Question about HP Designjet T790 Inkjet Large Format Printer - 24" - Color
Remove roll from sheet path
When i print with plloter appear error remove roll sheet path
2 Suggested Answers
vinay229229
  • 1121 Answers
SOURCE: how to do remove roll
Its malfunction of sheet path paper sensor due to dust, don't open any thing just high pressure air pump required(ex bicycle pump)blow on sheet paper path sensor located just left above of paper roll path(look black "U" shaped, blow air in it.. check it will get resolved... Reason:the IR paper sensor shell having very small path(holes both side) to run the IR beam to other side, if the dust accumulate on IR diode the rays unable to travel to other side, result malfunction of sensor, if we blow presser air on it, dust will clean & sensor will work normally.. Its not funny remedy..it will work try it...
Posted on Feb 02, 2012
A1 rotation from A0 roll
I could't understand the question exactly..I will try my level best, it may helps you..
T770 plotter having three media paths..
1. Sheet path
2. Roll 1
3. Roll 2..
After initializing, printer will ask to load the media, you have to specify the desired media selection ie sheet, Roll1, Roll2..
If U R selected roll one, message appears on screen "Open Roll 1 cover", you have to follow the message, once the paper is loaded in the path, printer has to detect the paper,it has to pull inside with the help of the roll feed motor..
In this case If UR selected Roll 1 on printer screen & inserted Roll 2 media, printer will runs Roll 1 motor, not roll 2 motor.. This problem U might be facing..
If my suggestion is not helping U, pl let me know exact problem what UR facing...
Apr 26, 2014 | HP DESIGNJET T770 Printer
Remove roll from sheet path how
This is one of frequent error in this series.
as you know two types of media paths 1. roll media 2. Sheet media. In sheeteet media loading area, you can observe 'u' shaped(extremly right side where sheet media sits) plastic mould which paper passes through in it. This palstic mould contains paper sensor to sence the sheetmedia. If this sensor is dusty, printer will treats that sheet path accupied by media. The best method to clean this sensor is to blow pressure air in this sheet path area.bicycle pump is best for this process.. try it...
Jan 31, 2014 | HEWLETT-PACKARD T790 InkJet Plotter...
Red and green light turn after first run
Its common problem in T Series Plotters:
Cause of malfunction: These plotters having separate sheet path as well as roll path for print media. After initializing plotter its verify the available media(sheet or roll). If sheet path is occupied by the media it wont allow the roll media, means first priority is for sheet.If sheet path paper sensor dusty or malfunction, printer will say "remove paper from sheet path" even no paper in sheet path..
How to shoot this problem:
You need to clean sheet path sensor located at sheet loading area.(black 'U' shaped part) Applying the pressured air at sensor is the best method to clean.. If problem remain you need to remove the sensor & clean or replace it.
Follow the snaps:
Need to open roll feed right side portion
dadb8b23-32b2-4d8a-952b-038117715d5b.jpg f7392b92-295a-4144-8387-b83355c6889e.jpg 6f066468-8698-4d24-94d4-af1703c40407.jpg 6ed46665-db38-4ccc-8522-c52ae9c50dbf.jpg 37e6b4f2-cc2e-438b-849e-9911bd553c7e.jpg
Clean the IR sensor...
Fix it back..
Note: Technical knowledge required to understand the remedy..
Jan 26, 2014 | HEWLETT-PACKARD CP1025 Laser Printer
T652n 202.03 paperjam
1Open the upper-front cover and remove the toner cartridge.2
Look into the printer. Remove any jammed sheets of paper that you find there.
  • If the print job only consisted of this one page, reinstall the toner cartridge and close the front cover. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If the print job consisted of more than one page, confirm the entire paper path is clear before printing again. Do the following:
    1. Remove the top paper tray ('Tray 1').
    2. Remove any jammed or partially-fed sheets of paper you find here, then reinstall the tray.
    3. Go around to the back of the machine and open the upper-rear cover. Remove any jammed sheets of paper you find, then close the cover.
    4. Once you have confirmed that the entire paper path is clear, reinstall the toner cartridge and close the front cover.
    5. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If you cannot locate any jammed paper under the toner cartridge, then check the rest of the printer for any jammed paper. Do the following:
    • Remove the top paper tray ('Tray 1') and look for any jammed or partially-fed sheets of paper.
    • If you do not find any jammed pages there, reinstall the tray and go around to the back of the machine. Open the upper-rear cover and look there.
    • If the entire paper path appears to be clear, close the rear cover and power off the printer. Reinstall the toner cartridge and close the front cover. Power the printer back on. If a 200 error continues on power up, a sensor in the printer may be malfunctioning. This will require a service call to correct the issue. Please contact Lexmark Technical Support for additional information (see Contacting Lexmark Technical Supportbelow for details).
Aug 28, 2012 | Lexmark T652N PRINTER OPPENHEIMER SPECIAL...
How to do remove roll from sheet path?
Sep 02, 2011 | HP DESIGNJET T770 Printer
Lexmark X85 won't feed paper. When trying to
There could be something in the paper feeder that's blocking the paper path. Please follow steps below to identify and fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside for any debris.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
6. If cartridge area is clear, close the cover.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
ns Serif"'>6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 11, 2011 | Lexmark X85 All-In-One InkJet Printer
My wife tried to print on T-Shirt tranfers meant for ink-jet printers, and they melted onto the fuser roll, and it stinks. I need to remove the fuser assembly and clean it, but could use some instructions....
This might help. I did the same thing with my laserjet printer.
Staples has laserjet cleaning sheets. I ran several sheets through the printer after I pulled most of the transfer paper out.
The sheets are one use sheets so, you will need a few.They are impregnated with cleaning fluid on textured paper.
These sheets clean the entire paper travel path.
Dec 12, 2009 | Brother MFC-7820N Laser Printer
HP PSC 1315 Problem
Glad to know that your problem is solved.
Thank you for using fixya..
Jun 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hp LaserJet 1100: Runs louder than normal and continuously, BUT will not grab paper and print
Fred shine a flashlight down the paper feed throat and see if the feer roller is rotating when the printer tries to print.
I have had to replace many of the feed rolls and separation pads in this series of printer.
the tires get dirty or worn and feed multiple sheets or none at all. check for obstructions as well-sometimes the black mylar sheet which sits in front of the feed roll gets in the way of the paper path and has to be pushed in place. I have also seen paper pieces stuck next to the paper path switch which is visible after removing the toner cartridge. hope this helps.
Mar 28, 2008 | HP LaserJet 1100 Printer
HP Designjet T790 Inkjet Large Format Printer - 24" - Color Logo
20 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
