Question about Toastmaster 200 Waffle Maker
How to clean model 230
I know you can't submerge the unit, but can i scrub it and run it under water?
  • 2,119 Answers
Probably not safe to put under running water. Water will get inside of the unit. You can scrub the grids with dry baking soda and a plastic brush or scrape out stuck waffle parts with a wooden stick or a bamboo chopstick. One trick to use is to add cooking oil to stuck parts and allow them to cook before trying to scrape waffle parts out.
Posted on Jul 30, 2014
Hoover problems
A high pressure water hose nozzle after first submerging assy. to soak for a few hours ( the dirt and grime build up with time, and dry hard, blocking passageways.
Jun 15, 2014 | Hoover Power Scrub Deluxe Carpet Washer -...
How to clean and service the voltas vertis platina split ac?
The filter is behind the front panel on the indoor unit. Look for a thumb or finger grip at each side of the panel and lift the bottom of the panel out and up. The filters should be seen as soon as you lift the panel. The filters will slide out. Wash them under running water by hand. Don't scrub , vacuum or brush them. They are quiet fragile and any harsh scrubbing will damage them. Cheers.
Mar 27, 2014 | LG L1204R Air Conditioner
DELL VOSTRO 230 PROBLEM
Your computer is toast! If it was submerged in water, your motherboard, hard drive, memory and power supply are contaminated.
Jul 03, 2012 | Dell Vostro 230 PC Desktop
Ive got a flashing clean light and the dishwasher won't run. Is there a reset button or a common part that causes this problem?
Flashing clean light on a Whirlpool dishwasher is a heater malfunction (sorta) this failure code is generated when the unit does not sense a 5 degree rise in water temperature with in 15 seconds (give or take depending on model) some of the earlier models could show code under certain circumstances such as incoming water to cold.
With control off alternately press high temp scrub and heated dry till all the lights flash on and it will go into a diagnostic mode hit cancel/drain button twice and retry using the dishwasher if the code persists try running Your kitchen sink until water is hot then running the dishwasher if the code comes up again begin inspecting the heater in bottom of wash tub for damage or signs of shorting also pull out from under the counter to inpect wiring to the heater, if these look good test the safety cutoff towards the front bottom of the unit small black and silver button sized componant with two wires to it for continuity.
Still ok remove the thermistor from bottom of pump and clean it and test the ohms according to the tech sheet on the back of the toe panel on front of dishwasher, if this is ok test run the dishwasher with a high temp scrub option selected and test voltage to the heater at the two connectors directly at the heater if there is no voltage and You have properly checked the previous items the control has a bad heater relay and will require replacement.
Mar 28, 2010 | Whirlpool DU1055XTSQ Built-in Dishwasher
Our clean light flashes 7 times pauses and flashes 7 times again, we can not restart the unit whats could be wrong
This machine was made by Whirlpool and the flashing clean light is a common error code for them.If the clean light is the one flashing then your dishwasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has until all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
Press the heated dry button followed by the normal cycle button, and then repeat once. You should see all of the lights come on for a second or two, and then the dishwasher will work again.
If you haven't already, take a look under the kick plate in front to see if there is a schematic tucked in there somewhere. Whirlpool has put their diagnostics for specific models on these.
I don't have the specific repair manual for you model.
So, if the above combination does not work here are two more that have worked for me.
HiTemp Wash + Air Dry + HiTemp Wash + Air Dry in less than 5 sec
or
Hi Temp Scrub/Scour + Air Dry + Hi Temp Scrub/Scour + Air Dry in less than 5 sec
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 30, 2009 | Whirlpool Dishwashers
Juice on pi-1536 keyboard and touchpad
Juice on keyboard ?? Disconnect ALL power immediately!! Then, remove keyboard, run under quite hot tap water, then immediatey submerge keyboard in isopropyl alcohol in a shallow tray, place in a beach towel & with washing machine water OFF, spin the unit in towel, allow 24 hrs to dry in sun, reinstall. It works.... If LAPTOP got drenched, stand on side, with screen open, dry thoroughly 2 days, pray a lot,
Jun 21, 2009 | Fujitsu Siemens Computers & Internet
Farberware 4 and 12 cup percolators stopped making good coffee
I thoroughly cleaned my 4-cup percolator by brewing a couple of pots of plain white vinegar and scrubbing the build-up from the bottom of the pot (and running a couple of plain water brews through the pot after all the cleaning). The percolator now brews hot, strong coffee again!
Nov 05, 2008 | Coffee Makers & Espresso Machines
Fridge problem
usually the smell is the water dripping into the pan under unit place cleaners and use charcoal inside unit to remove odars that collect on evaporator and get concentrated then go to drip pan
Feb 11, 2008 | Frigidaire FRT17G4B Top Freezer...
Toastmaster 200 Waffle Maker Logo
117 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Henry  Thomas
Henry Thomas
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
