Samsung HLR6156WX/Xaa Hdmi
HDMI input is not working. Dvd player works on other TV's
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
You need drivers
Posted on Apr 25, 2014
4 Suggested Answers
shibuda
  • 1812 Answers
SOURCE: I have a Windows 7 Media Center PC, connected to
Set the resulation proper ,
If you need more information, reply me soon.
Thanks
Posted on Feb 20, 2011
kyocon
  • 104 Answers
SOURCE: trying to connect 46"samsung smart
200px-multiconnector-scart-chti.jpg magnify-clip.pngMulti-AV SCART adaptors with Input/Output signal switch (gold & nickel). A common misconception among game console owners is such connectors will allow RGB quality, while they are only CVBS and S-Videocompliant. THESE CAN BE USED FOR NON HD DEVICES SUCH AS YOUR DVD-VCR, AND SKYTOP BOX YOUR TV WILL HAVE AT LEAST 1 OF THE YELLOW WHITE RED COMPOSITE CONNECTION
Posted on May 05, 2011
  • 13 Answers
SOURCE: hp g62 hooking it up
its not right to use the VGA output ( Monitor output ) its better to use the HDMI output, plus you can't hear sound from VGA output.. so the best is HDMI
Posted on Aug 04, 2011
We have purchased a Samsung 55" Smart TV. We have it set up and working with Foxtel connected via the supplied fittings. How do we connect the DVD player?
The usual way is to connect it via a HDMI cable, for which the TV should have 2 or 3 input ports. You then select this HDMI as input on the TV to see a DVD playing.
Get a "high speed" HDMI cable. Some will say there is no difference between any HDMI cables, but they did see fit to increase the bandwidth in these cables for Blu-Ray DVDs.
Dec 27, 2016 | Samsung Televison & Video
Picture in picture operation & connection to dvd player
Now--first--connect the DVR cable box HDMI output to the HDTV HDMI input (use the lowest numbered one e.g. HDMI 1) for this connection. Use a standard (not Monster brand) HDMI cable for this connection. Then turn on the TV, turn on the cable box and switch the TV to the HDMI input. A picture should come on. You may even hear the audio on the TV speakers. If so, that is OK.
Then--connect the component video output of the DVD HT to the TV component 1 input. Use a three wire component video cable with red, blue and green connectors on each end. Connect color to color on both ends. Then turn on the DVD, put a DVD in the player and start it running. Switch the TV to the component input and it should show a pix. The audio will come from the DVD player speakers.
If your DVD player does have an HDMI output, you can use it and just connect as above to the second TV HDMI input.
To get audio from the cable box out of the DVD player speakers, you will need to connect an audio cable from the cable box go the HT amplifier. Use a set of RCA patch cables and go from the analog audio output of the cable box to the rear panel audio inputs of the DVD player. The owners manual for this unit will give directions on using this input. Since your HT unit does not have any other inputs, you will not be able to get Dolby Digital audio.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Good luck. Remember, the owners manuals all have hook up connections diagrams. Sometimes they will help.
Dont forget to rate me as fixya..
Jan 30, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
How do i program my sony dvd player dvp.sr200p to work on my philips tv
No special programming is required. Connect the DVD player to the TV using an HDMI cable. Note which input jack you used on the TV (example: HDMI 1 or HDMI 2, etc.) Turn on the DVD player and insert a DVD disc and play it. Turn on the TV and select the input you used to connect the DVD player (example: HDMI 1 or HDMI 2, etc.). You should now see and hear the DVD disc playing. Most settings are pre-set at the factory so everything will work without adjustment. However, both the DVD player and the TV have a Menu where you can adjust settings for picture, sound, etc. if desired.
Jan 01, 2016 | Sony DVP-SR200P DVD/CD Player
HDMI input says "mode not compatible"
If your Playstation is putting out the signal in 1080p then try changing it to 1080i and see if that works. Not all TVs are compatible with 1080p.
Aug 02, 2012 | Samsung Lnt4042hx/xaa
Samsung ps wx30 surround sound system. speakers are plugged in to dvd player. dvd player is connected to tv via hdmi cable. speakers only work when using dvd player and not tv/sky etc.. am i missing some...
Hi,here is my simple solution...
To listen your TV on your
samsung ps wx30 surround sound system ,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out " of your TV unit
** to "AUX input " or "TV" OR "Any input" of your
dvd player or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
dvd player corresponding your RCA or Optic connection or HDMI ..
There you go..Your TV sound is on the
dvd player By this means whatever you watch on the
TV (
tuner, satellite , Xbox , etc..) ,it's sound will come thru your
dvd player.
Hope this helps!..if more he?p requires pls let me know..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 25, 2011 | Audio Players & Recorders
How to connect motorola cable box to samsung dvd/vcr model vr375 to a Westinghouse hdtv with 2 hdmi connections
The DVD-VR375 does not have an HDMI input. The connection should be:
• RED WHITE & YELLOW CABLE from your cable box (AV OUT) should connect to the DVD-VR375 (AV IN 1). Set the DVD-VR375 to AV 1 using the INPUT SEL. button.
• Next, connect an HDMI cable from the DVD-VR375 (HDMI OUT) to the TV (HDMI IN). Set the TV to the proper source.
This connection would allow the recorder to work as a pass through and will let you record TV programs as well as watch your cable channels.
Hope this helps!
Jul 06, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
I have connected my DVD/VCR to my Samsung 32 inc television but I get no sound
I had a strange issue yesterday too.
Our Samsung DVD/VCr all in one combo did a similar thing.
I used the HDMI cable for the DVD into the TV input labeled HDMI/DVD. That worked okay.
But the VCR part didn't work.
At one point I got sound but no picture. Using the RCA cables in the back on another input "Component 1"
I was trying to squeeze the best picture out of the player using the S-VHS cable.
I thought it did picture only, but the Plasma seems to be more picky about input sources.
I got everything to work keeping the DVD as a separate HDMI to Plasma TV feed.
The VCR was 3 RCA's Yellow (picture) red and white for stereo sound.
I then reset (toggled through the inputs to "reset" the TV.
It finally worked but I was two days mulling it over.
See if this works for you.
My TV was a Panasonic Plasma, but shouldn't matter.
Skip the S-VHS line and connect the inoputs with the TV off.
You MAy need to go into the input of set up menu on the TV (ours had a wrench as an icon) and set the Component 1 or 2 to "VCR".
Aug 04, 2008 | Samsung Televison & Video
My Samsung LN40A530 only produces a blank blue screen whenever I try to use an HDMI input source. Audio seem to come through fine but not the video. Other, non-HDMI video inputs work fine. I've tried...
We are having the same problem. We have 2 DVD players with up-converter to 1080i and 1080p. Both DVD work fine (one Sony and one Samsung) with our Samsung LN-T4053H upstairs, never intermittent.
LN40A530 downstairs is having "Searching for Signal" problem. Took it back to Sears got a new one, problem followed. Something is wrong with this LN40A530. Perhaps firmware update is needed.
Jun 11, 2008 | Televison & Video
Samsung LE26R51BD HDMI PROBLEM
Sounds to me like you need to change your input feed oin the settings menu of you TV to HDMI. If it doesn't work then you can either return the DVD player because using an HD DVD with a non HD capable TV is pointless, or you can upgrade to an HD TV.
Mar 15, 2008 | Samsung LN-R268W 26 in. HD-Ready LCD...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
