Dell 1320c service manual
While processing a print job, the machine is very squeaky and loud. Does it need oiling?
printech
  • 159 Answers
SOURCE: Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Posted on Mar 16, 2008
leroyal
  • 2120 Answers
SOURCE: HP Laserjet 4050 hangs on processing job
Unplug printer cable.
turn off
turn back on and wait for READY
turn off
connect printer cable
turn on
Posted on Jan 05, 2009
  • 4 Answers
SOURCE: Dell 1320c prints black as light grey. Tonor
This isn\'t a fault with the printer, IT IS A FAULT WITH THE WAY IT HAS BEEN SET UP! The problem is, not all of the tabs have been removed from the PHD unit inside. In order to remove these, you need to open the front cover of
the printer, move the four tabs 90 degrees and pull the whole PHD out.
You will then see the four yellow tags on the side.
Having printed with the tags in means the PHD has been potentially
damaged. If you\'re lucky, you\'ll get away with removing the tags now and
it will return to normal after about 50 pages, it not then you\'ll need a
new PHD. The reason the problem manifests itself with black first is
because the black is the most commonly used colour.
For info on removing all the tags, see here:
http://support.euro.dell.com/support/edocs/systems/prn1320c/en/ug/1320c_en/section04.htm#1055182
Posted on Oct 03, 2010
SOURCE: my dell 1320c laser printer is starting to sound
Mine is doing the same thing and no luck on anyone advising where to lubricate the inside the unit. I'm sure it's a simple fix...mine honestly just sounds like it needs "oiled"... but where to "oil" it is the big question. It still prints beautifully. Can anyone out there help?
Posted on Nov 08, 2010
SOURCE: Dell 1320C
On page 30 of the 1320c manual it says this signifies the coming end of the PHD (print head device). I cannot find a part number or reference to the PHD on the Dell web site pages connected with this printer
Posted on Dec 15, 2010
The left side of paper comes out of my Dell 1320c printer very faint. Why?
If there is a toner cartridge in this printer, take it out and shake it. Do this outdoors in the event that come toner comes out in the process. Don't want to soil carpeting with toner! Sometimes the toner clumps up and doesn't spread throughout the cartridge. Shaking it, distributes the toner and allows printing more evenly.
Jan 08, 2015 | Dell 1320c Laser Printer
Dell 1320c printer is squeaking when printing
Hi, my Dell 1320C has started making a squeeking noise when it prints. It's like some rolling parts need oiling. Any suggestions?
Feb 28, 2012 | Dell 1320c Laser Printer
Dell 1320c print spool issues
Today I installed my new printer Dell Color Laser Printer 1320c. I cannot print as documents sent to spooler. I tried reinstalling. o good. I disabled spooler...no good. I'm a technophobic with little spare time, running own business and cannot print the documentation I need. Any help out there?
Jul 02, 2011 | Dell 1320c Laser Printer
My dell 1320 is not printing on the left side of the paper, it is very faded. What is the problem?
I had a similar problem with my 1320c. It seems that it is to do with toner contamination in the optical processing unit. I solved this issue by removing the unit and cleaning the mirrors/lenses in the open front of the unit and the laser/mirrors behind the plastic cover at the back with compressed air. This is an involved job needing the removal of all the outer casing and a couple of circuit boards. Only tackle this if you are competent with electro-mechanical devices.
It seems a real shame that this printer was not manufactured with a sealed optical processor unit which would have cost very little extra and stopped the contamination.
Nov 20, 2010 | Dell 1320c Laser Printer
My dell 1320c laser printer is starting to sound like wheels squeaking, can I do any greaseing or oiling?
Sep 09, 2010 | Dell 1320c Laser Printer
Wrong size paper error Dell 1320C
if you are printing letter size then setting the tray to a4 will produce an error... if you really need to print a4 then go into the driver and set it to print a4 and in print options set it for a4...and set the tray for a4
Dec 20, 2009 | Dell 1320c Laser Printer
Dell colour laser 1320c printer prints one page
in your printer properties set the paper size according to your printer paper size.
Nov 27, 2009 | Dell 1320c Laser Printer
Error light is "Orange On"
I did return to the Dell Spare Parts section and connect to someone via their Chat service. Although (at 45 minutes) the chat process took about twice as long as I expected, in the end they did have the DT574, Print Head Device which I ordered at $116 plus tax and shipping. This was less than the $168 I found at two independent web sites. I am assuming they are sending me the correct item for the printer. If not, I will follow up on this posting to let everyone know.
Jun 10, 2009 | Dell 1320c Laser Printer
Dell 1320C
Jan 30, 2009 | Dell 1320c Laser Printer
jasbo
jasbo
