disk or any other media)
(2)In order to set this priority resart your computer and as the first any information appears on screen start pressing "F2" and "DEL" keys swiftly and alternatively. A new screen appears....
(3)Look for "boot priority" and take the CD/DVD drive on top of the list. You need to experiment this a little because every PC BIOS has a different format to make these settings
(4) Insert your bootable Windows CD/DVD in your computer and boot from it.
(5)You will be asked to Press any key to boot from CD.......
(6)Press any key
(7)The Windows installation screen will appear.
(8)In the setup carefully select delete and select the partition where you want to install Windows.
You should have adequate space for Windows.
(9) Be careful do not touch the partition where the Linux is installed
(10) Once you have deleted the partition carefully Format it or make a Quick format.
(11)After that your Windows installation should start.
The rest is very intuitive......
Oct 06, 2010 | Computers & Internet
Cant start windows
The no bootable device found or the promary disk not found error can be caused because of the following reasons
1. The operating system has crashed
2. The harddrive is faulty.
Try the following steps
1. Remove any cd if there is in the optical drive
2. Disconnect the Ac adapater and remove the battery
3. Press and hold the power button on the laptop for 10 seconds
4. Reconnect the Ac adapter
5. Power on the laptop and press F12 key on the keyboard a couple of times slowly on the Dell screen
6. Select Hardrive diagnostics from the list
7. If the harddrive returns with an error code , you would need to replace the same
8. If not then, restart your computer and press F8, a couple of times on dell logo screen
9. Select safe mode from the list.
Use the following wizard
http://tinyurl.com/56ym45
Thanks
Proton
Nov 19, 2008 | Dell Inspiron 700M Notebook
Primary hard disk not found
ok
when u power up the computer press F2 or delete or F8 or F12 key try one by one.
ten u enter in bios.
go to driver configuration.
u see harddisk option detect your harddisk .if u see your hardd isk then no issue.also go to boot option.then set your hard disk as first boot device.
then save all settings.
thats it.
try also to remove battry form laptop then again attheched .
Modem wont dial out modem query failed say port in use
go to control panel > system> go modem and uninstall modem > resart pc > co back to system > up top of page click action >system changes, the modem should reinstall, in not pick any devise and yninstall it, go back to action and choose system change, booth the device you uninstall and the modem should reinstall
coastal-connection.com
Aug 02, 2008 | E-Machines Computers & Internet
Computers & Internet Logo
Alun Cox
