Question about Kenmore Elite HE5t Washer
Replace pulley and drive belt on a front load GE Washer WHDVH626FWW
Need manual
freetek
  • 5568 Answers
SOURCE: kenmore front load washer eco system belt
Go to Sears.com and follow the links for parts, you will have a search window for your model and their website has complete illustrated parts breakdowns with part # and prices.
Record the Sears belt part number and check with anyone who sells belts in your area.
They will have a cross reference to Sears/Kenmore part numbers so you don't even really need to know the size.
The replacement belt will have a length on the cardboard sleeve that you can add to your user guide.
Posted on Jul 22, 2008
blueextc3221
  • 15935 Answers
SOURCE: I have a Kenmore front load washer 41740042990
motor controller is the likely culprit.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
blueextc3221
  • 15935 Answers
SOURCE: GE front load washer WSXH208A1WW belt slips off
There is a belt tensioner pulley. If it is failed - your belt won't properly tension.
It appears your tensioner has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Posted on Sep 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a front load washer model #44832. We had a
FREE??
The unit is not under warranty.
Posted on Sep 14, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Front Load Washer Drive Belt Keeps rubbing up against Tub
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
Posted on Sep 16, 2010
I have a 2 year old GE WCVH6260HWW front loading washing machine. Last night I smelled burning and there was actuall smoke in the room. I just shut it down. To me it smelled like a rubber (belt) type...
Pull the back panel off and look at he drive belt. My pully nut loosened up and caused extreme vibration (more than usual). The pulley is aluminum and it rounded out the center hole of the pulley. The belt finally came off. I replaced the pulley and belt.
Sep 05, 2010 | GE WBVH6240F Front Load Washer
GE front load washer wont start model #WHDVH626FWW
there is a chance that your door lock has failed
Feb 06, 2010 | GE WSXH208A Front Load Washer
Washer will fill and spin but will not agitate ge top load washer wwsr3130w0ww
It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Jan 02, 2010 | GE WBSR3140DW Top Load Washer
Ge whdvh626 washer fills and drains. drun does not
I took off back plate and noticed belt was off. I also noticed that pulley was very loose. I ordered new pulley and belt and replaced myself. Thanks.
Dec 16, 2009 | GE WSXH208A Front Load Washer
Need to get replacement belt for washer. where to
If the model number you have this question listed under is correct, the part number for a replacement belt is WH08X10024. You can find it listed at appliancepartspros.com for about $37.
If you have never replaced a belt on this type of washer before, the following link explains how:
http://www.fixya.com/support/r3059652-drive_belt_installation_whirlpool_duet
The link is for Kenmore Elite and Whirlpool Duet, but the GE model listed is identical in design.
If you have any questions, please let me know. I hope this helps you.
Oct 15, 2009 | GE Energy Star WCVH6260F Front Load Washer
Washing machine won't turn back and forth
Most likely your drive belt has slipped off. Open up the back of teh washer and see if the drive belt has slipped off and ease it back on with a screwdriver.
Jun 29, 2009 | GE WSXH208A Front Load Washer
Changing the belt on a GE front loading washer
Hello , i can try to help , I have always got these belts on by starting the belt on the small pulley/motor , then rolling it on the large pulley , kinda like putting a bike chain on. Let me know if you have any other questions and how it turns out.
Phil
Jan 07, 2009 | GE WSXH208A Front Load Washer
I have a GE front load washer model # whdvh626fww. it keeps making alot of noise when in the spin cycle and the belt keeps coming off. at first I thougt it was out of balance but that was not it . when I...
I have a different suggestion based on my washer's similar problem. If the black stuff is powdery and localized at the back of the unit, more than likely the culprit is the drum pulley itself is warped, causing the belt to chafe against the drum. The black powder is rubber residue from the scraping of belt on plastic. No need to replace unit. New belt and new pulley run about $70 each.
Jul 19, 2008 | GE Washing Machines
Kenmore Elite HE5t Washer Logo
21 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
