Question about LG LSC26905TT Side by Side Refrigerator
Leak on a LG side by side double door fridge/freezer at the bootom of the freezer door
  • 489 Answers
SOURCE: LG LRSC26923TT freezer not freezing error display
You have a defrost problem that requires a service call from a qualified LG technician.
Posted on Apr 29, 2008
jeffbvegas1
  • 520 Answers
SOURCE: LG French door fridge freezer not freezing
hopefully you looked out back ...rear lower panel and checked little white condenser fan running...it really needs too to keep temp stable across the condenser coils and no overheat condition to the compressor.hopefully you wont need the $300 circuit board like I just bought
Posted on Jun 26, 2009
  • 112 Answers
SOURCE: Dents in fridge door
Contact an automotive "paintless dent removal" provider-- they are mobile, so they can come to your home.
Posted on Jul 09, 2009
SOURCE: LG LDC22720SW ECU reads 5-6-7 on freezer side
I have a similiar problem with my LG refrigerator. The freezer settings get stuck on 6 and 7, while the refrigerator side is showing nothing. Pushing the buttons to adjust the temperature does nothing. The whole time, my food is getting spoiled.
Posted on Oct 18, 2009
  • 161 Answers
SOURCE: LG GR-349R bottom mount freezer gets heavy ice
Find the drain tube in the back and check it for a frozen state. If it si,use a hair dryer to thaw it. If it does it again, you have a defrost problem
Posted on Jan 22, 2010
Im looking at buying an LG fridge with the double doors and freezer on the bottom. It also has the ice machine and water hook ups but it needs a gas refill how much will that cost?
I wouldn't buy any modern fridge that needs a gas refill. Needing a refill means that it has a leak. Modern fridges are 'sealed unit' compressors and should NEVER leak. If they do then there is a leak, often in the evaporator coils inside the fridge and commonly between the copper to aluminium joins. These leaks would need to be repaired however most piping is not easily accessible. Cost may be $100 to $300 for re-gas plus repair $$$ and unless the leak was located and repaired then you will be re-gassing again in days, weeks or months.
LEAK needs FIX LEAK and re-gas.
Oct 21, 2016 | LG Refrigerators
I have a LG fridge double door top freezer model no GL-T262QM. the refrigeration compartment is not cooling.
ihave a lg.double door refri model T262QM about 7 years old. no cooing in freezer so i want to get cooling coil capaliry data i am technician
Mar 21, 2011 | LG LRTN22314 Top Freezer Refrigerator
LG Fridge-Freezer model no. GR-T632DVQ The upper freezer lights works. The lower fridge light stopped working. When tested the light bulb works and is NOT broken. There is a combination double...
looking for a door for lg refrigerator GR-T632DVQ
if anyone can help me plz ring 0421203100
perfect fridge, had it for 10 years, door fell off today :(
i've been searching everywhere, *sigh
please help if u can
Mar 16, 2011 | Refrigerators
I have a double door refrigerator, the top side is not working, only the freezer side wich is working.
It may be your compressor. There has been a lot of complaints about this fridge. If the vents are blocked, it won't cool. The fridge has been the one that always goes out, mainly because the compressor. You will have to get someone out to fix it. Hopefully, your warranty is still good.
Feb 18, 2011 | LG LRFD22850 Bottom Freezer Refrigerator...
LG Fridge Icebeam Door Cooling Refrigerator Freezer is leaking water into very bottom of fridge. Fridge is only 6 years old. What could be the cause of this problem ? Many thanks for feedback.
lg ice beam refrigerator which has door cooling also is not cooling properly. the freezer is working there was ice accumulated in the rear corner of the freezer i defrosted but still the fridge is not cooling and there is a pool of water at the bottom most of the time. sometimes i see the fan inside the fridge is not working
Jan 11, 2011 | LG LRTN22310 Top Freezer Refrigerator
How to resolve our "lack of water" issue..within the last few weeks, the water dispenser's water flow lessen with each day-now it does not just doesn't work
there may be a problem with the water lines or bottles in the fridge compartment is frozen raise the temp in the fridges to about 38 for a couple of days and this should unthaw the lines
Apr 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
Fridge not making usual humming sound
I had a same problem, However the fan in the freezer seems stop and the freezer compartment is melting. Its a double door LG with 270 ltrs.
Mar 11, 2010 | LG LRTBC1825T Top Freezer Refrigerator
Lg side by side refridgerator ice maker
you can adjust the control for the freezer side to a colder setting think of the freezer control as a door warmer setting door open farther colder setting door farther closed the fridge control is electric that runs the compresser can turn fridge down to creat more cooling freezer or set freezer to colder setting it is a balancing
act have actually closed freezer control to coldest setting and had items freeze in the fridge side where air from freezer first enters fridge a lower temp in freezer should help ice production
Dec 10, 2009 | LG LSC27931S Side by Side Refrigerator
Water leaking at bootom of freezer door
I would check the water connection under the toe plate....follow the water line that comes out of the freezer door.. check if that is where your leak is coming from..
Aug 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
LG LSC26905TT Side by Side Refrigerator Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
