Question about Kitchen Nutrition West Bend Americraft Regal Ware Kitchen Nutrition Oil Core Waterless Electric Skillet MADE IN USA BY WEST BEND
Probe control PC066 need this probe control
Display shows SHORTED PROBE
When lincoln pizza oven shows shorted probe, this is a fault message which is not difficult to solve. You only need to replace the probe and it will be ok. this means that the probe is kaput and should be replaced.
The probe is inserted in main pan chamber next to the burner.Open the back cover unclip the probe from the holder and pull it backwards into to the control box chamber.On replacing the probe make sure only the thin part wire like of the probe goes into the heating chamber. make sure that bulb remains inside the control box chamber otherwise it would go kaput again.
Aug 01, 2013 | Lincoln Impinger 1116 Gas Oven
My house was hit by lightening last night. Since then my Frigidaire stove, blinks F3 when turned on.
Hi.
F3 means that the temperature sensor is open. Locate and remove the temperature probe. Use a multimeter to read the impedance at probe contacts. At room the probe will read about 1.1KOhms. If it reads infinity (open), then the probe must be replaced.
If the probe is good, test the wiring between probe and electronic control. If wiring and probe are good, then the problem is electronic control.
Test the probe first.
Apr 25, 2011 | Frigidaire Kitchen Ranges
After removing the heat sensor i closed the door. Now I cannot open it please help. F3 code.
The error code F3 indicates an oven sensor problem. You will need to remove the back of the range and locate the temperature probe (usually in the upper right hand corner. First disconnect power to the range. Ohm the probe, it should ohm approximately 1100 ohms at room temperature. If not, the probe is bad. If the probe ohms near 1100, you will then need to make the same measurement at the EOC (Electronic Oven Control) with the probe connected to these wires. If you get 1100 (approximately) the control is bad. If the probe ohms correctly and you have a different reading down the wires from the control the wires are bad.
Jan 22, 2011 | Frigidaire FEF336BC Electric Kitchen Range
I have a frigidare and my oven wont stop beeping codes like f-10 and f- 30 what does this mean
this is a bad ove probe fault.you will need to check the resistance of the oven probe.remove the back panel and diconnect the probe then check the resistance at room temp the resistance should be no lower than 500 ohms if it is less replace the probe.
you will also need to check the wiring to the probe and main control board,IF the probe checks as good then you will need to replace the main control board.
This will fix your oven,please rate or comment on this resolution.
Dec 12, 2010 | Ovens
Error code f31 flashing
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from www.searspartsdirect.com website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
http://media.fotki.com/1_p,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 03, 2009 | Kenmore 96422 / 96424 / 96429 Electric...
Kenmore Gas range. Oven does not work and F30 alarm displays.
Sep 01, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Our kenmore 790 built in oven keeps flashing an F30 code after we turn off the oven, or sometimes when the oven is on, it shuts off and then beeps the F30. I keep hearing it is the RTD probe, but where is...
Mar 06, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore Elite made by Frigidaire 30" slide in electric range model # 790.46603501 shows F30 ERR. Oven will not work. Range top is fine. Help!!! Turkey to cook!! Lynne
Nov 26, 2008 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
Kitchen Nutrition West Bend Americraft Regal Ware Kitchen Nutrition Oil Core Waterless Electric Skillet MADE IN USA BY WEST BEND Logo
64 people viewed this question
Top Kitchen Nutrition West Bend Americraft Regal Ware Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Nutrition West Bend Americraft Regal Ware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
