Question about De Dietrich DVH610JU1 24 in. Built-in Dishwasher
Where is the flood switch on die dietrich dishwasher dvh640ju1
Where is the flood switch on this model
    Prodigy:
    An expert who has answered 500 questions.
  • De Dietrich Expert
  • 517 Answers
These are normally in the bottom of the dish washer
micro switch controlled by a float
Posted on Feb 16, 2014
Flood switch 920 model
Not sure what the actual model number is but usually the F1 error with Fisher and Paykel dishwasher means water has entered the flood switch located at the base. This could be due to leaky hoses or water leaking through the door or lid seal. Wait for a day or two until the water evaporates and try again. Otherwise you will have to dry out the flood switch and then try again. Location of flood switch will depend on your model. For double drawer dishwasher you will have to take the bottom drawer out from the housing and the switch is on the floor of housing. But make sure you take the mains power chord out before touching the insides of dishwasher. Will also need to find the cause of the leak. Other reason for F1 could be loss of power to top dishdrawer if you have double drawer. But in that case the top drawer will have no lights on. The power board is located on the base of housing under bottom drawer. Once again do not touch inside of dishwasher without shutting off mains power.
Jan 27, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Flood switch activated on dishwasher DW60CSWI
Please clarify the model number. i am assuming you have a standard height single door dishwasher. It is likely the flood switch assembly itself is faulty and giving false results. Check the base of the dishwasher - item 95 in on page 10 in this manual. The microswitch could be faulty or the spring might be stuck.
Jan 21, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
My dishwasher does not deliver water. Switch on and it just switches off again
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 19, 2010 | De Dietrich 18 in. VW7451 Built-in...
De Dietrich dishwasher model DVF300JU2 Child opened door during wash cycle closed door but m/c did not restart,now all lights on! unable to clear/restart, tried to cancel programme by pressing 'Start' for...
try pressing stop or cancel button for 10 full seconds. If this does not work, unplug the machine for 10 minutes. While unpluged, press and hold cancel or stop but for 10 seconds, then plug machine back in. If it still does not work, test the door switch with an ohmmeter to make sure the door switch is not faulty.
Jul 12, 2010 | De Dietrich Dishwashers
Washer starts program but sound much noisier than
Suggest you check the water pressure out the pipe, then clean the inner sieve which is usually in the valve inlet. if all is clean and still little water enters, i would replace valve.Also, chech the pressure switch line an make sure it is not partially filled with water.
Sep 21, 2009 | De Dietrich 24 in. DVF120J Built-in...
The flood switch has been activated on my dishwasher
Remove the bottom drawer by pressing in the tabs on either side of the drawer (bottom edge towards the front).
Dry out the compartment with towels and let air dry.
Apr 11, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Leak from a De Dietrich Integrated Dishwasher has caused 3 red lights on the left of the Control Panel to flash and also a Blue Light on the right hand side of the Control Panel to flash. On resetting...
Pull the built in unit out and tilt towards the rear right leg and the water will drain on to the floor. The Dishwasher then restarts but the anti flood sensor will reactivate after 2-3 more washes. Do not know final fix yet.
Oct 05, 2008 | De Dietrich Dishwashers
Wont switch on
try replacing on/off button or replacing the door switch.
thees parts sould be examind by technishian befor replacment.
Dec 28, 2007 | De Dietrich 24 in. DVF120J Built-in...
De Dietrich DVH610JU1 24 in. Built-in Dishwasher Logo
223 people viewed this question
Top De Dietrich Dishwashers Experts
ray gallant
richie46
Are you a De Dietrich Dishwasher Expert? Answer questions, earn points and help others
