Need to reset lamp timer after replacing lamp SONY XL-5100
ctf1800
  • 4402 Answers
SOURCE: How to reset lamp timer
press and hold the "enter" button on the TV, the press and hold the "menu" button on the zenith remote-- after several seconds of holding both buttons the option of re-setting the lamp came up. Hope this helps
Posted on Jan 18, 2008
Slinteriors
  • 8617 Answers
SOURCE: lamp replacement
The file is too large to post here but if you post your email address, I can send you the step by step instructions to replace the lamp and reset the lamp hour counter.
Posted on Mar 03, 2008
  • 47 Answers
SOURCE: Lamp timer reset
You will need the remote that shipped with the television. Take it with you up to the television then press and hold the VOL- button on the TV and the SPLIT button on the remote. Message should say "lamp time was reset to 0". Make sure the remote is in TV mode and aimed at the TV's IR sensor.
Posted on Mar 09, 2008
SOURCE: Need to reset the lamp timer / Panasonic PT-43LC14
hold the volume down on the TV and press and hold down the MUTE button on the remote control. Be sure to hold both buttons down at the same time and until the red light goes out.
This worked for me.
Posted on May 03, 2009
SOURCE: projection lamp timer reset
The others are almost right. You first hold down the minus button on your "TV", then at the same time hold down 0 on your remote. Make sure if you have a universal remote to swich it to TV.
Posted on Feb 27, 2010
How much is a uhp lamp 120w xl-5100
Original lamp USD100
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jul 24, 2014 | Sony XL-5100 Projector Lamp for Grand WEGA...
Lamp blew, picture went then sound also. Replaced lamp, now will not turn on. Red light flashing on front switch panel.
If the red light flashing 3 times the pause and again flashing 3 times, check and make sure lamp cover is installed correctly back on tv.
Sep 05, 2011 | Sony KS 50R200A Replacement Rear...
I am trying to figure out how to replace my replacement lamp, but do not know where it is located.
Lamp Access door for Sony KF50WE610 is below the screen on the front of the TV. This page shows location of Lamp access door and DIY bulb change instructions for most SONY LCD TVs:
DIY Bulb Installation Guide
XL-2000 XL-2100 XL-2200
XL-2400 XL-2500 XL-5000
XL-5100 XL-5200 XL-5300
This page shows Lamps and bulbs for all Sony LCD Projection TVs
Sony Lamp Gallery
Look at Optical Engine Faults before buying a lamp or bulb. Replacement bulb will not repair these problems.
Feb 05, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Just lost the picture and now the lamp light is flashing
If lamp light on Sony TV front start flashing that means Lamp is dead and need to be replaced.
Lamp replacement is easy and procedure would be written in user manual of TV.
Dec 20, 2009 | Sony XL-5100 Projector Lamp for Grand WEGA...
Sony KDSR50 - TV comes on then goes to a black screen - sound is fine. In the 2 or 3 mins of TV visual time, the color looks a bit off - lacking red - could this be a bulb problem? Bulb does not look...
Hi
Its symptom of weak lamp so TV needs new lamp.
Lamp replacement procedure is written in user manual and lamp part number is as follows..
F93087600 Lamp Block XL-5100
Available in Sony Accessories Store, please buy Sony Original Lamp for TV safety.
Jun 26, 2009 | Sony KDSR50XBR1 50" Projection HDTV
How To change Sony XL-5100 Projector Lamp with housing
  • Installation is Quick and Easy:
    In most cases, replacing your projection lamp is quick and easy. However, it is recommended that you consult your owner's manual for more detailed instructions:
  • Unplug your TV from your power outlet
  • Allow the lamp to cool for at least one (1) hour before replacing it
  • Remove the Lamp unit cover (Usually located at the rear of the television)
  • Unscrew the lamp housing unit
  • Remove the old lamp housing unit and discard
  • Screw in the new lamp housing unit
  • Place the cover back onto your TV unit Caution: Do NOT touch the bulb directly with your fingers.
  • Jun 15, 2009 | Sony XL-5100 Projector Lamp for Grand WEGA...
    KDSR50XBR1 won't stay on
    Thanks for update.
    Replace TV lamp and every thing will be OK.
    Avoid aftermarket lamps and buy original Sony Lamp under following part number from Sony Accessories Store.
    F93087600 XL-5100 LAMP BLOCK
    Feb 05, 2009 | Sony KDS-R50XBR1 50" HDTV
    Reset the time on the lamp
    Hi steelerector
    While the Projector is in standby mode - in other words just plug in the powercord.
    Hold down on the Projector's remote the left & right scroll buttons and press enter.
    This will reset the Projector's lamp timer.
    May 23, 2008 | Sony XL-2000U Projector Lamp for XBR800...
    Sony kf60xbr800 lamp
    Hi steelerector
    It is really easy to do , you will normally get a little manual on how to do this with the replacement lamp.
    Provided that the lamp is a original Sony lamp.
    If not , then just unscrew the lamp door at the bottom , take out the two screws that fastens the lamp to the Projector's inside , replace the lamp and screw it back in and then put back the lamp door.
    Then just remember to reset the lamp timer.
    May 17, 2008 | Sony XL-2000U Projector Lamp for XBR800...
    Televison & Video Logo
    22 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
