Question about Admiral 3.4 cu. ft. Top Load Washer in White ATW4675YQ
Admiral won't run just makes a humming sound - Admiral 3.4 cu. ft. Top Load Washer in White ATW4675YQ
Stopped during cycle. will not spin or agitate and makes a humming noise
The humming noise may indicate a worn capacitor on the motor.
Nov 25, 2015 | Admiral Washing Machines
Water won't come in. Hums, fill light flashes once but no water
Sounds like a bad inlet valve--the part the hoses connect to. You may want to check that the house valve at the washer did not somehow get turned off also. The hum is the valve trying to open.
May 20, 2015 | Admiral Washing Machines
I have an Admiral side by side model LSD2615HEZ that is not cooling. I can hear the hum of the condenser, but do not hear fans kicking on when I turn the temp gauge from 0 to 9. I don't hear a click or...
Do you hear the thermostat control clicking off and on if so turn on set about half way and remove cover from back and see or hear if the compressor and motor are running if not you need to replace the starting components go to a appliance store and buy a 3 in 1 kit and follow the diagram for installation make sure you disconnect the power before working on it. good luck and please leave me feedback so I know it works.
Feb 04, 2015 | Admiral 26 cu. ft. Side-By-Side...
My admiral washer sometime will not complete the spin cycle. If it sits for a while it will eventualy start working. When it is not working the drum will not even move.
1. The timer is failing. 2. The drive motor is disconnected from the drum but will make a hum noise. 3. The motor is failing.
Nov 16, 2013 | Admiral Washing Machines
Condensor Fan won't stay running
Check capacitor if its good its the motor
Aug 30, 2012 | Gibson Heating & Cooling
My dryer won't turn on and it makes a humming
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2011 | Kenmore 600 6965 Electric Dryer
The agitator will not run the motor only hums. The spin cycle works and pumps out the water.
Sounds like your agitator is jammed with perhaps a sock or something, You may be able to lift the agitator up to clear it.
Jan 09, 2010 | Admiral Washing Machines
My Admiral lg capicity washer won't agitate or spin
Sounds like the belt is broken. Yes you can fix yourself. Lift top, remove front cover, belt is at bottom, not to hard to replace. If belt is not broke let me know, I will go further.
Jul 17, 2009 | Admiral AW22 Top Load Washer
Admiral Refrigerator/Side by Side
compressor or sealed system issue compressor is failing or a problem in the sealed syetem is putting a back pressure onto the comperssor causing the compressor to eventualy kick of on the internal overload in the compressor, cools down as you unplug the unit allowing the compressor to cool down resets the internal overload runs and repeats the process
have the unit checed by a quilified tech in ref sealed system repair
May 27, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral 3.4 cu. ft. Top Load Washer in White ATW4675YQ Logo
35 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
