Question about Kyocera FS-1035MFP
Kyocera fs3140 maintenance kit reset - Kyocera FS-1035MFP
3 Suggested Answers
  • 58 Answers
SOURCE: New maintenance kit
Hi Did you run up the developer unit? Menu button down to Other then to Service and press enter on developer and switch off and turn on will run for a while. In the service menu after you run up the dev unit you may have a option in there to press enter on the MK Symbol.
Cheers
Posted on Jun 27, 2008
  • 95 Answers
SOURCE: kYOCERA fs-1920 Has the message instal
It means the page count has triggered this message.
You _should_ get a maintenance kit.
But if you simply can't take the time/money, you'll find a new menu item in the menus after service. the new item is 'maintenance', get to there and press enter. (May need to press enter twice), the menu item, flashing light, and install MK message will all disappear.
Posted on Sep 08, 2010
Reset Replace Maintenance Kit warning error on Kyocera FS1370DN
Press MENU on device, scroll to ADJUST/MAINTENANCE, press right arrow and you should see NEW MK.
Press OK twice.
Oct 09, 2015 | Kyocera Office Equipment & Supplies
How do I get rid of 'Install MK' message?
Missed something, Part of the maintenance kit is the developer and also the drum unit, you will need to change the 1/8th amp fuse in the developer assembly, and also the chip inside the drum unit.
Farnell stock both, the fuses are p/n: 446-816 and the serial eeprom chip is p/n: 690-650
This isnt the exact chip that kyocera use as they use a 93LC56B, but the ones that i have fitted before are 93C46 -these seem to work just the same.
Hope this helps.
Jun 02, 2015 | Kyocera FS-1135MFP
Resetting for replaced MK kyocera fs 1135
press numeric keys 1087 1087 , then 251
Checking/clearing the maintenance count Description Displays, clears and changes the maintenance count. Purpose To check the maintenance count. Also to clear the count during maintenance service (replacing the maintenance kit). Method 1. Press the start key. The maintenance count is displayed. Setting 1. Select [M.CNT A] using the cursor up/down keys. 2. Change the setting using the cursor left/right keys or numeric keys. 3. Press the start key. The count is set. Clearing 1. Select [CLEAR] using the cursor up/down keys. 2. Press the start key. The count is cleared. Completion Press the stop key. The screen for selecting a maintenance item No. is displayed. Item No. Description Description Setting range Initial setting Maintenance count 0 to 9999999 0
May 26, 2015 | Kyocera Office Equipment & Supplies
Time for maintenance C Kyocera 4501ci what is the solution
you need to replace maintenance kit c
MK-8505C (Maintenance Kit) 1702LC0UN2 300K $400.00 0.00133
May 20, 2015 | Kyocera Office Equipment & Supplies
Kyocera maintenance kit reset
You can access the following by hitting the menu key
1. Enter the maintenance mode [>>Maintenance].
2. Press the OK key. [>>Maintenance?] will be displayed.
3. Press the OK key twice. The counter for each component is reset immediately.
Aug 26, 2014 | Kyocera FS-1370DN
Kyocera taskalfa 300ci
10871087 to enter service mode. There are 2 maint. kits for the 300ci. One for color and one for mono. If you were able to perform a maintenance then you should be well versed on which adjustments to make and which counters to reset. If not you can cause major problems so be careful.
Dec 16, 2013 | Kyocera Office Equipment & Supplies
Why does my copystar FS3140 scan slow
default the scan settings to grayscale or monchrome and drop the resolution to 300dpi or lower
Mar 06, 2013 | Kyocera Copystar FS3140MFP Copier
FS3140 memory full
this can occur if jobs hang due to printer error (empty toner, jam, etc...) if the printer usually prints normally but displays that message when faxes are being received then you may need to reset or replace the fax board and update the firmware. you could turn on hdd RAMDISK mode in the command center. You could also add additional RAM
Feb 19, 2013 | Kyocera FS3140MFP AllInOne Laser Printer
Kyocera Printer FS2000-D says "install
You need to turn off the printer and unplug it then install the items from the maintenance kit.
Mar 31, 2011 | Kyocera MAINT KIT: DRUM, DEVELOPER, FEED &...
Kyocera FS-4000DN is showing install MK; Can the problem be fix without buying a Maintence Kit for $532?
> without buying a Maintenance Kit ?
Either you buy the kit, or you sell the printer "as is" on eBay, after buying a new printer.
Jan 19, 2011 | Kyocera FS-4000DN Laser Printer
Kyocera FS-1035MFP Logo
80 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
