Insignia tv, will not power on. no lights are on
No power, tv will not come on, reset fuse box, changed sockets, still no power
  • 40 Answers
Try using a different room. The sockets will probably be on a different circuit. If that doesn't work, it sounds like a power supply problem on the TV. You'll need to replace the part. Unfortunately, it's usually cheaper to buy a new Insignia tv than getting the power supply replaced. TV technicians are expensive
Posted on Apr 30, 2014
2 Suggested Answers
SOURCE: Tv when plugged in trips main fuse box
If there is a short circuit inside the TV, the fuse should normally blow first before tripping your breaker. The only exception is if you have a short in the ac cord or the line filter of the TV set. Have you tried the tv on another circuit to see if it trips that breaker? If not, it could be that your first circuit is close to an overload and the TV is simply pushing the circuit "over the edge".
Posted on Sep 04, 2012
I have an Insignia 32 inch tv. When watching a local channel today using antenna/TV the channel box and the menu keep flashing on and off screen.
Do a hard reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Feb 21, 2018 | Insignia Televison & Video
Why wont my insignia tv NS-D260A13 turn on after a storm?
Could very well have been shocked by lightning. If so, it is probably dead. To check, try the wall socket with a light to see if there is power there. Check the power line to the TV to see it is in good condition. Look on the back of TV for a fuse or circuit breaker (and if you have an extension cord with a circuit breaker). Use both TV mounted Power On button and the remote. If all this fails and the TV is expensive or in warranty, you have to fix or trash it.
May 20, 2017 | Insignia Televison & Video
Insignia flat screen tv will not power on,nothing,not even a power light. what causes that?
hi i take it you've check the fuse in the plug, if ok, the fuse inside the tv on the power board could have blown.thanks
shaun
Mar 03, 2017 | Insignia Televison & Video
THE TV WILL NOT POWER UP. WHAT DO I DO?
Tv have a LED light indication flashes or no LED light indication at all to the tv set?Check ur power out socket source,for power?Yes.Tries tv unplug,replug it back like about an hour later for the tv do a resetting itself back to the factory setting.Tv should be working again now.If still have the same problems.The tv power supply board it is dead.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 14, 2011 | Insignia LCDTV26 26 in. Television
How do i program the control to the converter box!
Try these steps: 1. Turn on your TV and change it to channel 3 or 4. 2. Press the power button on your Insignia Remote control. The converter light will be turn on in stand by mode (the red light appears). Press the power button again, the blue light will be on. 3. On your Insignia remote control, press the menu button. 4. A menu items appear, navigate to the autoscan item to scan channel.
Jun 13, 2009 | Insignia Digital-to-Analog Converter for...
Insignia tv, universal remote, and.....
Follows steps below to program your Insignia Converter Box:
1. Turn on your TV using your TV remote control and change its channel to 3 or 4.
2. Turn on the convert box; the blue light on the converter box is on. If you press the power button again, the red light on the converter box will be on, but do Not turn it to Red!!! Your insignia's other buttons will not response if it in red light mode!!!
3. Then press the Menu button on the Insignia remote control. A wizard will appear. The wizard does not appear if your TV is not in channel 3 or 4.
4. Follow the wizard instructions to scan channels.
Volume problem on odyseey
Check the following fuses. Fuse No. 8 (7.5A) in driver's side kick panel fuse box. Fuse No. 9 (15A) in passenger's side kick panel fuse box. Fuse No. 11 (10A) in passenger's side kick panel fuse box. All these fuses need to be good in order for the audio unit to work. Also check the power sockets (cig lighter) for power. If the fuses are good but no power to cig lighters then the accessory power socket relay is bad. Its located in the passenger side kick panel fuse box.
Feb 19, 2009 | 2002 Honda Odyssey
Sony Bravia LCD TV is tripping the fuse in the house
These things draw a huge surge current when turned on. What size fuse are you blowing? These things can surge 10-12 amps on turn-on. What about a fuse with a reset button. They will take alittle more surge before they go. Don't matter about the insignia working before because the cheaper sets tend to stay powered up more when off....thus not surging on from a dead start. Could you try a different plug on a different circuit/fuse? and see if that makes a difference. If you have a 15 amp fuse, then your pretty close with other stuff plugged in. What size is your service? Do you still have an original 60 amp box with screw in fuses? Is it an old house?
Sep 08, 2008 | Sony Bravia KDL-40S4100 40 in. LCD TV
Problem with tv
look for reset sw. under unit.
Aug 02, 2008 | Insignia Televison & Video
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
