Question about Maytag M3X05F2D Air Conditioner
The push botton switch is broken and the part is not longer available what can I do
Any solution
GE SPACEMAKER MICROWAVE OVEN MODEL J VM64 003 LIGHT SWITCH BROKE HOW DO I REPLACE IT?
Unfortunately it appears none of these parts are avail anymore. The physical buttons, key panel assy, touch pad support are no longer available. The smart board (WB27X5239) seems to floating around, but this does not appear to contain either of the 2 buttons or switches as part of it's assembly. Pleazer Appliance..
Jan 11, 2015 | GE Microwave Ovens
Why is my on and off botton stop working tryed putting a new one on but same thing pushing in and out but not turning it on have to do it by wall main
Odds are the PCB trace on the control panel is broken for the switch from pushing hard on the ON button. You will need to repair the connections or replace the switch or replace the control panel. Good Luck
Jul 16, 2013 | Office Equipment & Supplies
Honeywell reset botton stuck
Buy some WD40 or CRC spray and using the thin tube that comes on each can, spray around each button to get penetration into the spring inside. Pump the switch until it loostens. If this doesn\'t work you need a new switch!
Dec 31, 2012 | Honeywell Heating & Cooling
4 wheel high not working
Is it a push botton switch on the dashboard or manual shifter.If it's a push botton switch,replace switch and if it's a manual shifter, replace transfer case solenoid.
Jan 04, 2010 | 1996 GMC Yukon
Push starter botton and sometimes it bump the
Probably a dirty contact in the starter switch on the bars, strip down inspect and clean, replace if broken. Maybe a flat or discharched battery, charge or replace battery. Loose cable to the starter, check and tighten. Relay faulty, replace with new. Starter soleniod fauly, replace. Starter motor fault, remove, inspect and repair, replace if required.
Oct 02, 2009 | Harley Davidson FXSTS Springer Softail...
Broken door switch
This would require an exact model #.
ie 110.88777
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
I have Altec Lancing ACS22 computer speakers. When I push the botton to turn the speakers on, the light won't come on - meaning they are not on. It takes several tries pressing on the botton at different...
Hello! The "DC IN" jack has bad solder connections on the circuit board or the "ON\OFF" switch has corrosion\dirt on the switch contacts or bad solder connections itself. Use a philips head screwdriver to disassemble the speaker and solder the "DC IN" jack and the on\off switch. Get "control cleaner" and spray it into the on\off switch. Push the button many times to clean the contacts inside the switch. Only one other thing could cause this problem and that's a cracked circuit board.That can be fixed by soldering jumper wires across the broken traces on the board. Good luck!!
barneyluc
Oct 20, 2008 | Audio Players & Recorders
Doesn't work at all
Check the door switch. With the door open, on the upper right side of the tub opening there should be a little lever. Push on it and you should hear a click sound. If the lever is broken or no click sound, you need to replace the switch. If that checks good check your circuit breakers and power cord and outlet.
Apr 08, 2008 | Kenmore 63032 Electric Dryer
Maytag M3X05F2D Air Conditioner Logo
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
