Question about Harman Kardon AVR 40
WILL NOT COME ON DISPLAY SAY PROTECT WHEN YOU MASH THE POWER BUTTON
How to remove protect from my cd receiver display, model HCD-EC99i?
When the protect indicator comes on, usually a power transistor has blown. The unit needs to be taken to a repair shop.
May 04, 2017 | Hardware & Accessories
Protect push power/ sony- MHC RV6
A protect message on a sony usually means there is an amplifier problem.
Jul 19, 2013 | Audio Players & Recorders
How do I delete Mash Button?
To remove the Mash button, first I'll need you to answer these questions:
1. Which Service pack of Windows Xp are you using?
2. Which browser are you using?
Feb 21, 2013 | Microsoft Windows XP Home Edition
My JVC car stereo display " Protect " on display
FIRST PRESS THE RESET BUTTON BEHIND THE FACE IF DONT WORK CHECK ALL SPEAKER WIRES SOMETHING MIGHT BE TOUCHING
Jul 24, 2011 | JVC AM FM CD DET FACE CAR STEREO
Vs15 (Gray, Metallic) 15 in. Flat Panel LCD Monitor: you mash the power button and the light will come ...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 16, 2010 | HP vs15 15"LCD Flat Panel Monitor
How do i get the thing to not say protect
try factory reset by unplugging unit then hold down tuner button and video select buttons then plug in unit let display flash a couple times then release,if unit goes back to protect,you have a shorted power amp problems.
Apr 13, 2010 | Denon AVR-900 Receiver
Lack of power
The computer will not allow the car to full rev in park to protect the engine. Likewise there is a rev limiter when in drive which will shut down injectors at high engine speeds usually around 5000 RPM or so.
Mar 16, 2009 | 2005 Chrysler 300
Kenwood in dash cd player
The protection function is activated when the speaker wire has a short-circuit or touches the chassis of the vehicle. Wire or insulate the speaker cable properly and press the reset button. (The reset button is that little pinhole button below and to the right of the volume control). If you do this and the "PROTECT" code doesn't disappear, you'll have to consult a service center. Further, if you had this professionally installed, they should be obligated to fix the issue for you (hopefully).
Jul 23, 2007 | Kenwood KDC-MP205 CD Player
16 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
