Question about Vehicle Parts & Accessories
Chevy equinox headlights are not working - Vehicle Parts & Accessories
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 104 Answers
Check fuse boxes. diagrams are usually on cover look for hd lght or some thing to that effect. if its not a fuse the switch could be bad seem s chevy owns the paten on bad switches if they turn on all together with the turn signals. usually both bulbs do not go out at the same time, without a real bad short in the wiring. good luck!
Posted on Feb 16, 2014
2005 Chevy equinox when releasing the emergency brake and the headlight switch is on auto the lights come on automatically except the tail lights.
You probably have daytime running lights - when you do this during daylight hours, only the front running lights will come on. If at night, regular headlights and tail lights will come on. If this is not the case, you will have a problem with the headlight control module.
Apr 10, 2018 | 2005 Chevrolet Equinox
Dim headlight one side
Check voltage to lamp assembly. Could be a relay, a bad wire, or a bad connector. Since one headlamp works correctly, the switch assembly probably works. Without a wiring diagram. I can't tell whether the headlights get power directly from the switch or not... Time to buy a manual.
Apr 01, 2014 | Chevrolet Equinox Cars & Trucks
Headlight problems with my 2008 chevy equinox
We'll if you are replacing bulbs and they work when you put them in but burn out quickly, that symptom along with condensation inside the lens surly indicates a moisture problem meaning somewhere there is a bad seal in the headlight lens assembly.
Nov 24, 2013 | 2008 Chevrolet Equinox LS
2005 chevy equinox headlights went out, only the driver side bright light works. Does this mean the passenger side headlamp is blown?
Sounds like you are right own...to change each bulb...you need to remove the chrome grill from the front center...be sure to pry up the clips carefully so not to break the trim bar...then each headlight assembly is removable with 3 10 mm bolts...do not touch your exposed fingers on the new bulbs...yes the low/high bulb is one unit...that is why I believe it is just your bulbs...about $11. each...Hope this helps.
Jan 25, 2011 | 2005 Chevrolet Equinox
Chevy 2005 Equinox, day time running light when out, are they controlled by a fuse?
The Daytime running lights are controlled by a relay under the hood that says "DRL"
I would just pull the relay and not worry about it. daytime running lights are just an annoyance.
Apr 16, 2010 | 2005 Chevrolet Equinox
Change the headlight on a 2006 Chevy Equinox
The front bumper cover does have to come loose at the top. Remove the retainers along the top of the front bumper cover on top by the radiator and loose the part of the grill that goes over the headlamp. cover with tape to avoid scratching the lens . then remove the 3 bolts for the headlamp. Two at the top and one down at the bottom inboard side. Then pull the headlamp at the outobard bottom to release the retainer and remove the headlamp.
Aug 17, 2009 | Street Glow Streetglow Streetglow H894...
I need a diagram of a 2005 Chevy Equinox engine
where is the coolant temp sensor on a 2005 chevy equinox
Aug 05, 2009 | 2005 Chevrolet Equinox
Low beam and DRL will not come on
most headlight switches are pop in style that u just pop out of the dash and gently undo the electrical connector and replace it in reverse order, however all GM cars have individual relays for the lights so You may want to try a new relay first.
Jun 30, 2008 | 2005 Chevrolet Equinox
Vehicle Parts & Accessories Logo
65 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
