Question about Acer Aspire™ T180 PC Desktop
Acer long beep when cpu turned on
When computer is turned on I get a constant long beep, and I've cleaned the ram, but still get the long beep, also monitor won't come on a keyboard doesn't work. Fan comes on and power indicator light comes on.
    Guru:
  • 219 Answers
I'm Electronics Telecom Engineer,webdesigner ,seo, PC support professional,Online teacher via skype I'll help YOU
to fix problem Please feel free to contact me anytime via e-mail at besubmitbe@gmail.com, or on Skype at bpshbp
Posted on Apr 21, 2014
  • 233 Answers
SOURCE: ACER Aspire- beeping sound - 6seconds when I power machine on
The beeps are telling you there is a hardware failure (POST). The number and length of beeps will give a better indication as to what has failed. Write back with that info and someone on this web site will interpret this for you.
Posted on Jan 19, 2009
  • 3 Answers
SOURCE: computer wont boot hear one beep from motherboard over and over
If your power supply is bad, there is typically a much cheaper way to fix it rather than purchasing a new one.
If you know a little about electronics or know someone who does have them open up the power supply and check the capacitors. Often times when a power supply goes bad its the result of capacitors going bad.
If you notice on the ends of any capacitors a brownish/whitish discharge or "bulging" then the capacitor has gone bad.
A new one typically cost less than a dollar and replacing it is fairly easy if you know how to solder.
Let me know if you have anymore questions and hopefully if this is the case you can save some money.
Posted on Feb 23, 2009
mrninja
  • 600 Answers
SOURCE: Computer stopped communicating with the monitor & keyboard
I agree, if you did a combo of keystrokes (re: cntrl+F5 for monitor) thats only a shortcut keystroke and should be able to do and undo all changes in "control panel">"display">"settings">advanced
Posted on Apr 22, 2009
leecom72
  • 4806 Answers
SOURCE: Get NO SIGNAL on Acer M1640~Monitor is Fine~Is CPU
Try removing the system memory and clean the brass contacts and the slots it goes into, then reseat the memory and try to boot again, the memory looks like this >>>>>>>
Good luck
Posted on Jun 28, 2009
byteguy
  • 2229 Answers
SOURCE: Acer desktop mouse,keyboard not functioning, monitor also not wor
If there is no display on the monitor, then your computer is not sending a video signal to the monitor.
This could be caused by a bad video card or some other hardware problem. I would open the case and disconnect all the devices (hard drive, CD, etc. Leave only the CPU, memory, and video connected. You could leave the keyboard and mouse connected too.
If your computer then starts, you can start to add devices (after turning the computer off) one at a time.
If this doesn't work, then you are looking at replacing the motherboard or just the video card if that is possible.
Posted on Nov 05, 2009
My Dell Inspiron 545 desktop computer beeps upon start up. It beeps 4 times pause and repeat over and over again. Also the monitor screen is black and won't turn on.
Try to open the CPU
when you open the cpu remove the ram clean it with eraser carefully
or if you have IP solution try to clean the ram with it and again install the ram
Apr 13, 2016 | Dell Computers & Internet
Cpu was working fine. stopped working of a sudden. turned off & on. 4 long beep, pause, followed by 2 beeps. number 3,4 come out on actual computer. nothing shows up on monitor. please help.
please check your ram is properly inserted if please remove your ram and insert it properly in slot before inserting in slot clean the slot and rub the ram strings with eraser and insert it. if ur using with 2 rams in 2 slot please remove one of the ram from cpu and check if problem persits again remove another ram from cpu
Sep 07, 2015 | Computers & Internet
Constant beeps
if there is beeps on it then its probably your ram has come loose or your cpu fan try to find installing RAM on PC on youtube there should be a video there and do the same for cpu fan ....hope this helps if you like you can google your pc's manafacturer error beeps like if its 2 short then one long it will let you know exactly is in error....bonnell
Apr 22, 2012 | Gigabyte Ga-g31m-s2l Motherboard Intel G31...
I turn the pc on nd the motherboard beeps like an alarm. I've pulled everycard out, ram, cpu etc and just left the fans plugged in, but the problem still persists.
The beeps are the clue to what is wrong: Count the beeps and check against beep codes like at http://www.computerhope.com/beep.htm
Check that *********** board is listed, some use slightly different codes...
Aug 07, 2011 | Abit IN9 32X-MAX Motherboard
My display unit of my ACER PC show no signal,but it is on. what can be the problem?
first shut down you computer remove the covers of the cpu then locate the memory and remove them wipe them clean with clean cloth and switch the computer on with out the memory and see if you hear any beeps if you hear beeps insert the memory and switch on the computer if still no beeps then remove the processor fan and clean the surface of the processor fan and the processor apply a thin layer heatsink solvent and clip the processor fan tighty to the socket
Jun 02, 2011 | Acer AL1716 17" LCD Monitor
Constant beep at startup
THIS BEEP SOUND INDICATE YOUR RAM/RAM SLOT PROBLEM
OPEN YOUR CPU AND REMOVE RAM
CLEAN YOUR RAM SLOT USING CLOTH
AND REINSERT YOUR RAM
T
PLEASE VOTE IF YOU SATISFAID
Dec 06, 2010 | AOpen AX34-U Motherboard
When I power up my acer PC I get a beep beep beep
Open your cpu cabinet cover.
Then Refix RAM memory on mother board.
Remove pci cards from mother board if any.
Make sure motherboard is not ground with cabinet.
Reattach ATX power connector to motherboard.
Pull cmos cell from motherboard for 10 minutes then refix it .
Then it work again.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 06, 2009 | Acer (AST135-U-S3100) PC Desktop
Beep codes
you check memory stick i mean extended ram surface clean with eraser or change ram
Sep 09, 2009 | Computers & Internet
CPU bleeping constantly.
Yes that means the computer has failed POST. So yes, something has come loose or has got damaged.
"POST" is an acronym for Power On Self-Test. The POST process checks the basic system functions before attempting to load an operating system. It checks RAM, processor, drives, system interface, etc. If POST fails, the system will normally halt and may produce a series of beeps from the computer speaker which can help indicate the cause of the problem.
Jan 17, 2009 | Computers & Internet
Asus Motherboard Constant High POST beep
long beep - memory bank is not plugged well, or broken
continuous beep - no power, loose card, or short.
Aug 01, 2008 | ASUS P4S800-MX Motherboard
Acer Aspire™ T180 PC Desktop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
