Question about Next Lil Gem
The chain guard on my daughter's 16 inch "Lil Gem" broke off. Where can I find a replacement?
Where to buy a chain guard replacement for a kids bicycle brand name "mini viper 16 inches wheels diamondback."
Any bike shop that deals with Diamondback should be able to order you one.
Feb 02, 2016 | Cycling
I bought a meridian trike from schwinn, my kids took a hammer to the chain guard and my wife is upset, is there any way I can just buy a new chain guard for this trike? Also want to put a motor plz
Schwinn Meridian chainguard - schwinnbikeforum
www.schwinnbikeforum.com > ... > WELTERWEIGHT PLUS
Oct 20, 2012 - 5 posts - ‎5 authors
A little help please... My daughter needs a new chainguard for her Schwinn Meridian. She loaned her trike out, to be used in a parade, and ...
I need a new chain guard for a Schwinn Meridian Adult - Fixya
www.fixya.com/.../t10679393-need_new_chain_guard_schwinn_meridi...
Oct 16, 2011 - SOURCE: Meridian Adult 26-Inch 3-Wheel Bike: Schwinn Meridian Tricycle rear brake adjustment... ... Schwinn Meridian Adult 26-Inch... ... Have a manual for Schwinn Meridian Adult 26-Inch 3-Wheel Bike?
Brian riding on his new Schwinn Meridian 24-inch 3-wheel ...
Dec 26, 2015 | Cycling
Chain came off
Take off your chain guard, should be 2 bolts holding the chain bar in place. Then make sure there isnt another bolt or screw you missed, pop off cover put chain on, replace chain guard and tighten chain. It should be that simple
Jul 22, 2012 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
My chainsaw starts and runs, but the blade wont turn.
Sounds like the chain brake is on, grag the hand guard and pull it firmly right back to the top handle until the brake clicks off, now try again.
Sep 19, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I put oil in my new chainsaw, but it is smoking and the chain is not turning.
Sounds like the chainbrake is on, grab the hand guard and pull it fully back to the top handle until it clicks and the brake is off.
Sep 03, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
What is the name of the release bar or guard bar that move forward to release or stop the chain
Hi, its called a chain brake lever but is referred to as a front hand guard by some manufactures. Hope this helps, regards Phil.
Jul 27, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Can't get chain to move. Engine starts ok but seems to be burning clutch. Has not been used for 18 months.
Hi there, I suspect that the chain brake has been activated. To release it, pull back the front guard (in front of the front handle) until it clicks. The chain should now be free to move. Happy sawing !
Nov 06, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Remove chain guard
The OM for your saw is is the best guide. You can download a replacement here (disengage the chain brake first - pull handle aft):
Poulan.com/CurrentModels
http://www.poulanpro.com/node4043.aspx
Type just the model numbers (choose the suffix after the list is provided).
A broad adjustment procedure can be found here. Completely remove the bar cover, slide the bar against the drive sprocket, remove the chain from the bar.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 10, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Won't turn over
RESET THE GUARD AT YOUR LEFT HAND. THERE IS A GUARD AT THE TOP OF THE HANDLE THAT KICKS WHEN THE CHAIN COMES OFF.THAT SHOULD DO IT. GOOD LUCK.
Apr 28, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Open Questions:
Next Lil Gem Logo
65 people viewed this question
Top Next Cycling Experts
downhille
Ted Maxwell
Jerry Kramer
Jerry Kramer
Are you a Next Cycling Expert? Answer questions, earn points and help others
