Question about RCA Rtd3136 5.1 Channel Home Theater System With Dvd Player
Can you use dvd without speakers
Can you used the dvd part of rtd3136 home theater and get the sound from the tv
    New Friend:
    Problem Solver:
Yes you can get sound from tv provided there is audio in on your tv. To get sound select AV on your tv remote
Posted on Dec 30, 2014
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 89 Answers
Yes, go to your Television menu and system settings, select sound source and set it to internal speakers
Posted on Nov 24, 2014
RTD3136 100W RCA DVD Home Theatre System- everything is hooked up correctly, but the menu isn't coming up on the TV so that i can program it for the sound etc.
Click INPUT. you should see several options, like..TV. AVG. HDMI etc. Choose each one until your information shows on screen. This is how it is on a smart T.V. I hope it works for you
Feb 10, 2015 | RCA Audio Players & Recorders
I have an RCA RTD3136 theater system, bought new in 2013. Worked fine for a few months, then started going out occasionally. I'd unplug the unit and reset, and it would work fine,for a while.
It sounds to me like the audio output transistor or IC is going bad,or the unit is overheating.Try blowing the unit out with canned air and relocating it so it can(breathe)<dissipate heat .
Nov 12, 2014 | RCA Rtd3136 5.1 Channel Home Theater...
Manual for rca home theather rtd 3136
How old is your TV? The red, yellow, white cables will go on the back of the TV.
Mar 16, 2014 | RCA Rtd3136 5.1 Channel Home Theater...
Instruction manual for a RCA Home Theater System RTD 3136
The speaker jacks are labeled on the surround system.
front left front right
sub woofer
(can be located either side)
center
left rear right rear
tv= audio out ( red/white ) to surround=audio input ( red/white)
yellow is video, not needed for sound
Feb 18, 2014 | RCA Rtd3136 5.1 Channel Home Theater...
Is it possible to use the home theater speakers without using the dvd player? i would like to use the home theater speaker system with my tv while watching broadcast and not a dvd. how do i set this up?
I couldn't find a manual but...
The TV is NOT a primary audio source. If your cable box or whatever else you're watching has audio output I'd run that into the AUX, if it has one.
Dec 28, 2010 | Curtis DVD2054 Theater System
Someone gave me this system without a remote. When I turn up the volume, my TV and the system echo each other. What can I do?
It's customary to mute the TV speakers if you're using external, presumably better, speakers. The best TV-related audio would be obtained not from the TV but from the original source you're watching - CD/Cable/DVD/BluRay/Game.
If you have the manual you might also want to see the settings for speaker distance from the listening position as that can cause an indistinct sound image if grossly incorrect.
Dec 09, 2010 | Progressive Computer JSI 6 spkr. Home...
5.1 Dolby system does not work with the T.V.
Solution: connected the rear right and left wires to the Front , left and right wires......................and everything works the way I anticipated without any technical problems....... the woofer works on a separate circuit, so I continue to receive the "low" frequency..
Oct 01, 2009 | Memorex MiHT5005 Theater System
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
Sc-pt660 + 46pz85u = NO SOUND!
Don't worry about sending the TV audio to the Panasonic. Just send a digital audio signal from the cable box to the Panasonic.
DVD - Panasonic connected via HDMI
TV - Panasonic connected via HDI
cable connected to cable box and TV. But you will not really be using the cable connection to the TV (TV Tuner) since you will want HD feed from cable box through HDMI input on TV.
You aren't concerned about feeding the TV speakers because your audio will always come from the home theatre.
Note that some components don't feed audio through HDMI, in which case you will need to use optical digital audio.
Sep 08, 2008 | Panasonic Home Theater System System
RCA Rtd3136 5.1 Channel Home Theater System With Dvd Player Logo
101 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
